Nicla Sense ME keeps restarting on WebBLE Dashboard Demo
I have run the other examples such as Standalone, and App with Go and they work as intended.
I uploaded the WebBLE Dashboard Demo code from the Arduino Site and it just keeps restarting. The board does not show up in the connect interface on the online WebBLE Dashboard as it does in the html page created by Go demo that use the App example. Serial keeps printing: Start, address = 0f:0d:ad:24:aa:22 name = BLESense-AA22, over and over again and the led shows two quick blue and one long green signals.
The code is copied from the WebBLE Dashboard Demo https://docs.arduino.cc/tutorials/nicla-sense-me/web-ble-dashboard.
Anyon experience this or have any ideas?
Below is what is printed out during upload. I tried inserting the verbose compilation but it exceeded the post limit.
Sketch uses 291732 bytes (55%) of program storage space. Maximum is 527616 bytes.
Global variables use 38800 bytes (60%) of dynamic memory, leaving 25488 bytes for local variables. Maximum is 64288 bytes.
C:\Users\rrace\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2/bin/openocd.exe -d2 -s C:\Users\rrace\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2/share/openocd/scripts/ -f interface/cmsis-dap.cfg -c transport select swd; adapter speed 1000 -f target/nrf52.cfg -c telnet_port disabled; init; reset init; halt; adapter speed 10000; program {C:\Users\rrace\AppData\Local\Temp\arduino_build_582026/ns_web_ble.ino.elf}; reset run; shutdown
Open On-Chip Debugger 0.11.0+dev-gab95bac57-dirty (2021-05-11-10:45)
Licensed under GNU GPL v2
For bug reports, read
	http://openocd.org/doc/doxygen/bugs.html
debug_level: 2
adapter speed: 1000 kHz
Info : CMSIS-DAP: SWD  Supported
Info : CMSIS-DAP: FW Version = v1.0
Info : CMSIS-DAP: Serial# = 00750D1C
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 1000 kHz
Info : SWD DPIDR 0x2ba01477
Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : starting gdb server for nrf52.cpu on 3333
Info : Listening on port 3333 for gdb connections
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x00006dc4 msp: 0x20010000
** Programming Started **
Info : nRF52832-CIAA(build code: E0) 512kB Flash, 64kB RAM
Info : Padding image section 0 at 0x00056554 with 4 bytes
Warn : Adding extra erase range, 0x000573a0 .. 0x00057fff
** Programming Finished **
shutdown command invoked
