hello im new with arduino i just want to know if it is possible to connect a mic on arduino and it as a noise sensor then when a noise is detected it will send a voice warning via speaker.. TIA
Yes, it is.
No. When you read an analog pin, with a microphone attached to it, you get a rather useless value. From that one value, you can not determine frequency, pitch, volume, or much of anything useful.
You can get that there was, or was not, sound. No sound corresponds to a very small value. But, you'll have an extremely difficult time correlating the reading you get with a volume, so a whisper is as good as a shout.
can i use this diagram to adjust the sensitivity of the my electret mic so that it can be a noise detector.. im planning on using it to our school's library
or im planning to use the schematic diagram which i get from
http://www.learningaboutelectronics.com/Articles/Sound-detector-circuit.php
you could buy a premade mic/amp - see 1713 Adafruit Industries LLC | Development Boards, Kits, Programmers | DigiKey
Allan.
@negative004, do not cross-post. Other thread removed.
sorry but how am i going to delete the 1st post?
Are you asking how to delete this thread?
Stop cross-posting.
