Not seeing CAN Frames
Hello, first up, I'm a complete novice at Arduino and much less C++.
I have been toying around with a CAN based Gauge, the project for first coded by a Friend of mine that programmed it for Haltech ECUs. Displays data, RPM, Coolant Temps etc..
I helped out by coding the Link ECU intrigration. Had it working well. However I wanted to update it and change a few things on it as it's been a couple of years since I last played with it.
I noticed that my code no longer compiled on my machine. Erroring up. I found out that the CAN library I was using (GitHub - coryjfowler/MCP_CAN_lib: MCP_CAN Library) changed the CAN Id lookup
" The readMsgBuf() functions bring in the message ID. The getCanId() function is obsolete and no longer exists, don't use it."
I was using the getCanId in my code, so re-wrote the sections that used it and added in a
        unsigned int canId = 0x0FA;
        CAN0.readMsgBuf(canId, &rxLen, rxBuf);
However the Link ECUs use a multi frame CAN stream, meaning they use the first byte in the ID to label a frame number. Then each frame can have up to 7 bytes long for the date. Fitting in a lot of data into the single ID.
But I've noticed that the new library isn't picking up the frame, even though I request it in code.
        if (rxBuf[0] == 0) {                                        // If CAN ID is 250 pull the following buffer info
          VALUE1 = word(rxBuf[3], rxBuf[2]);                          // First two of bytes ID250 are RPM (buffer 2,3), skip first byte as this is address for frame
          VALUE1 = ((VALUE1 / 10) * 10);                              // Divide by 10 and times by 10 to remove last digit
        if (rxBuf[0] == 1) {                                        // Frame 2
          VALUE2 = word(rxBuf[5], rxBuf[4]);                          // Bytes 4 and 5 are TPS
          VALUE2 = (VALUE2 * 0.1);
Doing a print on VALUE1 gives me the correct RPM. However VALUE2 does not show anything.
Doing a serial print of the raw buffer shows only the first frame (byte 0) messages.
Elite_Gauge_Link_Generic_Dash.ino (33.1 KB)
I've uploaded the INO file, a lot of screens are commented out for testing.
I've also uploaded the Link ECU CAN stream structure. That shows the multiple frames.
Any advice or a pointers would be greatly appreciated.
#include <SPI.h>                                              // Harware SPI library
#include <mcp_can.h>                                          // CAN Library
#include <Adafruit_GFX.h>                                     // OLED GFX Library
#include <Adafruit_SSD1306.h>                                 // 1.3 inch OLED library
#include <EEPROM.h>                                           // EEPROM library
const byte led = 23;                                           // On board LED 23 will use for CAN connection indicator
//2.4 v2.0 OLED PINS H/W SPI                                   // Define OLED Pins
#define OLED_CS     11
#define OLED_RESET  10
#define OLED_DC     9
Adafruit_SSD1306 display(OLED_DC, OLED_RESET, OLED_CS);
//2.4 OLED PINS S/W SPI                                       // Uncomment for 2.4 inch OLED
//#define OLED_MOSI   11
//#define OLED_CLK   10
//#define OLED_DC    9
//#define OLED_CS    12
//#define OLED_RESET 8
//Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
//BUTTON CONFIG
const byte button = 4;
long buttonTimer = 0;
long longPressTime = 750;
boolean buttonActive = false;
boolean longPressActive = false;
//EEPROM CONFIG
byte addr = 1;                                                 // Initislise the EEPROM address
