Hello!
I'm lost between all the threads and the different libraries
I have to send only a number from 1 to 32 to more than 10 slaves at the same time using 1 master, and nothing else. (using the NRF24L01 chip)
All the libraries talk about pipes, sending message back,....
I only need a one way communication.
Someone already did that ?
Thanks for your help !
If you disable autoacknowledge you can (successfully) send to any number of clients.
You will not know whether anybody copied your message,
but that's normal for a broadcast.
Okay thanks, but is there any library that is the best and easiest to do that ?
Handling of autoacknowledge should be contained in any library.
After study of the nrf2401 datasheet (which is a must to use that chip anyway),
you could easily add it (or expose it if hidden by private: or protected:) yourself.
