No new device appears for UNO R4 on Linux
Hello,
I bought a Uno R4 WiFi and when I connect it on my laptop no new devices appears in /dev folder.
dmesg shows me a new device detected.
I checked of "60-arduino-renesas.rules" in "/dev/udev/rules.d" and it is present.
However, when I connect the Uno R4 WiFi no new device appears.
Has anyone already face to this problem ?
Many thanks in advance
Thoma
Sounds like you are not a member of dialout. Try this:
Type 'groups', is 'dialout' there ?
sudo usermod -a -G tty yourUserName - sudo usermod -a -G tty gil
(gil is my user name)
sudo usermod -a -G dialout yourUserName
Log off and log on again for the changes to take effect.
The last step is most important!
I use an Arch Linux and the user is member of uucp.
As mentioned previously, neither /dev/ttyUSB0 nor /dev/ttyACM0 are created when I plug in the Uno R4 WiFI.
Still, I update the udev rules.
So, I suppose something is wrong on udev side in my opinion.
Run sudo dmesg -Hw and then plug in the Arduino. Report back with the output that is printed after plugging it in (if any).
Hello Pieter,
Here the lines that appears when connecting the Uno R4 WiFi:
[25juil. 21:30] usb 3-1.1: new full-speed USB device number 17 using xhci_hcd
[ +0,133878] usb 3-1.1: New USB device found, idVendor=2341, idProduct=1002, bcdDevice= 1.00
[ +0,000019] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0,000004] usb 3-1.1: Product: UNO WiFi R4 CMSIS-DAP
[ +0,000003] usb 3-1.1: Manufacturer: Arduino
[ +0,000003] usb 3-1.1: SerialNumber: 64E8335DF614
[ +0,131447] hid-generic 0003:2341:1002.001B: hiddev96,hidraw0: USB HID v1.11 Device [Arduino UNO WiFi R4 CMSIS-DAP] on usb-0000:73:00.4-1.1/input0
I think you should be able to flash the R4. Serial might show up with a sketch including Serial.begin(...).
Did you reload the udev rules or rebooted you PC?
Hello Rintin,
I found the origin of my problem: kernel version and driver version was not the same.
This was due to a recent system update including a kernel update.
I forgot to reboot the machine.
Thanks for your help
