Non-functioning circuit
I have built a circuit on a breadboard containing an Arduino Nano, gyroscope and SD-card writer. On the breadboard it worked perfectly.
After that I have transferred the components to a protoboard and soldered them onto it. Since then the circuit does not work anymore: The gyroscope does not give an accurate readout (stays 0 degrees in all angles) and there is no data written to the SD-card.
On all wires a voltage of 4 to 5 volts could be measured.
Where does this go wrong?
Edit: It was my first time soldering onto a protoboard, if you got any tips, please let me know.
You do need some practice with soldering! Use your multimeter to check all connections for continuity, and also check for unwanted short circuits between neighboring connections.
I suggest to use smaller diameter wire, and protoboards similar to that pictured below, with connector strips so that you don't have to solder wires directly to pins.
Two things:
  • you should have used female header connectors to plug your modules into.
  • for point to point connections, you should have used 30AWG wire wrap wire.
This joint is not soldered. Add flux and re-heat (reflow)
It is good that you have used coloured cables , but the soldering is poor and you need practice .
Meanwhile you need to check through - it is easy to solder to the wrong pins when looking at the underside , and check for shorts between your soldered points .
Hello jw_dh
Visit the local "Makerspace" or the of local radio amateurs club to learn how to solder properly.
