Hello everyone!
I am trying to get my Uno and Leonardo to communicate with each other using a nRF24l01. I have connected both modules but it doesn't work...
I have already tested the communication between the arduinos and the module with Robins program.
*See Simple nRF24L01+ 2.4GHz transceiver demo - #30 by Robin2
However, I'm not really at all familiar with how chips and modules work so I don't really know what it all means. The results are below.
I also don't know if it is possible to have a uno and a leonardo communicate because of the different chips. I did check the frequency and it is the same.
Can anyone help me with this?
Thanks in advance!
Uno:
CheckConnection Starting
FIRST WITH THE DEFAULT ADDRESSES after power on
Note that RF24 does NOT reset when Arduino resets - only when power is removed
If the numbers are mostly 0x00 or 0xff it means that the Arduino is not
communicating with the nRF24
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0xe7e7e7e7e7 0x4141417852
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0xe7e7e7e7e7
RX_PW_P0-6 = 0x00 0x20 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0e
DYNPD/FEATURE = 0x00 0x00
Data Rate = 1MBPS
Model = nRF24L01+
CRC Length = 16 bits
PA Power = PA_MAX
AND NOW WITH ADDRESS AAAxR 0x41 41 41 78 52 ON P1
and 250KBPS data rate
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x27
CONFIG = 0x0e
Data Rate = 250KBPS
Model = nRF24L01+
PA Power = PA_MAX
Leonardo:
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0e
Data Rate = 1MBPS
Model = nRF24L01+
PA Power = PA_MAX
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x27
CONFIG = 0x0e
Data Rate = 250KBPS
Model = nRF24L01+
PA Power = PA_MAX
