Hello,
Please could somebody explain to me why i get the error "no matching function to call for HttpClient::HttpClient()" (when compiling)
Perhaps it's because the EthernetClient is also named as client. if somebody could explain to me what I need to understand to get through this problem it would be much appreciated.
#include <Ethernet.h>
#include <HttpClient.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 68);
EthernetClient client;
// Start Ehternet
Ethernet.begin(mac,ip);
// client.connect();
// Start Serial Port
// Check Ethernet
Serial.println("Setup...");
Serial.println("ip is: ");
Serial.println(Ethernet.localIP());
Serial.println("DNS is: ");
Serial.println(Ethernet.dnsServerIP());
Serial.println("Ethernet Hardward Status is: ");
if (Ethernet.hardwareStatus() == 1) {
Serial.println("W5100 Ethernet controller detected.");
// Initialize the client library
HttpClient client;
// Make a HTTP request:
client.get("http://www.arduino.cc/asciilogo.txt");
// if there are incoming bytes available from the server, read them and print them:
while (client.available()) {
char c = client.read();
Serial.print(c);
Serial.flush();
delay(5000);
Here is the error in full.
I was basing this on an example called HTTP Client. I will check out the other examples, but they seem more complex so i was hoping to begin with this one.
Thank you.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
C:\Users\simon\Auduino_Sketches\TEMP\sketch_dec28a\sketch_dec28a.ino: In function 'void loop()':
sketch_dec28a:38:14: error: no matching function for call to 'HttpClient::HttpClient()'
HttpClient client;
In file included from C:\Users\simon\Auduino_Sketches\TEMP\sketch_dec28a\sketch_dec28a.ino:1:0:
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:50:5: note: candidate: HttpClient::HttpClient(Client&)
HttpClient(Client& aClient);
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:50:5: note: candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:37:7: note: candidate: constexpr HttpClient::HttpClient(const HttpClient&)
class HttpClient : public Client
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:37:7: note: candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:37:7: note: candidate: constexpr HttpClient::HttpClient(HttpClient&&)
sketch_dec28a:41:51: error: no matching function for call to 'HttpClient::get(const char [36])'
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:74:9: note: candidate: int HttpClient::get(const char*, uint16_t, const char*, const char*)
int get(const char* aServerName, uint16_t aServerPort, const char* aURLPath,
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:74:9: note: candidate expects 4 arguments, 1 provided
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:86:9: note: candidate: int HttpClient::get(const char*, const char*, const char*)
int get(const char* aServerName, const char* aURLPath, const char* aUserAgent =NULL)
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:86:9: note: candidate expects 3 arguments, 1 provided
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:100:9: note: candidate: int HttpClient::get(const IPAddress&, const char*, uint16_t, const char*, const char*)
int get(const IPAddress& aServerAddress,
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:100:9: note: candidate expects 5 arguments, 1 provided
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:117:9: note: candidate: int HttpClient::get(const IPAddress&, const char*, const char*, const char*)
C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0/HttpClient.h:117:9: note: candidate expects 4 arguments, 1 provided
Multiple libraries were found for "HttpClient.h"
Used: C:\Program Files (x86)\Arduino\libraries\HttpClientt-2.2.0
Not used: C:\Program Files (x86)\Arduino\libraries\Bridge
exit status 1
option enabled in File -> Preferences.
Your compiler believes that you are using an HttpClient class which does not have an empty constructor.
It tells you it expects one parameter HttpClient::HttpClient(Client&)==>cf comment #1
clarify which library you are trying to use please
is it likely that more than one library exists with the name HttpClient? Perhaps that's obvious, but I have been assuming that all libraries with a given name would behave the same...
