I just got this gyroscope sensor Arduino Compatible 3-axis Gyroscope/Gyro Sensor Module
I followed this tutorial http://bildr.org/2011/06/l3g4200d-arduino/ , but I cannot get any data or response from the device.
I also ran the I2C Scanner and it didn't find any devices.
The connections are:
3.3v --- SDO , VCC, CS
A4 --- SCL
A5 --- SDA
GND --- GND
Here's the code I used:
#include<Wire.h>
#define CTRL_REG1 0x20
#define CTRL_REG2 0x21
#define CTRL_REG3 0x22
#define CTRL_REG4 0x23
#define CTRL_REG5 0x24
int L3G4200D_Address = 105; //I2C address of the L3G4200D
int x;
int y;
int z;
void setup(){
Wire.begin();
Serial.println("starting up L3G4200D");
setupL3G4200D(2000); // Configure L3G4200 – 250, 500 or 2000 deg/sec
delay(1500); //wait for the sensor to be ready
void loop(){
getGyroValues(); // This will update x, y, and z with new values
Serial.print("X:");
Serial.print(x);
Serial.print(" Y:");
Serial.print(y);
Serial.print(" Z:");
Serial.println(z);
delay(500); //Just here to slow down the serial to make it more readable
void getGyroValues(){
byte xMSB = readRegister(L3G4200D_Address, 0x29);
byte xLSB = readRegister(L3G4200D_Address, 0x28);
x = ((xMSB << 8) | xLSB);
byte yMSB = readRegister(L3G4200D_Address, 0x2B);
byte yLSB = readRegister(L3G4200D_Address, 0x2A);
y = ((yMSB << 8) | yLSB);
byte zMSB = readRegister(L3G4200D_Address, 0x2D);
byte zLSB = readRegister(L3G4200D_Address, 0x2C);
z = ((zMSB << 8) | zLSB);
int setupL3G4200D(int scale){ //From Jim Lindblom of Sparkfun's code
// Enable x, y, z and turn off power down:
writeRegister(L3G4200D_Address, CTRL_REG1, 0b00001111);
// If you'd like to adjust/use the HPF, you can edit the line below to configure CTRL_REG2:
writeRegister(L3G4200D_Address, CTRL_REG2, 0b00000000);
// Configure CTRL_REG3 to generate data ready interrupt on INT2
// No interrupts used on INT1, if you'd like to configure INT1
// or INT2 otherwise, consult the datasheet:
writeRegister(L3G4200D_Address, CTRL_REG3, 0b00001000);
// CTRL_REG4 controls the full-scale range, among other things:
if(scale == 250){
writeRegister(L3G4200D_Address, CTRL_REG4, 0b00000000);
else if(scale == 500){
writeRegister(L3G4200D_Address, CTRL_REG4, 0b00010000);
else{
writeRegister(L3G4200D_Address, CTRL_REG4, 0b00110000);
// CTRL_REG5 controls high-pass filtering of outputs, use it
// if you'd like:
writeRegister(L3G4200D_Address, CTRL_REG5, 0b00000000);
void writeRegister(int deviceAddress, byte address, byte val) {
Wire.beginTransmission(deviceAddress); // start transmission to device
Wire.write(address); // send register address
Wire.write(val); // send value to write
Wire.endTransmission(); // end transmission
int readRegister(int deviceAddress, byte address){
int v;
Wire.write(address); // register to read
if (Wire.requestFrom(deviceAddress, 1) != 1) // Read a byte
return -1; // error
return Wire.read (); // return data
When I run it I just get -1's, because Wire.requestFrom(deviceAddress, 1) returns an error.
Possibly I do not have the right address, but if that was the case, wouldn't the I2C scanner have found the right address?
I would appreciate any help.
