It has been two years since i programmed on Arduino. Have not changed the sketch. Try to compile and get error message" File does not exist". Have tried several files with same result. Also same for DS3231.
Remove and reload libraries in use and board managers.
Post the complete error message but it sounds like the RTC lib is not installed or installed in the wrong place. How you reference it in your code is also important.
