Thank you for your answers.
Since I've set SoftwareSerial at 9600 and double-check the wirings, the non-blinking LED (no satellite connection) is a problem of mine. I just don't understand why via u-center it established connection and with Arduino don't.
I've tried by the time all codes I've find in both interier and exterier enviroment.
Does the module establish the connection automaticly when powered?
Upon power up, the module does what you program it to do via u-center.
Evidently, you have not read the u-center documentation, as that explains how to set up the module to output ASCII NMEA sentences of the type you need.
I've read u-center's User Guide but it just tell me how to pick up something, not what to pick up.
If I open Messages uder Confuguration View, I can see here NMEA GxGLL, GxGSA, GxGLL, etc.... and I don't know which one I need.
The same situation with GNSS Config. There's nothing selected but I don't know how much channels I need for GPS, Galileo, GLONASS, etc...
I haven't find it in any documation.
Then why did you buy THAT module?
To test that the Arduino can get data from the GPS, it doesn't matter which one you pick. Close your eyes and stab at one of them.
First initialize the module to "factory default". Then make sure that output is set to NMEA ASCII, at 9600 baud. You can go higher, but all programs have to agree on the baud rate.
You need the $GPRMC sentence at minimum. That will allow you to get your position, speed and course using either a terminal program on a PC (with a serial adapter) or the Arduino -- IF the module has a clear view of the sky and a valid satellite fix.
It may be that your particular module does not allow you to select which type of NMEA sentences it outputs (some do).
It might also be a power supply issue. Connect the GPS module to a stable +5V DC supply. Soon it should get a satellite fix, and the green LED should start flashing.
Now connect the module to your Arduino, but only +5V and GND. If the Arduino can supply a stable +5V to the module, it should get a satellite fix, and the green LED should start flashing. If the module gets a satellite fix, you can again connect the TX and RX pins, and everything should work now.
If not, your Arduino might not be able to supply enough power to the module.
On my Arduino Pro Mini, which, admittedly, is only powered via the USB to serial converter, the GPS module only seems to work sporadically. But, as soon as I connect the module to an external, stable +5V DC supply, it works every time ![]()
@jirakst: have you made and progress?
Here is another example/tutorial that also explains how to change the baud rate on the GPS module
@Kenjutsu I had the exact same problem as de OP (@jirakst) and I did as you said in your comment:
Kenjutsu:
It might also be a power supply issue. Connect the GPS module to a stable +5V DC supply. Soon it should get a satellite fix, and the green LED should start flashing.Now connect the module to your Arduino, but only +5V and GND. If the Arduino can supply a stable +5V to the module, it should get a satellite fix, and the green LED should start flashing. If the module gets a satellite fix, you can again connect the TX and RX pins, and everything should work now.
And it worked perfectly!! Problem solved. All I did was connect the GPS module to +5V DC supply instead of 3.3V, waited about 30s and voilà, the GPS started blink in red every 1s and started to transmit all the NMEA information exactly as it should.
I know that it's been a long time since @jirakst abandoned topic, but I'm here to tell you that it worked for me your solution.
Thank you very much, you helped a lot!! Have a nice day! ![]()
