Hi all
I need some help with this kind of communication between the above arduinos. The nRF are connected on a 5v convert board and are powered by separately. During my trials they are in a distance of a meter between them. Both have a 10uF cap on their board power in points.
The problem is that the receiver seems not receiving. I think is better to include the results than tried to explain. An image is always better than words i think.
I followed Robin2 instructions with simple TX-RX codes. Also i tried the TEST code from his #31 for both of the nRFs. I include the results from the tests and the results from the serial monitors.
I read a lot of threads about issues with this communication and tried a few things like different cap capacitors, different devices, some delays but no success untill now. If someone comes up with an idea will be great. Thanks.
CODE FOR NANO
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 7
#define CSN_PIN 8
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
Serial.println("SimpleTx Starting");
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.setRetries(3,5); // delay, count
radio.openWritingPipe(slaveAddress);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis) {
send();
prevMillis = millis();
void send() {
bool rslt;
rslt = radio.write( &dataToSend, sizeof(dataToSend) );
// Always use sizeof() as it gives the size as the number of bytes.
// For example if dataToSend was an int sizeof() would correctly return 2
Serial.print("Data Sent ");
Serial.print(dataToSend);
if (rslt) {
Serial.println(" Acknowledge received");
updateMessage();
else {
Serial.println(" Tx failed");
void updateMessage() {
// so you can see that new data is being sent
txNum += 1;
if (txNum > '9') {
txNum = '0';
dataToSend[8] = txNum;
CODE FOR MEGA
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 7
#define CSN_PIN 8
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
Serial.println("SimpleRx Starting");
radio.begin();
radio.openReadingPipe(1, thisSlaveAddress);
radio.startListening();
getData();
delay(200);
showData();
void getData() {
if ( radio.available() ) {
radio.read( &dataReceived, sizeof(dataReceived) );
newData = true;
void showData() {
if (newData == true) {
Serial.print("Data received ");
Serial.println(dataReceived);
newData = false;
The following is the code of ROBIN2 to check if there is connection between nRF module and the Arduino.
// 18 Mar 2018 - simple program to verify connection between Arduino
// and nRF24L01+
// This program does NOT attempt any communication with another nRF24
#include <SPI.h>
#include <RF24.h>
#include <printf.h>
#define CE_PIN 9
#define CSN_PIN 10
printf_begin();
Serial.println("CheckConnection Starting");
Serial.println("FIRST WITH THE DEFAULT ADDRESSES after power on");
Serial.println(" Note that RF24 does NOT reset when Arduino resets - only when power is removed");
Serial.println(" If the numbers are mostly 0x00 or 0xff it means that the Arduino is not");
Serial.println(" communicating with the nRF24");
radio.begin();
radio.printDetails();
Serial.println("AND NOW WITH ADDRESS AAAxR 0x41 41 41 78 52 ON P1");
Serial.println(" and 250KBPS data rate");
Upload a photo of my setup:
I don't have the capability at the moment to upload a schematic so i will describe the connections which are simple ones.
For Arduino MEGA 2560:
GND -----> GND
CE ------> PIN 7
CSN ------> PIN 8
MISO ----> PIN 50
MOSI ----> PIN 51
SCK ------> PIN 52
Power supply for the nRF module is separate from the arduino. The GND is connected from nRF module to the arduino.
For NANO;
GND -----> GND
CE -----> PIN 7
CSN -----> PIN 8
MISO ----> PIN D12
MOSI ----> PIN D11
SCK ------> PIN D13
THE RESULTS FROM THE COMMUNICATION BETWEEN THE 2 ARDUINO'S ARE WORD DOCUMENTS(COPIED FROM TERATERM) IN THE FOLLOWING LINK:arduino nRF - Google Drive
IS TOO MUCH TO LOAD HERE.
THANK YOU.
