i'm testing Nikon intervalometer but have little problems.
I'm using sketch from this site: Sensor tutorials - IR remote receiver/decoder tutorial
Arduino can trigger my Nikon D50, but not every time. For 10 fotos it makes only 6 or 8. When I connect LED I can see it blink, so Arduino sends impulses.
Camera works fine with ML-L3 Nikon remote control. I also tried different IR leds and different pins, different delays, but with no success.
I don't know what's the problem, so I hope someone can help me to find the solution.
No, but I tested my remote signal with arduino and IR sensor via serial monitor and it looks like this one in sketch, there are no big differences. I tried also to send IR pulses more times with 50 microseconds delay, but it didn't help either.
rednaskellar:
Hello,
Do you have a solution to your problem? I have the same problem with a Pentax K-x and an AVR-Butterfly.
If you use his library you can just call the sendRaw() function and input an array of timings. Here is the Nikon code I used in the TriggerTrap
unsigned int MLL3Buffer[] = {2000,27830,390,1580,410,3580,400}; //shutter from: http://www.bigmike.it/ircontrol/
for (int i = 0; i < 2; ++i) { //send twice
irsend.sendRaw(MLL3Buffer,7,38); //ML-L3 (Nikon), suppose to be 38.4khz
delay(63);
If you look in this file, you can find other IR codes used for Pentax or other cameras, around line 700:
