nRf24L01 weird question
I started my adventure using the maniacbug library prior to Arduino having the RF24 by TMRh20 installed in the new downloaded IDE 11/14/16
am I correct in thinking that mainiacbug and TMRH20 have combined there code and all should work fine using old 2014 sketches?
unless I lost it completely I seem to have a hard time getting 2 way communication working with the new IDE on old sketches.
should I be defining each pin?
#define CE_pin 9
#define CSN_pin 10
etc
BTW using windows 10 app version
The TMRh20 library is a newer version of the ManiacBug code with some important improvements. There are slight differences for some of the functions.
If you get a compiler error look up the documentation for both versions and you should be able to figure out how to update the code.
...R
Simple nRF24L01+ Tutorial
