i am using rs485 with multiple arduinos (1 master, 2 slaves). The code is working with a single master and slave setup but when i connect the second slave, the second slave hears nothing.. plxx guide me! The code is mentioned below. For the second arduino i used a second msg..
//Master sketch
#include "RS485_protocol.h"
#include <SoftwareSerial.h>
const byte ENABLE_PIN = 3;
const byte LED_PIN = 13;
SoftwareSerial rs485 (10, 11); // receive pin, transmit pin
// callback routines
void fWrite (const byte what)
rs485.write (what);
int fAvailable ()
return rs485.available ();
int fRead ()
return rs485.read ();
rs485.begin (9600);
pinMode (ENABLE_PIN, OUTPUT); // driver output enable
pinMode (LED_PIN, OUTPUT); // built-in LED
} // end of setup
byte old_level = 0;
// read potentiometer
byte level = analogRead (0) / 4;
Serial.println(level);
delay(100);
// no change? forget it
if (level == old_level)
return;
// assemble message
byte msg [] = {
1, // device 1
2, // turn light on
level // to what level
byte msg1 [] = {
5, // device 2
2, // turn light on
// send to slave
digitalWrite (ENABLE_PIN, HIGH); // enable sending
sendMsg (fWrite, msg, sizeof msg);
digitalWrite (ENABLE_PIN, LOW); // disable sending
sendMsg (fWrite, msg1, sizeof msg1);
// Serial.print(fWrite);
// receive response
byte buf [10];
byte received = recvMsg (fAvailable, fRead, buf, sizeof buf);
// Serial.print(received);
digitalWrite (LED_PIN, received == 0); // turn on LED if error
// only send once per successful change
if (received)
old_level = level;
delay(2000);
//Slave sketch 1
SoftwareSerial rs485 (7, 5); // receive pin, transmit pin
const byte ENABLE_PIN = 4;
rs485.write (what);
int fAvailable ()
int fRead ()
rs485.begin (9600);
byte buf [10];
byte received = recvMsg (fAvailable, fRead, buf, sizeof (buf));
if (received)
if (buf [0] != 2)
return; // not my device
if (buf [1] != 2)
return; // unknown command
byte msg [] = {
0, // device 0 (master)
3, // turn light on command received
delay (1); // give the master a moment to prepare to receive
delayMicroseconds (660);
analogWrite (3, buf [2]); // set light level
} // end if something received
//Slave sketch 2
SoftwareSerial rs485 (52, 53); // receive pin, transmit pin
rs485.write (what);
int fAvailable ()
int fRead ()
rs485.begin (9600);
byte buf [10];
if (received)
if (buf [0] != 5)
if (buf [1] != 2)
byte msg [] = {
analogWrite (51, buf [2]); // set light level
} // end of loop
