Nick Gammon's SendOnlySoftwareSerial
In post #3 of this 12 year old thread, "Using only TX of SoftwareSerial, leaving RX pin free", Nick Gammon introduced his library SendOnlySoftwareSerial
https://forum.arduino.cc/t/using-only-tx-of-softwareserial-leaving-rx-pin-free/109623/2
He didn't say which Arduino boards were compatible with it. Or not. Has anyone here successfully used it with Spence Konde's ATTinyCore? On any aTTiny version?
I tried Nick's simple example
#include <SendOnlySoftwareSerial.h>
SendOnlySoftwareSerial mySerial (3);  // Tx pin
void setup ()
  mySerial.begin(115200);
int i;
void loop ()
  mySerial.print ("test: ");
  mySerial.println (i++);
  delay (100);
with my aTTiny88 board. It compiled and ran, but printed nothing. Tried various changes in the board paarameters but same result. Couldn't find much more here:
his github page
it's meant for ATMEGA 328P or ATMEGA 1280/2560(edited)
The SoftwareSerial library for ATTiny88 is a different library
This is from ATtiny88 data sheets which does not say that the chip contains UART Interface. Does it indeed contain a Serial Port?
peripheralsofattiny88
the ATtiny88 does not have an UART hence the need for SoftwareSerial if that feature is needed
Yet his library is being used here for an ATTiny45 as the second of two methods for accessing software serial on a Tiny. I’d hoped I could do the same, albeit on an 88 and - more critically - still using the ATTiny core.
https://www.youtube.com/watch?v=1xwWpz2V__4
Transmitting is easy - easier than Receiving.
If there's no other way Serial TX can be bit-banged (start bit, 8 data bits, stop bit).
The slower the more reliable - unless you're heavy into the Timers and so on.
sorry you are right. I got confused - sending only is bit banging
115200 might be too high?
Unfortunately not.
