#include <Servo.h>
#include <NewPing.h>
int IN1 = 8;
int IN2 = 9;
int IN3 = 10;
int IN4 = 11;
//sensor pins
#define trig_pin A1
#define echo_pin A0
#define maximum_distance 5
boolean goesForward = false;
int distance = 100;
NewPing sonar(trig_pin, echo_pin, maximum_distance) ;
Servo servo_motor;
pinMode(IN3, OUTPUT);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN4, OUTPUT);
servo_motor.attach(7);
servo_motor.write(115);
delay(2000);
distance = readPing()
delay(100);
delay(100);
delay(100);
delay(100);
int distanceRight = 0;
int distanceLeft = 0;
delay(50);
if (distance <= 20) {
moveStop();
delay(300);
moveBackward();
delay(400);
moveStop();
delay(300);
distanceRight = lookRight();
delay(300);
distanceLeft =lookLeft();
delay(300)
if (distance >= distanceLeft) {
turnRight();
moveStop();
else{
moveForward();
distance = readPing();
int lookRight() {
servo_motor.write(50);
int distance = readPing();
delay(100);
return distance;
int lookLeft(){
servo_motor.write(170);
delay(100);
return. distance;
delay(100);
int readPing() {
delay(70);
int cm = sonar.ping_cm();
if (cm==0) {
cm=250;
return cm;
void moveStop() {
digitalWrite(IN3, LOW);
digitalWrite(IN1, LOW);
digitalWrite(IN4, LOW);
digitalWrite(IN2, LOW);
void moveForward() {
if(!goesForward) {
goesForward=true;
digitalWrite(IN1, HIGH);
digitalWrite(IN3, HIGH);
void moveBackward() {
goesForward=false;
digitalWrite(IN2, HIGH);
digitalWrite(IN4, HIGH);
void turnRight() {
void turnLeft() {
Welcome to the forum, @syed_umer.
Please share the error you are getting, or tell us what is happening that should not, or isn't that should.
We not mind readers over here.
a7
Where is the brace at end of the loop() function ?
And this
delay(100);
delay(100);
delay(100);
Missing semicolons ?
and again
delay(300)
Once more, with feeling
Something different for a change
What is that full stop doing there ?
return. distance;
An old friend
Use tools -> autoformat and you will see what is wrong.
After autoformat, you can see that int lookRight() does not start at the beginng of a line. That indicates that something is wrong before that; as @UKHeliBob indicates, missing a } at the end of loop().
Function declarations / definitions should always start at the beginning of a line after an autoformat.
After you fix that, you will have one } too many at the end of your sketch.
Tools -> autoformat will also show you the missing semicolons mentioned above; e.g.
delay(300)
The additional indentation indicates that something is wrong.
Conclusion:
Always use tools -> autoformat to properly indent your code which in turn makes it easier to find issues.
the brace is at the end of the code. i fixed the semi colons but its still showing error
I am on macbook and there is no tools options showing for me, what can i do?
Show your fixed code.
If there are still two *}* at the end of the code, that is wrong.
This is for IDE2.0 on Windows, the Mac (regardless of IDE version) should show the same.
#include <Servo.h>
int IN1 = 8;
int IN2 = 9;
int IN3 = 10;
int IN4 = 11;
//sensor pins
#define trig_pin A1
#define echo_pin A0
int distance = 100;
Servo servo_motor;
delay(2000);
distance = readPing() ;
delay(100);
delay(100);
delay(100);
delay(100);
delay(50);
moveStop();
delay(300);
moveBackward();
delay(400);
moveStop();
delay(300);
delay(300);
delay(300);
turnRight();
moveStop();
else{
moveForward();
int lookRight() {
delay(100);
return distance;
int lookLeft(){
delay(100);
return distance;
delay(100);
int readPing() {
delay(70); }
if (cm==0) {
cm=250;
return cm;
void moveStop() {
if(!goesForward) {
goesForward=true;
goesForward=false;
void turnRight() {
void turnLeft() {
Where are the code tags ??
void turnLeft()
That last } does not belong there.
Other mistake
int readPing()
delay(70);
You're missing a } at the end of lookLeft(). And the } after delay(70) does not belong there.
Is it possible for you to correct all my mistakes and send it so i can test to see if it works? that would be a great help.
You have been given details of what is wrong. Why not fix them yourself ? If you still have problems afterwards then post your new code and the full error message here for more help
