I've been doing some testing on nRF24L01+ modules, especially on range, and I like everyone I want more range.
The goal is to have a central hub with multiple sensors for use in house (with concrete floors, yay). Each sensor communicates directly to the central hub, so between a sensor and the hub 2 way communication should be possible. I want to use the PA+LNA with antenna - version in main hub, and the smaller modules with on board antenna for sensors.
To look at feasability I've done some basic range testing on them, and is is on the edge of fair connection. Meaning that if I look at the sensor furthest from the hub location, it has contact, sort of. Depending on where I stand, the exact antenna direction, and possibaly even the ether winds, I sometimes have no connection.
I'm looking for a decent way to make sure I have connection roughly everywhere. I already have set powers on max, caps soldered on all modules, set send retries to 15, and am using 250kbps data rate. Additionally I am using a 3.3v regulator on the PA+LNA module.
Can I get better sending/receiving capabilities on the central hub by changing the antenna for a "better" one? If yes, what to look for in such an antenna?
Alternatively can I improve connectivity by soldering a wire antenna to the basic modules (as described here). Exept I don't think I can implement this perfect dipole. A sollution I would rather be looking at is a flexible wire-antenna, that can be bent to fit the space of sensor installation (for example: bent around the inside of a 3x3cm enclosure). Or would that give worse than stock performance?