byte buttonPushCounter = EEPROM.read(1);                      // Counter for the number of button presses (get value from EEPROM)
//byte buttonPushCounter = 0;
//CAN CONFIG
unsigned char rxLen;                                      // CAN message rx length
unsigned char rxBuf[8];                                       // CAN message number of bytes
MCP_CAN CAN0(17);                                             // Set CAN C/S pin
byte CANfilterset = 0;                                        // Check if the fitler is set
//ECU VALUES
int VALUE1;                                                  // VALUE1 integer
int VALUE2;                                                  // VALUE2 integer
int VALUE3;                                                  // VALUE1 integer
int VALUE4;                                                  // VALUE2 integer
word STATUS1 = 0;
int STATUS2 = 0;
int STATUS3 = 0;
int STATUS4 = 0;
int STATUS5 = 0;
int LIMIT1 = 0;
int CLIMIT1;
float FVALUE1 = 0;                                               // VALUE1 floating point (decemal place numbers)
float FVALUE2 = 0;                                               // VALUE2 floating point (decemal place numbers)
float FVALUE3 = 0;
float FVALUE4 = 0;
unsigned long line = 0;
unsigned long ID = 0;
//SCREEN 1 HEADING, DATA AND MAX/MIN VALUES
int MAX1 = -10000;
int MAX2 = -10000;
int MIN1 = 10000;
int MIN2 = 10000;
float FMAX1 = -10000;
float FMAX2 = -10000;
float FMIN1 = 10000;
float FMIN2 = 10000;
int ScreenOff = 0;
  Serial.begin(115200);                                       // Serial Comms speed
  pinMode(led, OUTPUT);                                       // Setup Pin 23 as Output Led
  if (buttonPushCounter >= 13)                                 // On first run EEPROM could be any value 0-254
  { EEPROM.write(1, 0);                                        // If it is above 13, set it to zero to agree with the 'if' loop
  display.begin(SSD1306_SWITCHCAPVCC);                        // Initialise OLED
  display.setTextWrap(false);
  pinMode(button, INPUT_PULLUP);                              //Button config
  pinMode(6, OUTPUT);
  digitalWrite(6, LOW);
  display.setRotation(0);                                     // Set rotation (0) Normal, (2) 180 deg
  display.clearDisplay();
  display.setTextSize(3);                                     // Splash screen
  display.setTextColor(WHITE);
  display.setCursor(20, 5);
  display.println("ELITE");
  display.setCursor(13, 35);
  display.setTextSize(2);
  display.println("GAUGE G4x");
  display.display();
  delay(1500);
  while (CAN_OK != CAN0.begin(MCP_STDEXT, CAN_1000KBPS, MCP_16MHZ))                     // initiate CAN bus : baudrate = 1000k for Haltech
    Serial.println(F("CAN BUS Shield init fail"));               // :(
    Serial.println(F(" Init CAN BUS Shield again"));             // Yes please
  Serial.println(F("CAN BUS Shield init ok!"));                  // YAY!
  CAN0.setMode(MCP_NORMAL);
  if (digitalRead(button) == LOW) {
    if (buttonActive == false) {
      buttonActive = true;
      buttonTimer = millis();
    if ((millis() - buttonTimer > longPressTime) && (longPressActive == false)) {
      // Clear the peak values
      longPressActive = true;
      CANfilterset = 0;
      resetValues();
      resetMaxMin();
      delay(50);
    if (buttonActive == true) {
      if (longPressActive == true) {
        //INCREMENT THE BUTTON COUNTER AND SET THE FILTER
        buttonPushCounter++;
        if (buttonPushCounter >= 13) buttonPushCounter = 0; // Reset button counter to loop through the displays
        EEPROM.write(1, buttonPushCounter);               // Update the counter into EEPROM (address location 1)
