No matching function for call to 'HardwareSerial::println(FirebaseJsonData&)'
i was trying firebase test for ESP32 in arduinoIDE,and prolem occur in here,my arduinoJson was not matching(i think i have to install arduinoJson library),but ive already install it.
rduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "WEMOS LOLIN32, 80MHz, Default, 80MHz (WiFi/BT), 115200"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\ridho\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\ridho\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\ridho\Documents\Arduino\libraries -fqbn=esp32:esp32:lolin32:FlashFreq=80,PartitionScheme=default,CPUFreq=80,UploadSpeed=115200 -ide-version=10815 -build-path C:\Users\ridho\AppData\Local\Temp\arduino_build_478861 -warnings=none -build-cache C:\Users\ridho\AppData\Local\Temp\arduino_cache_51041 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\ridho\Documents\Arduino\sppa\sppa.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\ridho\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\ridho\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\ridho\Documents\Arduino\libraries -fqbn=esp32:esp32:lolin32:FlashFreq=80,PartitionScheme=default,CPUFreq=80,UploadSpeed=115200 -ide-version=10815 -build-path C:\Users\ridho\AppData\Local\Temp\arduino_build_478861 -warnings=none -build-cache C:\Users\ridho\AppData\Local\Temp\arduino_cache_51041 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\ridho\Documents\Arduino\sppa\sppa.ino
Using board 'lolin32' from platform in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\Users\ridho\Documents\Arduino\sppa\partitions.csv" copy /y "C:\Users\ridho\Documents\Arduino\sppa\partitions.csv" "C:\Users\ridho\AppData\Local\Temp\arduino_build_478861\partitions.csv"
cmd /c if not exist "C:\Users\ridho\AppData\Local\Temp\arduino_build_478861\partitions.csv" copy "C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\tools\partitions\default.csv" "C:\Users\ridho\AppData\Local\Temp\arduino_build_478861\partitions.csv"
    1 file(s) copied.
Detecting libraries used...
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="LOLIN32"" "-DARDUINO_VARIANT="lolin32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\lolin32" "C:\Users\ridho\AppData\Local\Temp\arduino_build_478861\sketch\sppa.ino.cpp" -o nul
Alternatives for WiFi.h: [WiFi@1.2.7 WiFi@1.0]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@1.2.7 WiFi@1.0]
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="LOLIN32"" "-DARDUINO_VARIANT="lolin32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\lolin32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src" "C:\Users\ridho\AppData\Local\Temp\arduino_build_478861\sketch\sppa.ino.cpp" -o nul
Alternatives for FirebaseESP32.h: [Firebase_ESP32_Client@3.9.7]
ResolveLibrary(FirebaseESP32.h)
-> candidates: [Firebase_ESP32_Client@3.9.7]
"C:\Users\ridho\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10815 -DARDUINO_LOLIN32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="LOLIN32"" "-DARDUINO_VARIANT="lolin32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\variants\lolin32" "-IC:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src" "-IC:\Users\ridho\Documents\Arduino\libraries\Firebase_ESP32_Client\src" "C:\Users\ridho\AppData\Local\Temp\arduino_build_478861\sketch\sppa.ino.cpp" -o nul
Multiple libraries were found for "SD.h"
Used: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SD
Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries\SD
Multiple libraries were found for "WiFi.h"
Used: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries\WiFi
Using library WiFi at version 1.0 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Using library Firebase_ESP32_Client at version 3.9.7 in folder: C:\Users\ridho\Documents\Arduino\libraries\Firebase_ESP32_Client
Using library SPI at version 1.0 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPI
Using library FS at version 1.0 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\FS
Using library SPIFFS at version 1.0 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SPIFFS
Using library SD at version 1.0.5 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\SD
Using library WiFiClientSecure at version 1.0 in folder: C:\Users\ridho\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\WiFiClientSecure
exit status 1
no matching function for call to 'HardwareSerial::println(FirebaseJsonData&)'
@ridhoazhar313 Why do users choose to ignore the advice on posting code ?
The easier you make it to read and copy your code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
If you get errors when compiling please copy them from the IDE using the "Copy error messages" button and paste the clipboard here in code tags
Do not post pictures of code and error message
ive been add error massage while compiling code,thanks
Did you deliberately ignore the advice to use code tags when posting error messages ? It really does make them easier to deal with
