I'm working on a project using two Arduino Uno R3 boards, each connected to an nRF24L01 module. One Arduino is set up as a transmitter, and the other as a receiver. The transmitter sends a data packet containing an angle (stored as a uint8_t) and a distance (stored as a uint16_t) to the receiver, which is supposed to display these values on the Serial Monitor.
Issue:
- On the transmitter side, everything seems to work fine. When I check the Serial Monitor, the angle and distance values update correctly as expected.
- On the receiver side, however, both the angle and distance values are stuck at 0, even though the transmitter is sending non-zero data.
What I've Tried:
- Pipe Addresses: I've double-checked that the pipe addresses match on both the transmitter and receiver.
- Data Structure: I've ensured that the data structure (e.g., a struct with a uint8_t for angle and a uint16_t for distance) is identical in both the transmitter and receiver code.
- Wiring: I've verified the connections between the Arduino and the nRF24L01 modules (CE to pin 9, CSN to pin 10, SCK to pin 13, MOSI to pin 11, MISO to pin 12, VCC to 3.3V, GND to GND).
- Power Supply: I've confirmed that the nRF24L01 modules are powered with 3.3V from the Arduino, though I haven’t tested with an external power source yet.
- Debugging: I’ve added Serial.print statements in the receiver code to check if data is being received, but it still shows no updates.
Additional Details:
- I’m using the RF24 library for communication between the nRF24L01 modules.
- The transmitter setup includes a servo and a TFmini-S sensor to generate the angle and distance values, but since the transmitter works fine, I don’t think this is the issue.
- The nRF24L01 settings (e.g., power level, data rate, channel) are configured to match on both sides.
Questions:
- What could be causing the receiver to not receive or properly interpret the data from the transmitter?
- Are there any common pitfalls with nRF24L01 modules that I might have overlooked?
- What additional debugging steps would you recommend to pinpoint the problem?
Code Snippets:
Here’s a simplified version of my code for reference (please let me know if you need more details):
Transmitter Code:
#include <Servo.h>
#include <SoftwareSerial.h>
#include <SPI.h>
#include <RF24.h>
// -------------------- CONFIGURATION --------------------
// TFmini-S SoftwareSerial pins:
const uint8_t TFmini_RX = 4; // Sensor TX → Arduino RX
const uint8_t TFmini_TX = 5; // Arduino TX → Sensor RX (if needed)
// Servo pin:
const uint8_t SERVO_PIN = 6;
// nRF24L01 pins:
const uint8_t CE_PIN = 9; // CE connected to pin 9
const uint8_t CSN_PIN = 10; // CSN connected to pin 10
// -------------------- OBJECTS --------------------
Servo scanServo;
SoftwareSerial tfminiSerial(TFmini_RX, TFmini_TX);
RF24 radio(CE_PIN, CSN_PIN);
// Data structure for transmission (must match receiver):
struct DataPacket {
uint8_t angle; // Servo angle (0-180)
uint16_t distance; // Distance reading from sensor
// Pipe address (must be the same on transmitter and receiver):
const byte pipeAddress[6] = "00001";
// Scanning parameters:
const int minAngle = 0;
const int maxAngle = 180;
int currentAngle = minAngle;
int step = 5;
// -------------------- FUNCTIONS --------------------
// Read distance from TFmini-S sensor:
uint16_t readTFminiDistance() {
const uint8_t frameSize = 9;
uint8_t buffer[frameSize];
if (tfminiSerial.available() < frameSize) {
return 0; // Not enough data
while (tfminiSerial.available() >= frameSize) {
if (tfminiSerial.peek() == 0x59) {
tfminiSerial.readBytes(buffer, frameSize);
if (buffer[1] == 0x59) {
uint16_t dist = buffer[2] | (buffer[3] << 8);
return dist;
tfminiSerial.read(); // Discard until header found
return 0;
tfminiSerial.begin(115200); // TFmini-S baud rate
// Initialize servo:
scanServo.attach(SERVO_PIN);
scanServo.write(currentAngle);
delay(500); // Allow servo to settle
// Initialize nRF24L01:
radio.begin();
radio.openWritingPipe(pipeAddress); // Use the defined pipe address
radio.setPALevel(RF24_PA_HIGH); // High power
radio.setDataRate(RF24_250KBPS); // 250 kbps data rate
radio.stopListening(); // Set as transmitter
// Move servo to current angle:
delay(50); // Allow servo to move
// Read distance from sensor:
uint16_t distance = readTFminiDistance();
// Create data packet:
DataPacket packet;
packet.angle = currentAngle;
packet.distance = distance;
// Send packet via nRF24L01:
bool sent = radio.write(&packet, sizeof(packet));
// Debug output:
Serial.print("Angle: ");
Serial.print(currentAngle);
Serial.print(" Distance: ");
Serial.print(distance);
Serial.print(" Sent: ");
Serial.println(sent ? "Yes" : "No");
// Update angle for next iteration:
currentAngle += step;
if (currentAngle >= maxAngle || currentAngle <= minAngle) {
step = -step; // Reverse direction at limits
delay(100); // Control scanning speed
Receiver code:
#include <SPI.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN pins
struct DataPacket {
uint8_t angle;
uint16_t distance;
radio.begin();
radio.openReadingPipe(1, pipeAddress);
radio.startListening();
if (radio.available()) {
DataPacket packet;
radio.read(&packet, sizeof(packet));
Serial.print(packet.angle);
Serial.println(packet.distance);
I’d really appreciate any insights or suggestions you have! I’ve been stuck on this for a while and could use some fresh ideas to get the receiver working properly. Thanks in advance!
