Nokia 6101
Hi
I need help with working example for Nokia LCD with controller SPFD54124B.
I tried Adafruit-SPFD54124B with arduino nano , but nothing displayed on the lcd. I checked the connection and everything seems Ok. I have only White back light but no data. Any suggestions or solutions appreciated.
Thank you.
PS: The lcd connected to its original phone pcb, only SDA, SCL, RST, CS rewired accordingly.
pin assigned as following:
#define RST 10
#define CS 9
SDA connected to pin 13, SCL connected to pin 11.
Change to
SDA connected to pin 11, SCL connected to pin 13.
David.
I swapped the pins but still no luck.
I found GitHub - fire0shadow/Adafruit-SPFD54124B: Connect Nokia 1616/C1-0x display to Arduino on GitHub.
It is not a genuine Adafruit library, but I am sure that it would work.
The example assumes a Uno / Nano with SDA on MOSI (11) and SCL on SCK (13):
#define TFT_CS    		10
#define TFT_RESET  		12
Personally, I would put TFT_RESET on a different pin e.g. 9
I have never used Nokia 6101. Nor know whether it has a SPFD54124B controller
David.
You didn't mention GND in your connections.
Connect Arduino GND with phone GND if you didn't already do that.
This topic was automatically closed after 92 days. New replies are no longer allowed.