        CANfilterset = 0;                                  // Reset the CAN filter for next CAN ID
        ScreenOff = 0;
        resetValues();
        resetMaxMin();
        delay(50);
// RPM and TPS start
    if (buttonPushCounter == 0) {                                      // buttonPushCounter is used to cylce through screens
      if (CANfilterset < 3) {
        CAN0.init_Mask(0, 0, 0xFFFF);
        CAN0.init_Filt(0, 0, 0x00FA);
        CANfilterset++;
       // resetMaxMin();
      if (CAN_MSGAVAIL == CAN0.checkReceive())                        // Check if data coming
        digitalWrite(led, HIGH);                                      // turn the LED on, Data RX
        CAN0.readMsgBuf(canId, &rxLen, rxBuf);                               // Read data,  rxLen: data length, rxBuf: data buf
        if (VALUE1 > MAX1) {
          MAX1 = VALUE1;
        //debug
                Serial.println("-----------------------------");
                Serial.print("Data from ID: 0x");
                Serial.println(canId, HEX);
                for(int i = 0; i<rxLen; i++)
            Serial.print(rxBuf[i]);
            Serial.print("\t");
        // end debug
        display.setTextSize(1);
        display.setCursor(0, 0);
        display.println("RPM");
        display.setTextSize(4);
        display.setCursor(5, 12);
        if (VALUE1 < 10000) {
          display.print(" ");
        if (VALUE1 < 1000) {
          display.print(" ");
        if (VALUE1 < 100) {
          display.print(" ");
        if (VALUE1 < 10) {
          display.print(" ");
        display.println(VALUE1, DEC);                               // Show value1 (RPM) as a whole decimal number
        display.setCursor(0, 47);
        display.println("TPS");
        display.setCursor(0, 57);
        display.println("MAX");
        display.setCursor(88, 47);
        display.print(VALUE2, DEC);
        display.setCursor(88, 57);
        display.print(MAX1, DEC);
        display.display();
        delay(100);
// MGP Start
    if (buttonPushCounter == 1) {
        CANfilterset++;
        resetMaxMin();
        unsigned int canId = "0x00FA";
        if (rxBuf[0] == 0) {                                      // If CAN ID is 360 pull the following buffer info, frame ID 1
          VALUE1 = word(rxBuf[7], rxBuf[6]);
          //VALUE1 = (VALUE1 * 10);
          FVALUE1 = ((VALUE1 / 6.894) - 14.6);
        if (FVALUE1 > FMAX1) {
          FMAX1 = FVALUE1;
        display.println("MGP PSI");
        display.setCursor(5, 15);
        if (FVALUE1 >= 0.0) {
          display.print("+");
        display.print(FVALUE1, 1);
        display.print(FMAX1, 1);
        display.display();
// Ethanol Content Start
    if (buttonPushCounter == 2) {
        CANfilterset++;
        resetMaxMin();
        // Get Ethanol %
        if (rxBuf[0] == 13) {                  // frame 14
          VALUE1 = word(rxBuf[5], rxBuf[4]);
        display.println("ETHANOL %");
        display.setTextSize(5);
        display.setCursor(40, 20);
        if (VALUE1 < 10) {
          display.print(" ");
        display.display();
// Coolent and Air Temps Start
    if (buttonPushCounter == 3) {
        CANfilterset++;
        resetMaxMin();
        if (rxBuf[0] == 2) {
          FVALUE1 = (VALUE1 - 50.0);
          if (rxBuf[0] == 3) {
          VALUE2 = word(rxBuf[3], rxBuf[2]);
          FVALUE2 = (VALUE2 - 50.0);
          FMAX1 = FVALUE1;
        if (FVALUE2 > FMAX2) {
          FMAX2 = FVALUE2;
        display.println("CTS");
        display.setCursor(0, 23);
        display.println("IAT");
