No output to serial monitor
I tried a very basic sketch but nothing is output to the serial monitor. This is in the IDE. Any idea.
Serial.println("test");
Please post the complete sketch.
The bare minimum sketch can be found in your IDE here:
IDE >> EXAMPLES >> 01. BASICS >> BARE MINIMUM
And here:
https://docs.arduino.cc/built-in-examples/basics/BareMinimum/
Try to add "while (!Serial);" after "Serial.begin(9600);"
Also make sure the baudrate on the serial monitor is set to 9600
regards
Paul
#include <ArduinoBLE.h>
while (!Serial)
// begin initialization
if (!BLE.begin()) {
Serial.println("starting Bluetooth® Low Energy module failed!");
while (1)
Serial.println("Bluetooth® Low Energy Central - Peripheral Explorer");
// start scanning for peripherals
BLE.scan();
What is this code ?
If you put "while(1);" with the semi-colon right after, it will loop for ever and nothing will happen. !
Next to that it is inside a check that BLE.begin() failed??
I found the issue. I was using the IDE and the Arduino create agent was running. I closed the agent and serial started to work.
