Nextion Screen with Pneumatic Solenoid and TB6600 stepper driver
Hello. I have 12V Pneumatic Solenoid with TB6600 Stepper Driver connected to a nano. I am trying to use Nextion Screen to display motor speed using Numpad and buttons for forward and reverse motor direction. For whatever reason my code is not working. Please help me out here. Thank you.
#include <Nextion.h>
//Define pins
#define relayPin 5
#define enPin 3
#define stepPin 2
#define dirPin 4
unsigned long mdelay=270;
unsigned long Speed=200;
unsigned long rdelay=200;
unsigned long tdelay=200;
NexNumber n0 = NexNumber(0,2,"n0");
NexButton b0 = NexButton(0,3,"b0");
NexButton b1 = NexButton(0,4,"b1");
NexTouch *nex_listen_list[] = {&n0, &b0, &b1, NULL};
  Serial.print("baud=115200");
  Serial.write (0xff);
  Serial.end();
  pinMode(stepPin, OUTPUT);
  pinMode(enPin, OUTPUT);
  pinMode(relayPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  digitalWrite(enPin, LOW);
  digitalWrite(stepPin, HIGH);
  digitalWrite(dirPin, HIGH);
  // Initialize the Nextion library
  nexInit();
  // Register the button callback functions with the Nextion objects
  b0.attachPush(b0_PushCallback);
  b1.attachPush(b1_PushCallback);
  //Read the values entered by the user
  if (nexSerial.available()){
    uint32_t objID =nexObject.getLastNum();
    // Check if the value was sent from the numeric keypad component with ID n0
    if (objID == 2) {
      Speed = nexObject.getNumber("n0");
  nexLoop(nex_listen_list);
  for ( int x=0; x <Speed; x++){
    digitalWrite(stepPin,LOW);
    delayMicroseconds(mdelay); // Use the Speed variable to control the delay
    digitalWrite(stepPin,HIGH);
  digitalWrite(relayPin,HIGH);
  delay(rdelay);
  digitalWrite(relayPin,LOW);
  delay(tdelay);
//FORWARD BUTTON//
void b0_PushCallback (void *ptr) {
  digitalWrite(dirPin, LOW);
  //REVERSE BUTTON//
 void b1_PushCallback (void *ptr) {
Stepper drivers are for use with stepper motors.
Have a link to the solenoid data sheet?
I have this amazon link
I have two pneumatic cylinders with IRFZ34N mosfet to control the flow from the solenoid.
MOSFET is okay, but it should be a logic level MOSFET (IRL...)