        display.setCursor(40, 0);
        if (FVALUE1 < -100.0) {
          display.print(" ----- ");
        display.println(FVALUE1, 1);
        display.setCursor(40, 23);
        if (FVALUE2 < -100.0) {
        display.println(FVALUE2, 1);
        display.println("PEAK CTS");
        display.println("PEAK IAT");
        display.print(FMAX2, 1);
        display.display();
// AFR Start
    if (buttonPushCounter == 4) {
        CANfilterset++;
        resetMaxMin();
        if (rxBuf[0] == 6) {
          FVALUE1 = (((VALUE1 / 10.0) * 14.7) / 100.0);
        display.println("AFR");
        if (FVALUE1 < 10.0) {
          display.print(" ");
        display.display();
// Oil Pressure Start
    if (buttonPushCounter == 5) {
        CANfilterset++;
        resetMaxMin();
        if (rxBuf[0] == 8) {
          VALUE1 = ((VALUE1 / 10.0) - 100);
          FVALUE1 = ((VALUE1 * 14.5) / 100.0);
        if (FVALUE1 < FMIN1) {
          FMIN1 = FVALUE1;
          FMAX1 = FVALUE1;
        display.println("OIL P");
        if (FVALUE1 < 100.0) {
          display.print(" ");
          display.print(" ");
        display.println("MIN");
        display.print(FMIN1, 1);
        display.display();
// Battery Voltage
    if (buttonPushCounter == 6) {
        CANfilterset++;
        resetMaxMin();
          FVALUE1 = (VALUE1 / 100.0);
          FMIN1 = FVALUE1;
          FMAX1 = FVALUE1;
        display.println("BATT V");
        display.setCursor(25, 12);
          display.print(" ");
        display.display();
// Gear and Speed Start
    if (buttonPushCounter == 7) {
        CANfilterset++;
        resetMaxMin();
        if (rxBuf[0] == 4)  {
          VALUE1 = word(rxBuf[3],rxBuf[2]);
          if (rxBuf[0] == 9); {
          VALUE2 = (VALUE2 / 10);
        display.println("GEAR");
        display.setCursor(0, 40);
        display.println("SPEED");
        display.setCursor(80, 0);
        display.setCursor(52, 40);
        if (VALUE2 < 100) {
          display.print(" ");
        if (VALUE2 < 10) {
          display.print(" ");
        display.println(VALUE2, DEC);
        display.display();
// Injector Duty Start
    if (buttonPushCounter == 8) {
        CANfilterset++;
        resetMaxMin();
          FVALUE1 = (VALUE1 / 10.0);
          FMAX1 = FVALUE1;
        display.println("INJ %");
          display.print(" ");
          display.print(" ");
        display.display();
// Fuel Pressure Start
    if (buttonPushCounter == 9) {
        CANfilterset++;
        resetMaxMin();
        if (rxBuf[0] == 7) {
          FVALUE1 = ((VALUE1 / 6.895) * 1.0);
          FMIN1 = FVALUE1;
          FMAX1 = FVALUE1;
        display.println("FUEL P");
          display.print(" ");
          display.print(" ");
        display.display();
// Oil Temp Start
    if (buttonPushCounter == 10) {
        CANfilterset++;
        resetMaxMin();
          FMAX1 = FVALUE1;
        display.println("OIL T");
        display.setCursor(8, 12);
          display.print(" ");
          display.print(" ");
          display.print(" --- ");
        display.display();
// Ignition Timing Start
    if (buttonPushCounter == 11) {
        CANfilterset++;
        resetMaxMin();
          FVALUE1 = ((VALUE1 * 0.1) - 100);
        if (FVALUE1 > MAX1) {
          MAX1 = FVALUE1;
        display.println("IGN Timing");
        if (FVALUE1 < 1000) {
          display.print(" ");
        if (FVALUE1 < 100) {
          display.print(" ");
        if (FVALUE1 < 10) {
          display.print(" ");
        if (FVALUE1 < -100) {
        display.println(FVALUE1, DEC);
        display.display();
/* Cutting due to space limits
