No mosfets to control fans?
Hello, Normally I use a N-channel But I ran out of them and I do not have any P-channel either. I have 2 of the 12v fans 3w 3pin fans. Is there anything else I can use to control the fan itself? I need to control two of them but they do not need to be connected together to be controlled together in arduino.
Joseph
If PWM is "0" then aren't they Off?
Define control?
Turn ON and OFF?
OR
Control Speed?
Tom... :grinning: :+1: :coffee: :australia:
Use the fire fighting aids and calm down from the panic..
Read this link to understand what forum helpers prefer.
Link: Arduino Forum
I'm sorry let me rephrase this question. I need to control two fans that are 3Pin using PWM. Normally I use a N-Channel mosfet. But for some odd reason I ran out of them. And I tried to see If i have any P-channel mosfets but I do not have any of them either. I'm looking for something to replace with so I can Pwm fan speeds to make them go high or low speed. These fans are 3watts each at 12v.
Joseph
The 3rd pin is PWM input, isn't it?
Don't they stop with 0% Duty?
Hello, No it is a tackometer to read the speed of the fan not for controlling the fan.
Joseph
Well, in that event, it's not happening without a transistor.
Forget about using P channel MOSFETs for 12 volt and 5/3.3 volt controllers. Transistors are needed.
Buy logic N channel MOSFETa.
Only tansistors I have currently at the moment are the 2n222 transistors.
Joseph
2N2222 should work as low side switch don't forget kickback diode in parallel with fan.
2n222 I do have.
Joseph
Which Arduino, you may need 20mA base current.
I'm using the arduino zero board. which has a 3.3v logic level.
Joseph
I doubt that would work, not enough output pin current, how about a Darlington like TIP120?
Nothing else I have at the moment. I can not order anything either for a while.
Joseph
Any opto couplers like PC817?
Matter a fact I do. 3 of them.
Joseph
Maybe;
MCU output to opto input through 390 or 470Ω resistor(about 5mA), Opto collector to +12V through 390 or 470Ω, opto emitter to 2N2222 base (about 25mA)?
I can give it a try I do have them resistors values. I hope I don't let the smoke out. I need to look online for the collectors and emitters I do not know which one are they for the opto and the 2n222. I hope I can draw this out before I try it. Thank you
Joseph
