No data on Serial Monitor from UHF RFID (R16-7DB) via RS232 to TTL on ESP32
Hi! It's been days that I'm trying to figure out to connect a UHF RFID reader (R16-7DB) to my ESP32 using an RS232 to TTL converter (MX3232). I'm using GPIO16 (RX2) of the ESP32 for reading, and I’ve connected:
  • VCC of the converter to 3.3V of ESP32
  • GND to GND
  • TXD of the converter to GPIO16
The reader blinks when reading, but I’m not seeing any data on the serial monitor, and I assure that baud rates are correct. Also I only got this output when I click the en button:
19:50:44.581 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
19:50:44.581 -> configsip: 0, SPIWP:0xee
19:50:44.581 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
19:50:44.626 -> mode:DIO, clock div:1
19:50:44.626 -> load:0x3fff0030,len:4888
19:50:44.626 -> load:0x40078000,len:16516
19:50:44.626 -> load:0x40080400,len:4
19:50:44.626 -> load:0x40080404,len:3476
19:50:44.626 -> entry 0x400805b4
19:50:44.737 -> ESP32 RFID Reader Test (Read Only)
19:50:44.737 -> 0x00
Any ideas why this happens or what I might be missing? Im beginner on this so your responses are much appreciated, Thanks in advance!
Are you sure of that? Converter is just translator, not serial device. If I needed to guess, I would connect RX to RX. Does the pin have some arrow for direction printed?
Are those messages correct? Do they indicate an error? Is your unknown program actually reading something that tells you a tag has been read?
Does your tag reader function when using the PC sample program?
