for a project, I am working on I need to send numbers (random) from the transmitter to the receiver but it doesn't work. I don't find what it could be. I think it is something whit the char I am sending in.
transmitter ;
#include <nRF24L01.h>
#include <printf.h>
#include <RF24.h>
#include <RF24_config.h>
int randNumber = 0;
char Data[32];
RF24 transmit (2, 3); //create RF24 object called transmit
byte address [6] = "00001"; //set address to 00001
transmit.begin();
transmit.openWritingPipe(address); //open writing pipe to address 00001
transmit.setPALevel(RF24_PA_MIN); //set RF power output to minimum
transmit.setDataRate(RF24_250KBPS); //set datarate to 250kbps
transmit.setChannel(100); //set frequency to channel 100
transmit.stopListening();
randNumber = random(100, 120);
dtostrf(randNumber,10, 2, Data); //send character string upto 32 bytes long
transmit.write(&Data, sizeof(Data)); //transmit the data
receiver ;
#include <printf.h>
#include <RF24.h>
RF24 receive (2,3); //create object called receive
byte address [5] = "00001" ;
//creat an array with 5 elements, where each element is 1 byte;
Serial.begin(19200);
Serial.print("Starting Receiver \n");
receive.begin();
receive.openReadingPipe(0,address); //open reading pipe 0 at address 00001
receive.setPALevel(RF24_PA_MIN); //Set RF output to minimum
receive.setDataRate(RF24_250KBPS); //set datarate to 250kbps
receive.setChannel(100); //set frequency to channel 100
receive.startListening();
if (receive.available()) //check when received data available
char Data[32];
receive.read(&Data, sizeof(Data));
Serial.print(Data); //print data to serial monitor
If someone could help me it would be very nice of you.
the example I used worked but it was "hello world" I tried to replace hello word whit a random number because I am trying to send data from a GY-521 to another Arduino. with what I got now it does this
serial monitor ;
Starting Receiver
Data =
Data =
Data =
Data =
as you can see it doesn't read any number.
and this is the code I changed as you said.
transmitter;
#include <printf.h>
#include <RF24.h>
int randNumber = 0;
char Data[32];
RF24 transmit (9, 10); //create RF24 object called transmit
transmit.begin();
randNumber = random(10, 15);
sprintf(randNumber,"%d", Data); //send character string upto 32 bytes long
transmit.write(Data, sizeof(Data)); //transmit the data
Serial.println(Data);
receiver ;
#include <printf.h>
#include <RF24.h>
RF24 receive (9,10); //create object called receive
byte address [6] = "00001" ;
receive.begin();
char Data[32];
receive.read(Data, sizeof(Data));
Serial.print("Data = ");
Serial.println(Data); //print data to serial monitor
Do this
int randNumber = random(10, 15);
transmit.write(randNumber, sizeof(randNumber)); //transmit the data
Serial.println(randNumber);
and on the Rx side instead of this
char Data[32];
Do this
int randNumber;;
receive.read(randNumber, sizeof(randNumber));
Serial.print("randNumber = ");
Serial.println(randNumber); //print data to serial monitor
thank u for the help but whit everything you say it still doesn't work. any other advice?
in my serial monitor from the transmitter, I got data = (random number) but in my receiver it still says nothing.
6-echo:
Have you tried the first example in the link in Reply #2 with NO CHANGES to the example code?
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
There is also a connection test program to check that the Arduino can talk to the nRF24 it is connected to.
A common problem with nRF24 modules is insufficient 3.3v current from the Arduino 3.3v pin. At least for testing try powering the nRF24 with a pair of AA alkaline cells (3v) with the battery GND connected to the Arduino GND.
