Sorry for the experts - I'm a layman on the subject!
I downloaded the "ESP8266_TFT_SPIFFS" sketch by Bodmer and would like to use it on ESP8266 Nodemcu; inside the folder there are 3 files '.ino' and 1 folder 'data' with 3 figures inside. Which file '.ino' should I upload and what do I do with the 'data' folder?
Another thing: can I put more pictures inside the 'data' folder? (approximately how many, for a ESP8266)?
Please confirm that you have run all of Bodmer's other examples successfully.
Instructions for copying data files from your project folder into SPIFFS are in the links.
You can always copy a modified example into your User sketch directory. The IDE will do it for you. The IDE will not let you save a modified example in the examples folders.
Get the example running first.
Save the example in your User space
Add or remove files to the sketch data directory
Follow the procedure to transfer the data to SPIFFS
You can reserve 1M or 3M for SPIFFS.
You can get lots of .JPG images in 3M especially if you use some compression.
You can observe the picture quality when you compress JPG in Irfanview on your PC.
.BMP files waste a lot of space. You can only fit two 320x480 .BMP in 1M
Make notes on paper as you go. The SPIFFS procedure is a little fiddly. Manipulating images on your PC is a lot to learn.
Ask if you have a problem.
Oh. If you have mulltiple .INO files in a sketch directory, the "main" .INO is the one that has the same name as the directory.
.INO files are concatenated when Arduino mangles them into a valid .CPP file.
A single .INO file will find library headers and create forward references very well.
Concatenated .INOs do not manage references perfectly.
I suggest that you obey .CPP rules when writing multiple .INO files
david_prentice:
If you asked your question wisely, you would say Adafruit_ILI9341
Adafruit_ILI9341 has an example for 24-bit .BMP files
Adafruit has an example (Adafriuit imagereader) to load the file from the SD card only, if I'm not mistaken. And there is no option to load it from the SPIFFS. And, actually, there is not so much difference what library is used, The only thing, that is used from the library is preparing the display area for the image: tft.setAddrWindow().
Dancopy:
Thank you
David already answered you. I will just add some clarification.
Here is a video instruction how lo upload the files into SPIFFS of NodeMCU(ESP8266): https://www.youtube.com/watch?v=25eLIdLKgHs.
To get the Bodmer's examples running, you need to upload his bitmaps from the data folder to the SPIFFS of yours ESP8266 MCU.
The main sketch file is ESP8266_draw_565_image2.ino. The functions.ino files should be in the same folder as they contain functions, that are used in the main sketch.
If you want to upload your own files, you need to prepare them in the RGB565 (16-bit bmp) format without a header (follow the link, I've provided earlier). Such a file for the 240320 resolution will consume 153600 bytes (2403202(2 bytes = 16 bit)) .
My sincere thanks to David and Shur1k who gave me details;
I was able to install the program and recorded two images in SPIFFS of ESP (EagleEye and Tiger) but, what is that figure 'TigerDue'?
If you have any more patience with me, I have a few more questions:
I do not understand why the two images are in .raw extension and not jpg?
When I download or save more images, it should be in what format? .raw or jpg? And should it have resolutions 320x240 or 240x320 or still 240x240?
Another thing: I recorded the two images, EagleEye and Tiger, so let's say I want to record 5 more images; will the two images already recorded be overwritten or remain in ESP SPIFFS memory?
How to erase all SPIFFS images from ESP?
Does this sketch work with Display 3.5 inch 480*320 ILI9488 or even with screens as large as 5 inches? Would be great! (my opinion)
I believe, that TigerDue image is for loading specifically to Arduino Due compatable boards. But I'm 100% sure. Al least, this is not the raw image, it's a nitmap with a header of 54 bytes length.
Cause they are not the jpg files, they contain a raw image data (the sequence of the bytes for each pixel of the image, each pixel is represented by two bytes - 16 bit in a fornat 565 (5 for red, 6 for green and 5 for blue) ) 2) they should be in a raw format - a 16 bit 565 bitmap image without a header. You can you this link Rinky-Dink Electronics to convert your images into the needed format. The resolution depends on your tft screen resolution and orientation. The Bodmers original files are for the 240*320 resolution (tft.setOrientation(0/2) 0 or 2 - the portret mode, 1 or 3 - the landscape mode).
All the files from the data folder of the sketch are written to the SPIFFS each time, when you upload them,. Everything, that was there before, is cleared.
Why do you need it? Just upload the files, you need and that's all. Don't forget to set up in Arduino IDE, that you are using SPIFFS, you can use from 0 to 3 Mb of the ESP flash memory for SPIFFS.
I didn't use the sketch as it was, I've just used the drawRAW function in my sketch. But it should work, I think. You will just have the image on the part of your screen.
Hope it'll help you.
Cheers
P.S. Forgot to mention, that I needed to modify a bit Bodmer's function to make it works.
