No matching function to call for HttpClien
Hello,
Please could somebody explain to me why i get the error “no matching function to call for HttpClient::HttpClient()” (when compiling)
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266HTTPClient.h>
#include "DHT.h"
// WiFi settings
const char* ssid = "Septa";
const char* password = "aezakmi10";
#define DHTPIN 2     // Digital pin connected to the DHT sensor
//Azure IoT Hub
const String AzureIoTHubURI="IoTHub Host name";
//openssl s_client -servername myioteventhub.azure-devices.net -connect myioteventhub.azure-devices.net:443 | openssl x509 -fingerprint -noout //
const String AzureIoTHubFingerPrint="Your Finger print";
//az iot hub generate-sas-token --device-id {YourIoTDeviceId} --hub-name {YourIoTHubName}
const String AzureIoTHubAuth="your Sas`Preformatted text`";
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
  Serial.println(F("DHTxx test!"));
  dht.begin();
  // Init serial line
 // Serial.begin(115200);
  Serial.println("ESP8266 starting in normal mode");
  // Connect to WiFi
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Print the IP address
  // Wait a few seconds between measurements.
  delay(5000);
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print(F("Humidity: "));
  Serial.print(h);
  Serial.print(F("%  Temperature: "));
  Serial.print(t);
  Serial.print(F("°C "));
  Serial.print(f);
  Serial.print(F("°F  Heat index: "));
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(F("°F"));
  String PostData="{ \"DeviceId\":\"ESP8266-0001\",\"Temperature\":"+String(t)+",\"Humidity\":"+String(h)+"}";
      Serial.println(PostData);
      // Send data to cloud
      int returnCode=RestPostData(AzureIoTHubURI,AzureIoTHubFingerPrint,AzureIoTHubAuth,PostData);
      Serial.println(returnCode);
// Functions
int RestPostData(String URI, String fingerPrint, String Authorization, String PostData)
    HTTPClient http;
    http.begin(URI,fingerPrint);
    http.addHeader("Authorization",Authorization);
    http.addHeader("Content-Type", "application/atom+xml;type=entry;charset=utf-8");
    int returnCode=http.POST(PostData);
    if(returnCode<0)
    Serial.println("RestPostData: Error sending data: "+String(http.errorToString(returnCode).c_str()));
    http.end();
  return returnCode;
the constructor of HTTPClient is changed. now it requires WiFiClient or WiFiClientSecure object as first parameter. see the examples of the ESP8266HTTPClient library
