OBD II sparkfun issue
Hi all,
I have one obd 2 uart from sparkfun and tried to make their example of code.
This is obd2 and guide - OBD II UART Hookup Guide - SparkFun Learn
When I try to compile the code I get this error
Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
WARNING: Category 'Signal Input' in library PCINT r-site.net is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
C:\Users\lucian\Desktop\obd-sparkfun-test\obd-sparkfun-test.ino: In function 'void loop()':
obd-sparkfun-test:58: error: 'getResponse' was not declared in this scope
   getResponse();
C:\Users\lucian\Desktop\obd-sparkfun-test\obd-sparkfun-test.ino: At global scope:
obd-sparkfun-test:92: error: expected unqualified-id before '/' token
 /The getResponse function collects incoming data from the UART into the rxData buffer
exit status 1
This is the code
#include <SoftwareSerial.h>
//Create an instance of the new soft serial library to control the serial LCD
//Note, digital pin 3 of the Arduino should be connected to Rx of the serial LCD.
SoftwareSerial lcd(2,3);
//This is a character buffer that will store the data from the serial port
char rxData[20];
char rxIndex=0;
//Variables to hold the speed and RPM data.
int vehicleSpeed=0;
int vehicleRPM=0;
void setup(){
  //Both the Serial LCD and the OBD-II-UART use 9600 bps.
  lcd.begin(9600);
  //Clear the old data from the LCD.
  lcd.write(254);
  lcd.write(1);
  //Put the speed header on the first row.
  lcd.print("Speed: ");
  lcd.write(254);
  //Put the RPM header on the second row.
  lcd.write(128+64);
  lcd.print("RPM: ");
  //Wait for a little while before sending the reset command to the OBD-II-UART
  delay(1500);
  //Reset the OBD-II-UART
  Serial.println("ATZ");
  //Wait for a bit before starting to send commands after the reset.
  delay(2000);
  //Delete any data that may be in the serial port before we begin.
  Serial.flush();
void loop(){
  Serial.flush();
  //Set the cursor in the position where we want the speed data.
  lcd.write(254);
  lcd.write(128+8);
  //Clear out the old speed data, and reset the cursor position.
  lcd.print("        ");
  lcd.write(254);
  lcd.write(128+8);
  //Query the OBD-II-UART for the Vehicle Speed
  Serial.println("010D");
  //Get the response from the OBD-II-UART board. We get two responses
  //because the OBD-II-UART echoes the command that is sent.
  //We want the data in the second response.
  getResponse();
  getResponse();
  //Convert the string data to an integer
  vehicleSpeed = strtol(&rxData[6],0,16);
  //Print the speed data to the lcd
  lcd.print(vehicleSpeed);
  lcd.print(" km/h");
  delay(100);
  //Delete any data that may be left over in the serial port.
  Serial.flush();
  //Move the serial cursor to the position where we want the RPM data.
  lcd.write(254);
  lcd.write(128 + 69);
  //Clear the old RPM data, and then move the cursor position back.
  lcd.print("          ");
  lcd.write(254);
  lcd.write(128+69);
  //Query the OBD-II-UART for the Vehicle rpm
  Serial.println("010C");
  getResponse();
  getResponse();
  //NOTE: RPM data is two bytes long, and delivered in 1/4 RPM from the OBD-II-UART
  vehicleRPM = ((strtol(&rxData[6],0,16)*256)+strtol(&rxData[9],0,16))/4;
  //Print the rpm data to the lcd
  lcd.print(vehicleRPM);
  //Give the OBD bus a rest
  delay(100);
// and only exits when a carriage return character is seen. Once the carriage return
// string is detected, the rxData buffer is null terminated (so we can treat it as a string)
// and the rxData index is reset to 0 so that the next string can be copied.
void getResponse(void){
  char inChar=0;
  //Keep reading characters until we get a carriage return
  while(inChar != '\r'){
    //If a character comes in on the serial port, we need to act on it.
    if(Serial.available() > 0){
      //Start by checking if we've received the end of message character ('\r').
      if(Serial.peek() == '\r'){
        //Clear the Serial buffer
        inChar=Serial.read();
        //Put the end of string character on our data string
        rxData[rxIndex]='\0';
        //Reset the buffer index so that the next character goes back at the beginning of the string.
        rxIndex=0;
      //If we didn't get the end of message character, just add the new character to the string.
      else{
        //Get the new character from the Serial port.
        inChar = Serial.read();
        //Add the new character to the string, and increment the index variable.
        rxData[rxIndex++]=inChar;
Is the example code broken or I do something wrong?