The TFT screen chip select pin should be low before transfering the image data by the SPI bus. Maybe Bodmer did it in the main sketch, I don't know, but I've added it into the function before settting up the TFT address window:
digitalWrite(TFT_CS, LOW);
And I've changed the settings of the address window itself:
it was tft.setAddrWindow(x, y, x + rawWidth - 1, y + rawHeight -1 );
I don't know, why Bodmer set the window less then the image, I had an incorrect displaying of the image with such settings.
So, I've changed it to: tft.setAddrWindow(x, y, x + rawWidth, y + rawHeight); And after that the image was loaded correctly.
Thanks David for your reply;
I want to repeat here the question (5) I did earlier: Does this sketch work with Display 3.5 inch 480*320 ILI9488 (Breakout)?
In fact, I would like to do with a larger screen, such as 5 inches; thanks again
Firstly, thank you all for the help but, there is a problem:
The two image files that come in the original Bodmer code, are written correctly in SPIFFS and show on the screen (without having to make the changes that friend 'shur1k' mentioned);
So I used the Bodmer Tool for Conversion (ImageConverter (UTFT) and converted an image (320*240) 'jpg' to '.raw' and put it inside the 'data' folder and proceeded with the loading in function 'ESP8266 Sketch Data Upload '; it loaded normally but the image I added on the screen does not appear, only the two images that originally came in the 'data' folder.
I want to remember here that what I'm using as Flash Size "4M (3M SPIFFS)", so I do not know what I'm wrong; it is more likely to be in the loaded image type.
I really want to buy Screen 3.5" ILI9488 to use with that but, I'm afraid!
Would any of you, please, have some .raw format images for me to take a test?
PS. After loading with the 'ESP8266 Sketch Data Upload' function, should I load the sketch through the function (arrow) Load? (not!)
240x320 .JPG when compressed can fit in less than 32768 bytes.
Bodmer's "parrot.bmp" is only 128x160 but uses 60kB of disk space
Bodmer's "baboon40.jpg" is 320x480 but uses 24kB of disk space
Bodmer's "mouse480.jpg" is 480x320 but uses 7kB of disk
You can view these images on your PC. Navigate the libraries folder with Windows Explorer. Hover on the file to see dimensions and size. Click on file to view on the PC.
You can take any image from the Internet or your PC and process it in IrfanView.
e.g. resize it to suit your TFT e.g. 240x320 or 320x480 or ...
The full-fat image takes a lot of bytes e.g. width x height x 3.
e.g. store in .JPG format with different "compression quality" ratios.
"baboon.jpg" looks pretty good. Even though it has been compressed from 450.04kB down to 23.81kB (quality=40)
"mouse.jpg" is recognisable but fairly crap. It has been compressed from 450.04kB down to 6.45kB (quality=20)
Think about it. If you have a 1MB SPIFFS, you can store over 30 baboon JPEGs. But only 2 .BMP files. (Or 3 RAW files)
If your images compess "well" you can store many more .JPGs. Or different .JPGs with different compression quality. You can see what it looks like on the PC. Quality=90 still gives a reasonable file size.
Just do your Image preparation on the PC. Then copy to the sketch Data directory so you can upload to SPIFFS.
Hi Bodmer! I tried to attach all the files with .RAR here but it gives an error. I also tried to attach all .raw and also gave error. So I'm sending separately. Thank you
I think that this illustrates my point. The pictures are compressed.
dog.jpg 284x177 quality=94
flower3.jpg 320x240 quality=94
flower4.jpg 320x240 quality=94
penguins.jpg 320x240 quality=94
You could probably get away with lower quality. But 30kB is a reasonable size for storage in SPIFFS.
Hi David, thanks for your help.
Incredibly, the only code that saves and runs correctly on my Nodemcu is the original sketch by Bodmer, which comes with the 3 images in the 'data' folder (EagleEye, Tiger and TigerDue). It seems that whoever does all the magic is the 'TigerDue' figure. I can not understand. I put the images from the folder JPEGS.zip that you sent me, in the folder 'data' but it did not work; I converted those same images to .raw with the ImageConverter565 tool, but it did not work either.
I will make a request: if you or 'Bodmer' or 'shur1k' do not bother, send me here through the forum, all files mounted, with several images (10 or 15), as the original Bodmer file (ESP8266_TFT_SPIFFS. zip) on page 1, for me to do my last test.
I'm doing this: click on Tools > ESP8266 Sketch Data Upload and, after loading the images in SPIFFS, I load (Ctrl + U) the sketch.
I can not believe it's the size of the images I'm using.
Once again, my thanks to all.
david_prentice: @shurlk,
setAddrWindow() takes start and end addresses. Hence the -1
Thank you, David. You are completely right. There should be -1, my bad. Will try to sort out the code.
Dancopy:
Dancopy, was your image landscape (320240) or portrait (240230)? Have you set the correct screen orientation? What were the parameters of the drawRaw() function for your image?
The original images were loaded like this:
// Plot at x,y = 0,0 an image 240 pixels wide and 320 pixels high.
drawRaw("/Tiger.raw", 0, 0, 240, 320);
delay(2000); // Hang around for a while
tft.fillScreen(random(0xFFFF));
drawRaw("/EagleEye.raw", 0, 30, 240, 240);
