Hello!
Quite new to Arduino so forgive me for any mistakes -- I'm trying to build a driver circuit that can power a PCB trace to keep it at a constant ~35 C. I'm using a XIAO ESP32-C3 board and I've had a couple questions about my schematic and my code:
- My serial monitor states that the voltage measured is ~0.64 V. With my voltage divider setup I was expecting a voltage drop of ~1.65 across my thermistor, so I'm not sure if I just set up my circuit terribly wrong. I'm using a thermocouple to monitor the temperature of the trace and the temperature is ~25 C, so I'm not sure why the drop is so small.
- The specific thermistor I'm using is the NCP15WF104F03RC, which is 100k ohms at 25C and a B constant of 4250 K at 25C/50C
#include <PID_v1.h>
#define THERM_PIN A2
#define HEAT_PIN D10
#define THERM_R 100000 // thermistor resistance at 25 C
#define TEMP_NOM 25
#define NUM_SAMPLES 5
#define BETA 4250
#define SERIES_R 100000.0
//Define Variables we'll be connecting to
double Kp = 2.0, Ki = 2.0, Kd = 0.0;
// double Kp = 2.0, Ki = 5.0, Kd = 1.0;
float Rref = 100000.0; // Value of the reference resistor in ohms
float supplyVoltage = 3.3; // Supply voltage of ESP32 (assuming 3.3V)
float R0 = 100000.0; // resistance of thermistor at 25 C
//Specify the links and initial tuning parameters
double Setpoint, Input, Output;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
int WindowSize = 500;
unsigned long windowStartTime;
Setpoint = 35.0;
// Initialize heater pin
pinMode(HEAT_PIN, OUTPUT);
digitalWrite(HEAT_PIN, HIGH); // heater off
windowStartTime = millis();
//tell the PID to range between 0 and the full window size
myPID.SetOutputLimits(0, WindowSize);
//turn the PID on
myPID.SetMode(AUTOMATIC);
float average = analogRead(THERM_PIN);
Serial.print("analog reading ");
Serial.println(average); // analog input from thermistor voltage divider
float voltage = average * (3.3 / 4095.0); // convert analog reading to voltage; Vsupply / adcMax (ADC resolution)
Serial.print("Voltage ");
Serial.println(voltage); // analog input from thermistor voltage divider
float thermistorResistance = calculateResistance(voltage);
Serial.print("Thermistor resistance ");
Serial.println(thermistorResistance);
float temp = calculateTemperature(thermistorResistance);
Serial.print("Temperature: ");
Serial.print(temp);
Serial.println(" C");
Input = temp;
myPID.Compute();
// Adjust heater based on PID output
analogWrite(HEAT_PIN, Output);
// Print debug information
Serial.print("Setpoint: ");
Serial.print(Setpoint);
Serial.print(" | ");
Serial.print("Input: ");
Serial.print(Input);
Serial.print("Output: ");
Serial.println(Output);
turn the output pin on/off based on pid output
unsigned long now = millis();
if (millis() - windowStartTime > WindowSize) { //time to shift the Relay Window
windowStartTime += WindowSize;
if (Output > millis() - windowStartTime) digitalWrite(HEAT_PIN, HIGH);
else digitalWrite(HEAT_PIN, LOW);
float calculateResistance(float voltage) {
float Rseries = 100000.0;
float thermistorResistance = (Rseries * voltage) / (3.3 - voltage);
return thermistorResistance;
float calculateTemperature(float resistance) {
// using Steinhart-Hart equation
float A = 0.6400107870e-03;
float B = 2.440533353e-04;
float C = -0.6275337436e-07;
float inv_T = A + B * log(resistance) + C * pow(log(resistance), 3);
float temperature = (1.0 / inv_T) - 273.15; // Convert to Celsius
return temperature;
