NICLA Sense ME battery charging current
Hello everyone!
I would appreciate any help on this subject - i can read and write BQ25120A registers without a problem, but whatever value i write into Fast Charge Control Register it is allways charging with approx 15mA (measured with DMM)...
Did anyone manage to set higher current and how?
To be clear - i can write any value into Fast Charge Control Register and that value will be stored - checked by reading the register...
Lower values like 10mA also do not work...
Many thanks,
Josip
Hello again!
I have made a more precise measurement, charging current is in fact 11mA (do not believe it is important, but just in case...)
one of the codes i used to test this is :
#define BQ25120A_FAST_CHG_AFTER_BOOT 176 //charging current = 120mA
#define BQ25120A_ILIM_UVLO_CTRL_AFTER_BOOT 56 //BUVLO = 3V
#include "Nicla_System.h"
constexpr auto printInterval { 1000ul };
float voltage = -1.0f;
int x;
void setup(){
  for (const auto timeout = millis() + 2500; millis() < timeout && !Serial; delay(250));
  nicla::begin(); // Initialise library
  nicla::leds.begin(); // Start I2C connection to LED driver
  initBQ25120A();
  nicla::leds.setColor(blue);
void loop(){
  static auto updateTimestamp = millis();
  if (millis() - updateTimestamp >= printInterval) {
    float currentVoltage = nicla::getCurrentBatteryVoltage();
    if(currentVoltage != voltage){
      voltage = currentVoltage;
      Serial.print("\nVoltage: ");
      Serial.println(voltage);
      Serial.print(".");
    auto operatingStatus = nicla::getOperatingStatus();
    switch(operatingStatus) {
      case OperatingStatus::Charging:
      nicla::leds.setColor(255,100,0); // Yellow
      case OperatingStatus::ChargingComplete:
        nicla::leds.setColor(green);
        // This will stop further charging until enableCharging() is called again.
        nicla::disableCharging();
      case OperatingStatus::Error:
        nicla::leds.setColor(red);
      case OperatingStatus::Ready:
      default:
        nicla::leds.setColor(off);
void initBQ25120A(){
  Serial.println("BQ25120A Register Map Values after BOOT...");
  printBQ25120ARegisterMap();
  setBQ25120ARegisterMapValues();
  Serial.println("BQ25120A Register Map Values after SETUP");
void setBQ25120ARegisterMapValues(){
  nicla::setBatteryNTCEnabled(false);
  nicla::configureChargingSafetyTimer(ChargingSafetyTimerOption::ThreeHours);
  BQ25120A().writeByte(BQ25120A_ADDRESS, BQ25120A_ILIM_UVLO_CTRL, BQ25120A_ILIM_UVLO_CTRL_AFTER_BOOT);
  BQ25120A().writeByte(BQ25120A_ADDRESS, BQ25120A_FAST_CHG, BQ25120A_FAST_CHG_AFTER_BOOT);
void printBQ25120ARegisterMap(){
  uint8_t value = 0;
  // Register Map
  #define BQ25120A_STATUS             0x00
  #define BQ25120A_FAULTS             0x01
  #define BQ25120A_TS_CONTROL         0x02
  #define BQ25120A_FAST_CHG           0x03
  #define BQ25120A_TERMINATION_CURR   0x04
  #define BQ25120A_BATTERY_CTRL       0x05
  #define BQ25120A_SYS_VOUT_CTRL      0x06
  #define BQ25120A_LDO_CTRL           0x07
  #define BQ25120A_PUSH_BUTT_CTRL     0x08
  #define BQ25120A_ILIM_UVLO_CTRL     0x09
  #define BQ25120A_BATT_MON           0x0A
  #define BQ25120A_VIN_DPM            0x0B
  Serial.println("*********** BQ25120A Register Map Values ***********");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_STATUS );
  Serial.print("BQ25120A_STATUS = ");
  Serial.println(value);
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_FAULTS );
  Serial.print("BQ25120A_FAULTS = ");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_TS_CONTROL );
  Serial.print("BQ25120A_TS_CONTROL = ");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_FAST_CHG  );
  Serial.print("BQ25120A_FAST_CHG  = ");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_TERMINATION_CURR );
  Serial.print("BQ25120A_TERMINATION_CURR = ");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_BATTERY_CTRL );
  Serial.print("BQ25120A_BATTERY_CTRL = ");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_SYS_VOUT_CTRL );
  Serial.print("BQ25120A_SYS_VOUT_CTRL = ");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_LDO_CTRL );
  Serial.print("BQ25120A_LDO_CTRL = ");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_PUSH_BUTT_CTRL );
  Serial.print("BQ25120A_PUSH_BUTT_CTRL = ");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_ILIM_UVLO_CTRL );
  Serial.print("BQ25120A_ILIM_UVLO_CTRL = ");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_BATT_MON );
  Serial.print("BATT_MON = ");
  value = BQ25120A().readByte(BQ25120A_ADDRESS, BQ25120A_VIN_DPM );
  Serial.print("BQ25120A_VIN_DPM = ");
  Serial.println("****************************************************");
  Serial.println("");