// Cam Angle Start
    if (buttonPushCounter == 12) {
        CANfilterset++;
        resetMaxMin();
        if ((canId == 0x00FA) && (rxBuf[0] == 5))  {
          VALUE1 = word(rxBuf[3],rxBuf[2]);                 //Cam Inlet Bank 1
          FVALUE1 = (VALUE1 * 0.1);
          VALUE2 = word(rxBuf[5],rxBuf[4]);                 //Cam Inlet Bank 2
          FVALUE2 = (VALUE2 * 0.1);
          VALUE3 = word(rxBuf[7],rxBuf[6]);                 //Cam Exhaust Bank 1
          FVALUE3 = (VALUE3 * 0.1);
        if ((canId == 0x00FA) && (rxBuf[0] == 6)) {
          VALUE4 = word(rxBuf[3], rxBuf[2]);                //Cam Exhaust Bank 2
          FVALUE4 = (VALUE4 * 0.1);
        display.println("Cam Angle");
        display.setCursor(0, 10);
        display.println("Inlet 1:");
        display.setCursor(70, 10);
        display.print(FVALUE1, DEC);
        display.setCursor(0, 20);
        display.print("Inlet 2: ");
        display.setCursor(70, 20);
        display.print(FVALUE2, DEC);
        display.setCursor(0, 30);
        display.print("Exhaust 1:");
        display.setCursor(70, 30);
        display.print(FVALUE3, DEC);
        display.print("Exhaust 2:");
        display.setCursor(70, 40);
        display.print(FVALUE4, DEC);
        display.display();
// Status Screen Start
    if (buttonPushCounter == 13) {
        CANfilterset++;
        resetMaxMin();
          STATUS1 = word(rxBuf[6], rxBuf[7]);
          STATUS2 = bitRead(STATUS1, 15)*4 + bitRead(STATUS1, 14)*2 + bitRead(STATUS1, 13);   // Anti-Lag
          STATUS3 = bitRead(STATUS1, 12)*2 + bitRead(STATUS1, 11);                            // Launch Control
          STATUS4 = bitRead(STATUS1, 10)*4 + bitRead(STATUS1, 9)*2 + bitRead(STATUS1, 8);   // Traction Control
          STATUS5 = bitRead(STATUS1, 7)*8 + bitRead(STATUS1, 6)*4 + bitRead(STATUS1, 5)*2 + bitRead(STATUS1, 4);   // Cruise Control
          if (rxBuf[0] == 12) {
          CLIMIT1 = word(rxBuf[6], rxBuf[7]);
          if (bitRead(CLIMIT1, 0) == 1) (LIMIT1=0);}
          else if (bitRead(CLIMIT1, 1) == 1) (LIMIT1=1);
          else if (bitRead(CLIMIT1, 2) == 1) (LIMIT1=2);
          else if (bitRead(CLIMIT1, 3) == 1) (LIMIT1=3);
          else if (bitRead(CLIMIT1, 4) == 1) (LIMIT1=4);
          else if (bitRead(CLIMIT1, 5) == 1) (LIMIT1=5);
          else if (bitRead(CLIMIT1, 6) == 1) (LIMIT1=6);
          else if (bitRead(CLIMIT1, 7) == 1) (LIMIT1=7);
          else if (bitRead(CLIMIT1, 8) == 1) (LIMIT1=8);
          else if (bitRead(CLIMIT1, 9) == 1) (LIMIT1=9);
          else if (bitRead(CLIMIT1, 10) == 1) (LIMIT1=10);
          else if (bitRead(CLIMIT1, 11) == 1) (LIMIT1=11);
          else if (bitRead(CLIMIT1, 12) == 1) (LIMIT1=12);
          else if (bitRead(CLIMIT1, 13) == 1) (LIMIT1=13);
          else if (bitRead(CLIMIT1, 14) == 1) (LIMIT1=14);
          else if (bitRead(CLIMIT1, 15) == 1) (LIMIT1=15);
    display.setFont(NULL);
    display.println("STATUS");
// Anti-Lag Status
        display.print("AntiLag:");
        display.setCursor(55, 10);
        if (STATUS2 == 0) display.print("OFF");
        else if (STATUS2 == 1 ) display.print("Armed");
        else if (STATUS2 == 2 ) display.print("OFF: RPM<500");
        else if (STATUS2 == 3 ) display.print("Armed:Cyc OFF");
        else if (STATUS2 == 4 ) display.print("Armed:Cyc ACT");
        else if (STATUS2 == 5 ) display.print("Cyc Cooldown");
        else if (STATUS2 == 6 ) display.print("D-Arm:Cyc ACT");
// Launch Control
        display.print("Launch: ");
        display.setCursor(55, 20);
        if (STATUS3 == 0) display.print("OFF");
