hey,
I'm using first time ADXL345.
I use the Adafruit Library and it says "Ooops, no ADXL345 detected ... Check your wiring!".
I wired like that:
SCL -> A5
SDA -> A4
VCC -> 5V
GND -> GND
And I didn't change anything in the "Adafruit ADXL345 sensortest" at all.
My IDE is 1.8.16
what can be the problem?
Run the I2C scanner to see if the unit is detected, and at what address.
thanks for the answer
I used this: https://create.arduino.cc/projecthub/abdularbi17/how-to-scan-i2c-address-in-arduino-eaadda
for the I2C scanner and its says "No I2C devices found"
OK, post a picture of your wiring, and the soldering of the wires or headers on the breakout.
The ADXL345 is a 3.3V part. Where are the 5V to 3.3V level shifters on SDA and SCL?
sorry I didn't get it, what parts?
I connected it directly to the 5V, that's bad?
Well, it's not good.
The Adafruit board can be config'd for 3V/5V, but this one hasn't that capacity.
https://learn.adafruit.com/adxl345-digital-accelerometer/downloads
The ADXL345 will be destroyed if the SDA and SCL inputs are connected to 5V output signals.
Use a level shifter (some sensor boards have them built in, yours does not), or connect the sensor directly to a 3.3V Arduino.
thanks for the replies
so you think the ADXL345 is burnt out? there is something I can do?
The only way to tell is to wire it CORRECTLY, and hope that it survived the abuse.
Or just buy a new one, and wire that one correctly.
Or
buy the adafruit unit (linked previously).
system
Closed
May 11, 2022, 4:55pm
13
