Nicla Sense ME and digitalRead
Hello
I have a quite stupid problem with digitalRead
I modified example Arduino_BHY2->Standalone by just adding
pinMode(9, INPUT_PULLUP) in setup() function
and
Serial.println(String(digitalRead(9))) in loop() function
I connect the pin to ground, but digitalRead prints "1"
I tried with 10 and 20, but still have issues
Does anyone have suggestions?
Thanks in advance!
Hey there,
In the MBED board folder there is a library that contains the pin mapping:
PinDescription g_APinDescription[] = {
  { P0_10, NULL, NULL, NULL },    // 0: GPIO3
  { P0_9, NULL, NULL, NULL },     // 1: GPIO2/RX
  { P0_20, NULL, NULL, NULL },    // 2: GPIO1/TX
  { P0_23, NULL, NULL, NULL },    // 3: SCL1
  { P0_22, NULL, NULL, NULL },    // 4: SDA1
  { P0_24, NULL, NULL, NULL },    // 5: GPIO0
  { P0_29, NULL, NULL, NULL },    // 6: CS
  { P0_28, NULL, NULL, NULL },    // 7: CIPO
  { P0_27, NULL, NULL, NULL },    // 8: COPI
  { P0_11, NULL, NULL, NULL },    // 9: SCLK
  { P0_2, NULL, NULL, NULL },     // 10: A0
  { P0_30, NULL, NULL, NULL },    // 11: A1
  { P0_19, NULL, NULL, NULL },    // 12: INT ESLOV
  { P0_18, NULL, NULL, NULL },    // 13: Reset BHI260
  { P0_14, NULL, NULL, NULL },    // 14: INT BHI260
  { P0_25, NULL, NULL, NULL },    // 15: BQ25120 CD
  { P0_26, NULL, NULL, NULL },    // 16: CS FLASH
  { P0_31, NULL, NULL, NULL },    // 17: CS BHI260
In order to check digitalRead on a pin, you need to use the above map with the pinout, available here:
I do not exactly what you want you consider as "pin 9". But if you want to read the pin called "GPIO3" (which you find in the center-right side in the image).
You can use the following 2 methods:
digitalRead(GPIO3);
digitalRead(p10);
In my opinion always use the "pnumber" method.
Good luck!
EDIT: Forgot to mention that not all pins can be used for digital read/write as they are used for other protocols. GPIO1/2 are always used for TX/RX so you cannot access them from my findings. Even if you don't initialise the hardware serial with: Serial1.begin(9600);
Thank you very much for your reply
With GPIO3, the behaviour is slightly different. it is read as 1, when I connect the pin to GND it is read a 0, but then stays 0 even if I disconnect the pin from GND. Do I need an external pull-up resistor?
I've encountered that type of issue.
Try using a pull-up resistor (10k, 4.7k, 1k etc.) and try reading it as:
digitalRead(P0_10);
digitalRead(p10);
digitalRead(GPIO3);
And see which one gets the job done. For me P0_10 has always been the most successful, although I have not played with the digital Read too much. It seems that the board supports proper digitalRead/Write only on GPIO0 and 3, everything else causes issues.
Always remember to use pinMode(pin, INPUT);, otherwise you will have issues.
I would recommend if you can to have all your sensors either I2C or SPI, or if not, on the 2 analog pins (including the buttons). The digital pins are sketchy.