        else if (STATUS3 == 1 ) display.print("Active");
        else if (STATUS3 == 2 ) display.print("Inactive");
// Traction Control
        display.print("Traction: ");
        display.setCursor(55, 30);
        if (STATUS4 == 0) display.print("OFF");
        else if (STATUS4 == 1 ) display.print("RPM Lockout");
        else if (STATUS4 == 2 ) display.print("TPS Lockout");
        else if (STATUS4 == 3 ) display.print("SPD Lockout");
        else if (STATUS4 == 4 ) display.print("Ready");
        else if (STATUS4 == 5 ) display.print("Active");
        else if (STATUS4 == 6 ) display.print("Disabled");
        else if (STATUS4 == 7 ) display.print("OFF: TQ Mod");
 // Cruise Control
 //       display.setCursor(0, 40);
        display.print("Cruise: ");
        display.setCursor(55, 40);
        if (STATUS5 == 0) display.print("OFF");
        else if (STATUS5 == 1 ) display.print("Enabled");
        else if (STATUS5 == 2 ) display.print("Active");
        else if (STATUS5 == 3 ) display.print("Startup LCK");
        else if (STATUS5 == 4 ) display.print("Min RPM");
        else if (STATUS5 == 5 ) display.print("Max RPM");
        else if (STATUS5 == 6 ) display.print("CAN Error");
// Limits
        display.setCursor(0, 50);
        display.print("Limit: ");
        display.setCursor(55, 50);
        if (LIMIT1 == 0) display.print("RPM Limit");
        else if (LIMIT1 == 1 ) display.print("MAP Limit");
        else if (LIMIT1 == 2 ) display.print("Speed Limit");
        else if (LIMIT1 == 3 ) display.print("MAX Ignition");
        else if (LIMIT1 == 4 ) display.print("ALag IGN Cut");
        else if (LIMIT1 == 5 ) display.print("High Voltage");
        else if (LIMIT1 == 6 ) display.print("Overrun Flag");
        else if (LIMIT1 == 7 ) display.print("Traction Lim");
        else if (LIMIT1 == 8 ) display.print("Low Voltage");
        else if (LIMIT1 == 9 ) display.print("Launch RPM L");
        else if (LIMIT1 == 10 ) display.print("Empty");
        else if (LIMIT1 == 11 ) display.print("GP RPM 1 Lim");
        else if (LIMIT1 == 12 ) display.print("Rotary Oil");
        else if (LIMIT1 == 13 ) display.print("GP RPM 2 Lim");
        else if (LIMIT1 == 14 ) display.print("EThrottle");
        else if (LIMIT1 == 15 ) display.print("Cyclic Idle");
 * Link Generic dash profile uses Frame 14 bytes 6-7 for status for Anti-lag, Launch Control, Traction Control and Cruise Control
 * In the Ardunio CAN, this translates to the first byte of the frame == 13 setting the fram number to 14. Bytes 6 and 7 and read into the buffer
 * the bit ordering on the Ardunio is as follows
 * |   AL   |  LC |  TC  |  CC   |  NA   |
 * |15,14,13,12,11,10,9,8,7,6,5,4,3,2,1,0|
 * AL = Anti-Lag
 * LC = Launch Control
 * TC = Traction Control
 * CC = Cruise Control
 * NA = Unsued
       display.display();
    if (buttonPushCounter == 14) {
      if ( ScreenOff < 500) {
        ScreenOff++;
        display.setCursor(5, 25);
        display.println("SCREEN OFF");
        display.display();
        delay[1500];
      else {
        display.display();
void resetValues() {
  //ECU VALUES
//  VALUE1 = 0;
//  VALUE2 = 0;
  FVALUE1 = 0;
  FVALUE2 = 0;
void resetMaxMin() {
  MAX1 = -10000;
  MAX2 = -10000;
  MIN1 = 10000;
  MIN2 = 10000;
  FMAX1 = -10000;
  FMAX2 = -10000;
  FMIN1 = 10000;
  FMIN2 = 10000;
type or paste code here
I'm not comfortable with this kind matters but...
Please post autoformatted code here using code tags, the </> symbol. Helpers don't like filling up their computers, or they use phones, tablets that can't read .INO files.
Posting code here make more helpers take on Your post.
