Hello,
I just dive into arduino/nodemcu/esp8266/etc.
, so please let me know if there is anything wrong with how I made this post.
Here is my project and my issue:
Project: water tank level with ultrasonic sensor (US-100) + nodeMCU + battery powered. (My end goal is to have the nodeMCU sending a MQTT message), see code snippet at the end (please, also let me know if I can improve the code).
So far, everything is working as expected, device wakes up -> wifi connection -> mqtt connection -> get sensor value -> send mqtt message -> deep sleep.
My problem is: if SLEEP_DURATION is too long (> ~30min) the device won't wake up. If SLEEP_DURATION is less than 30 min, then everything is working fine. And I don't know what is wrong. (I have RST directly wired to D0).
Does anybody have any idea ?
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#define NB_TRYWIFI 5
#define SLEEP_DURATION 1000000 * 60 * 45
const char* wifi_ssid = "wifi_ssid";
const char* wifi_password = "wifi_pass";
IPAddress local_ip(10, 0, 5, 1);
IPAddress gateway(10, 0, 0, 1);
IPAddress subnet(255, 0, 0, 0);
IPAddress primary_dns(10, 0, 0, 1);
const char* mqtt_server = "10.0.1.2";
const int mqtt_port = 1883;
const char* mqtt_password = "mqtt_passw";
const char* mqtt_user = "mqtt_user";
const int US_100_ECHO = D2;
const int US_100_TRIG = D1;
WiFiClient espClient;
PubSubClient mqtt_client(espClient);
void sendMqttMessage(long distance, long analog){
char json[40];
if (mqttConnect()) {
Serial.println("Sending mqtt message");
sprintf(json, "{\"distance\": %d, \"analog\": %d}", distance, analog);
mqtt_client.publish("WaterTankLevel/info", json);
boolean mqttConnect() {
if (!mqtt_client.connected()) {
mqtt_client.setServer(mqtt_server, mqtt_port);
if (mqtt_client.connect("WaterTankLevel", mqtt_user, mqtt_password)) {
Serial.println("Connected to mqtt server");
return mqtt_client.connected();
Serial.println("Connection to mqtt server failed!");
return 0;
return 1;
boolean wifiConnect() {
WiFi.config(local_ip, gateway, subnet, primary_dns);
WiFi.begin(wifi_ssid, wifi_password);
Serial.println("Connecting to WiFi");
int _try = 0;
Serial.print(".");
_try++;
if ( _try >= NB_TRYWIFI ) {
Serial.println("Connection to wifi failed!");
return 0;
Serial.println("Connected to the WiFi");
return 1;
void sleep() {
Serial.println("Going to sleep");
ESP.deepSleep(SLEEP_DURATION);
void serialSetup() {
Serial.setTimeout(2000);
while(!Serial) { }
Serial.println("Waking up");
pinMode(US_100_ECHO, INPUT); // The set EchoPin input mode.
pinMode(US_100_TRIG, OUTPUT); // The set TrigPin output mode.
long readValue() {
unsigned long len_mm = -1;
unsigned long time_echo = 0;
int count = 0;
while (count < 10) {
Serial.println("Read value from ultrasonic sensor");
digitalWrite(US_100_TRIG, HIGH); // Send pulses begin by Trig / Pin
delayMicroseconds(50); // Set the pulse width of 50us (> 10us)
digitalWrite(US_100_TRIG, LOW); // The end of the pulse
time_echo = pulseIn(US_100_ECHO, HIGH); // A pulse width calculating US-100 returned
if((time_echo < 60000) && (time_echo > 1)) { // Pulse effective range (1, 60000).
len_mm = (time_echo * 34/100)/2; // Calculating the distance by a pulse width.
Serial.print("Present Distance is: "); // Output to the serial port monitor
Serial.print(len_mm, DEC); // Output to the serial port monitor
Serial.println("mm"); // Output to the serial port monitor
return len_mm;
count++;
return -1;
serialSetup();
boolean wifi_ok = wifiConnect();
if (wifi_ok) {
long value = readValue();
if (value > -1) {
sendMqttMessage(value, analogRead(A0));
Serial.println("Cannot get sensor value");
sleep();
Thanks for your help !
