Hi all
have been tryin to get my two nrf24l01 modules to communicate without luck. The code gives me the response
"sending to nrf24_reliable_datagram_server" (clientside)
"init failed 7or nothing" (severside)
pinout i have been using is , and the arduinos is connected to its own computer (tried on the same as well...same result)
9 CE
10 CSN
11 MOSI
12 MISO
13 SCK
and i have tried with and without external powersupply for the nrf24L01 (3s lipo with a bec) in addition i have connected an adapter for the nrf24l01 so i can supply that with the 5 v from eiter the nano or the bec
Board that has been used is Nano copy (5V)
i hope for some ideas to why its not working proberly
i have also tried the example from the NRFLite library "multiplePacketSizes TX and RX", and that works fine.
// nrf24_reliable_datagram_server.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple addressed, reliable messaging server
// with the RHReliableDatagram class, using the RH_NRF24 driver to control a NRF24 radio.
// It is designed to work with the other example nrf24_reliable_datagram_client
// Tested on Uno with Sparkfun WRL-00691 NRF24L01 module
// Tested on Teensy with Sparkfun WRL-00691 NRF24L01 module
// Tested on Anarduino Mini (http://www.anarduino.com/mini/) with RFM73 module
// Tested on Arduino Mega with Sparkfun WRL-00691 NRF25L01 module
#include <RHReliableDatagram.h>
#include <RH_NRF24.h>
#include <SPI.h>
#define CLIENT_ADDRESS 1
#define SERVER_ADDRESS 2
// Singleton instance of the radio driver
RH_NRF24 driver(9,10);
// RH_NRF24 driver(8, 7); // For RFM73 on Anarduino Mini
// Class to manage message delivery and receipt, using the driver declared above
RHReliableDatagram manager(driver, SERVER_ADDRESS);
if (!manager.init())
Serial.println("init failed");
// Defaults after init are 2.402 GHz (channel 2), 2Mbps, 0dBm
uint8_t data[] = "And hello back to you";
// Dont put this on the stack:
uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
if (manager.available())
// Wait for a message addressed to us from the client
uint8_t len = sizeof(buf);
uint8_t from;
if (manager.recvfromAck(buf, &len, &from))
Serial.print("got request from : 0x");
Serial.print(from, HEX);
Serial.print(": ");
Serial.println((char*)buf);
// Send a reply back to the originator client
if (!manager.sendtoWait(data, sizeof(data), from))
Serial.println("sendtoWait failed");
// nrf24_reliable_datagram_client.pde
// Example sketch showing how to create a simple addressed, reliable messaging client
// It is designed to work with the other example nrf24_reliable_datagram_server
#include <SPI.h>
RHReliableDatagram manager(driver, CLIENT_ADDRESS);
uint8_t data[] = "Hello World!";
Serial.println("Sending to nrf24_reliable_datagram_server");
// Send a message to manager_server
if (manager.sendtoWait(data, sizeof(data), SERVER_ADDRESS))
// Now wait for a reply from the server
uint8_t from;
if (manager.recvfromAckTimeout(buf, &len, 2000, &from))
Serial.print("got reply from : 0x");
Serial.print(": ");
Serial.println("No reply, is nrf24_reliable_datagram_server running?");
