Non-working example in default Nextion library
There is a standard example from the Nextion library for working with a button:
 * @example CompButton.ino
 * @par How to Use
 * This example shows that when the button component on the Nextion screen is released,
 * the text of this button will plus one every time.
 * @author  Wu Pengfei (email:<pengfei.wu@itead.cc>)
 * @date    2015/7/10
 * @updated 2016/12/25 bring HMI up to v0.32 to avoid too old issues
 * @convert by Patrick Martin, no other changes made
 * @copyright
 * Copyright (C) 2014-2015 ITEAD Intelligent Systems Co., Ltd. \n
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License as
 * published by the Free Software Foundation; either version 2 of
 * the License, or (at your option) any later version.
#include "Nextion.h"
 * Declare a button object [page id:0,component id:1, component name: "b0"].
NexButton b1 = NexButton(1, 4, "b1");
char buffer[100] = {0};
 * Register a button object to the touch event list.
NexTouch *nex_listen_list[] =
    &b1,
    NULL
 * Button component pop callback function.
 * In this example,the button's text value will plus one every time when it is released.
void b1PopCallback(void *ptr)
    uint16_t len;
    uint16_t number;
    NexButton *btn = (NexButton *)ptr;
    dbSerialPrintln("b0PopCallback");
    dbSerialPrint("ptr=");
    dbSerialPrintln((uint32_t)ptr);
    memset(buffer, 0, sizeof(buffer));
    /* Get the text value of button component [the value is string type]. */
    btn->getText(buffer, sizeof(buffer));
    number = atoi(buffer);
    number += 1;
    itoa(number, buffer, 10);
    /* Set the text value of button component [the value is string type]. */
    btn->setText(buffer);
void setup(void)
    /* Set the baudrate which is for debug and communicate with Nextion screen. */
    nexInit();
    /* Register the pop event callback function of the current button component. */
    b1.attachPop(b1PopCallback, &b1);
    dbSerialPrintln("setup done");
void loop(void)
     * When a pop or push event occured every time,
     * the corresponding component[right page id and component id] in touch event list will be asked.
    nexLoop(nex_listen_list);
I must say right away that my button is on page 2 (page1) (the button id and page number are indicated in the sketch correctly). After loading a sketch if you press button. you will get no reaction (everything is connected correctly).
In the Serial Port I can see this:
19:57:24.513 -> ⸮⸮⸮bkcmd=1⸮⸮⸮page 0⸮⸮⸮
It seems that there is no transition to the second page (page1). If so, what are the possible solutions? I was digging the Internet, but I didn’t find anything .. Thanks.
Feels more like a question for the Nextion forum...
What arduino are you running that on? What is connected where? (Including pin 0 and 1)
J-M-L:
Arduino UNO (lib edited for UNO), AM2320, RTC1307 (both SDA + SCL pins) and DS18B20 pin 9
How is that display connected?
If it's a software serial port, I would be suspcious that it's waiting for a reasponse, but because it was sending when the response was sent, and software serial is half-duplex, with the response being sent while it's still transmitting, and hence couldnt receive the response.
DrAzzy:
via Hardware Serial (RX 0 Pin TX 1pin)
Software Serial isnt working for me, I dont know why..
How do you get things go the serial monitor if the serial port is used by the display? Do you have a USB cable to the UNO and the serial monitor open?
J-M-L:
yes
andrwgldmn:
yes
you can't do that. The serial line is needed for your Screen, it can't be shared between the PC and the Screen