Thanks a lot
So, after forty posts, you
a) post in the wrong section
b) you post without code tags, thereby making it harder for others to help you.
C) (I'm guessing here) you didn't post all the error message.
I am sorry, I edited
Have you fixed that?
I think I am the most stupid man on earth....
I don t know how missed it
Thanks a lot
I missed it too, until you posted the full error message
Me again :slight_smile:
I did some progress but I am not able to get the correct RPM. I always get 832 rpm, no matter what.
I put that i in the code to check if is stuck or not and seems is not stuck...
Here is a short movie with how it works.
And this is the code
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
char rxData[20];
char rxIndex=0;
int i=0;
int vehicleRPM=0;
void setup(){
  lcd.begin(16, 2);
  lcd.print("Starting!...");
  delay (1000);
  lcd.setCursor(0, 0);
  lcd.print("RPM: ");
  delay(1500);
  delay(2000);
  Serial.flush();
void loop(){
  Serial.flush();
  //Set the cursor in the position where we want the rpm data.
   lcd.setCursor(0, 1);
  lcd.print(i);
  i++;
  lcd.setCursor(5, 0);
  lcd.print("..........");
  getResponse();
  getResponse();
  //lcd.print(" RPM");
  delay(100);
//The getResponse function collects incoming data from the UART into the rxData buffer
  char inChar=0;
        rxIndex=0;
      else{
Any idea what can be?
string - good.
Not terminating string - bad.
Robin2 has an excellent serial input tutorial.
I am not sure I get what you mean but I will search for that tutorial.
But this part of code is the original one from the sparkfun, haven t changed that...
Still working on this and still wasn't able to make it work :frowning:
If I am using pc serial over ftdi I get correct values but here I have a cr char which actually cut my first char from what I receive, see picture 1
Then with this code, I get only what you can see in pictures on my lcd...
Any help will be highly appreciated cause I have no more ideas what to try.
* OBD-II-UART Quickstart Sketch
* Written by Ryan Owens for SparkFun Electronics 7/5/2011
* Updates for Arduino 1.0+ by Toni Klopfenstein
* Released under the 'beerware' license
* (Do what you want with the code, but if we ever meet then you buy me a beer)
* This sketch will grab RPM and Vehicle Speed data from a vehicle with an OBD port
* using the OBD-II-UART board from SparkFun electronics. The data will be displayed
* on a serial 16x2 LCD. See the tutorial at https://www.sparkfun.com/tutorials/294
* to learn how to hook up the hardware:
//SoftwareSerial lcd(2,3);
char rxData[20];
char rxIndex=0;
int vehicleSpeed=0;
int vehicleRPM=0;
const int rs = 8, en = 9, d4 = 4, d5 = 5, d6 = 6, d7 = 7;
void setup(){
  //lcd.begin(9600);
  lcd.write(254);
  lcd.write(1);
  lcd.write(254);
  lcd.write(128+64);
  lcd.print("RPM: ");
  delay(1500);
  delay(2000);
  Serial.flush();
void loop(){
  Serial.flush();
  lcd.write(254);
  lcd.write(128+8);
  lcd.print("        ");
  lcd.write(254);
  lcd.write(128+8);
  getResponse();
  getResponse();
  lcd.print(" km/h");
  delay(100);
  Serial.flush();
  lcd.write(254);
  lcd.print("          ");
  lcd.write(254);
  lcd.write(128+69);
  getResponse();
  getResponse();
  delay(100);
  char inChar=0;
        rxIndex=0;
      else{
