I got a question about externally powering my NodeMCU V3. It has an onboard voltage regulator (3v3) which breaks out to 3 header pins. Now I want to power 3v3 from an external board. Can I supply 3v3 to all of those pins at the same time? (Basically connected in parallel).
Anyone has done this before or has this experience with NodeMCU V3?
rmvansomeren:
So it does!
rmvansomeren:
Why would you want to connect to more than one pin?
Also, why would you want to use a NodeMCU if you are going to provide a separate 3.3 V supply? An ESP-12 and adapter board would do the same job, though you would have to use an adapter to program it.
