My nodemcu32s is not recognised by arduino ide. Not even ports. I tried two cables and two pcs at one pc i hear the sound when a usb connects but only in device manager not in arduino ide. Mega 2560 is recognised though from the same port. What should i do? The red light lights up too it gets power so?
please help its an emergency
hers some pics too. first picture mega is automatically selected as a arduino mega board and its com port is deiscovered. pic two i manually chose the board and no ports come up.
Hi @marinochungus.
OK, this is useful information.
Please try this troubleshooting procedure and then report your results in a reply on this forum thread:
This procedure is not intended to solve the problem. The purpose is to gather more information.
- Open the Windows Device Manager.
- Select View > Devices by type from the Device Manager menus.
- Open the "View" menu.
- If there is a ✓ to the left of the "Show hidden devices" menu item, click on "Show hidden devices" to disable it.
- Disconnect the USB cable of the Arduino board from your computer.
- Take note of the contents of the "Other devices" and "Ports (COM & LPT)" sections of the Device Manager tree.
- Connect the Arduino board to your computer with a USB cable.
- Select Action > Scan for hardware changes" from the Device Manager menus.
Did you see any new device appear in the Device Manager tree after doing this? If so, please tell us where it is located in the tree and what it is named.
You can repeat steps 5-8 multiple times if you are not sure.
first pic is after unlpugging it second is when i plug it in so it recognises it
imma try now and let you know
no nothing but when i enable hidden stuff i see more things on other devices
btw it says that no drivers for this device exist
all i wanted was to program a esp 01 using the nodemcu but i cant even do this thing
OK, it looks like you will be able to solve the problem by installing the driver for the Silicon Labs CP2102 USB to serial bridge chip on your board.
You can get the driver from the chip manufacturer's website here:
thanks i will let you know if it works but can i program an esp 01 using the nodemcu32s?
what do i do with it? do i have to open it?
it worked thanks so much
You are welcome. I'm glad it is working now.
Regards,
Per
