I've only worked on Arduino one time before so I'm not very good at troubleshooting this code. This is someone else's code and so I've just been trying to fix it for my internship. I am currently using an Arduino Uno to make a cable tester which basically just checks if all 26 pins in our cables can cycle power. I keep getting an error saying:
Arduino: 1.6.11 (Windows 10), Board: "Arduino/Genuino Uno"
check_output:3: error: 'A10' was not declared in this scope
 LiquidCrystal lcd(A10,A11,A12,A13,A14,A15);
check_output:3: error: 'A11' was not declared in this scope
check_output:3: error: 'A12' was not declared in this scope
check_output:3: error: 'A13' was not declared in this scope
check_output:3: error: 'A14' was not declared in this scope
check_output:3: error: 'A15' was not declared in this scope
exit status 1
This is my code:
#include <LiquidCrystal.h>
  pinMode(0, OUTPUT);
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(14, OUTPUT);
  pinMode(15, OUTPUT);
  pinMode(16, OUTPUT);
  pinMode(17, OUTPUT);
  pinMode(18, OUTPUT);
  pinMode(19, OUTPUT);
  pinMode(20, OUTPUT);
  pinMode(21, OUTPUT);
  pinMode(22, OUTPUT);
  pinMode(23, OUTPUT);
  pinMode(24, OUTPUT);
  pinMode(25, OUTPUT);
  pinMode(28, INPUT);
  pinMode(29, INPUT);
  pinMode(30, INPUT);
  pinMode(31, INPUT);
  pinMode(32, INPUT);
  pinMode(33, INPUT);
  pinMode(34, INPUT);
  pinMode(35, INPUT);
  pinMode(36, INPUT);
  pinMode(37, INPUT);
  pinMode(38, INPUT);
  pinMode(39, INPUT);
  pinMode(40, INPUT);
  pinMode(41, INPUT);
  pinMode(42, INPUT);
  pinMode(43, INPUT);
  pinMode(44, INPUT);
  pinMode(45, INPUT);
  pinMode(46, INPUT);
  pinMode(47, INPUT);
  pinMode(48, INPUT);
  pinMode(49, INPUT);
  pinMode(50, INPUT);
  pinMode(51, INPUT);
  pinMode(52, INPUT);
  pinMode(53, INPUT);
lcd.begin(16,2);
lcd.setCursor(0,0);
lcd.print("Cable Test");
lcd.setCursor(0,1);
 int i=0, j=28,check_below=0, check_short=0, save_marker=0;
 while(i<=25&&j<=53)
  digitalWrite(i, HIGH);
  save_marker=j;
  for(int x=27; x<=53; x++)
    check_short=digitalRead(x);
    if(x!=save_marker&&check_short==HIGH)
      lcd.print("Failed:Short");
      continue;
  if(digitalRead(j)==HIGH)
    digitalWrite(i,LOW);
    i++;
    j++;
    if(i==26)
        lcd.print("Passed");
      continue;
    lcd.print( "FAILED:Continuity");
Would appreciate any kind of help of suggestions! Thank you in advance!
