#include <ESP32Servo.h>
Servo servo; // create servo object to control a servo
#define trigger_pin 5
#define echo_pin 18
#define SERVO_PIN 12 //seeting servo pin
// Setting Motor A
int enable1Pin = 14;
int motor1Pin1 = 27;
int motor1Pin2 = 26;
//Settin Motor B
int enable2Pin = 32;
int motor2Pin3 = 25;
int motor2Pin4 = 33;
// Setting PWM properties
const int frequency = 3000;
const int pwm_channel = 0;
const int resolution = 8;
long t; //var time to calculate distance
int distance; //var to store diatnce
servo.attach(SERVO_PIN); // attaches the servo on pin 12 to the servo objectư
pinMode(trigger_pin,OUTPUT); // attaches the trigger pin to 5 pin
pinMode(echo_pin,INPUT); // attaches echo pin to 18 pin
//modding motor A
pinMode(enable1Pin, OUTPUT);
pinMode(motor1Pin1, OUTPUT);
pinMode(motor1Pin2, OUTPUT);
//modding Motor B
pinMode(enable2Pin, OUTPUT);
pinMode(motor2Pin3, OUTPUT);
pinMode(motor2Pin4, OUTPUT);
// configure LEDC PWM
ledcAttachChannel(enable1Pin, frequency, resolution,pwm_channel);
ledcAttachChannel(enable2Pin, frequency, resolution,pwm_channel);
//setting hc-sro4
digitalWrite(trigger_pin,LOW);
delay(5);
digitalWrite(trigger_pin,HIGH);
delay(10);
//getting distance from hc-sr04
t = pulseIn(echo_pin, HIGH);
distance = (t*0.034)/2;
//default moving forward
MoveForward();
delay(200);
//centering servo
servo.write(90);
if(distance<20){
int distanceLeft = 0; //setting var for left and right
int distanceRight = 0;
delay(200);
distanceLeft = ServoLookLeft(distance);
delay(200);
distanceRight = ServoLookRight(distance);
delay(200);
StopCar();
delay(200);
MoveBackward();
delay(200);
StopCar();
delay(200);
//calcauting shortest distance
if(distanceRight <= distanceLeft){
TurnLeft();
else{
TurnRight();
//servo seek clear path
//servo turn left
int ServoLookLeft(int distance){
int ditanceLeft = 0;
servo.write(180); //lefting servo and taking value
delay(2000);
return distance;
//servo turn right
int ServoLookRight(int distance){
int ditanceRight = 0;
servo.write(0); //lefting servo and taking value
delay(2000);
return distance;
int SeekClearPath(){
servo.write(0); //righting servo
delay(2000);
ditanceRight=distance;
delay(2000);
ditanceLeft = distance;
//lcd.clear();
//centering servo back
servo.write(90);
//car movement functions
//move forward
void MoveForward(){
//Set speed motor A and B
analogWrite(enable1Pin,255);
analogWrite(enable2Pin,255);
digitalWrite(motor1Pin1, LOW);
digitalWrite(motor1Pin2, HIGH);
digitalWrite(motor2Pin3, HIGH);
digitalWrite(motor2Pin4, LOW);
//lcd.clear();
//move backward
void MoveBackward(){
digitalWrite(motor1Pin1, HIGH);
digitalWrite(motor1Pin2, LOW);
//lcd.clear();
delay(700);
//turn car left
void TurnLeft(){
digitalWrite(motor2Pin3, LOW);
//lcd.clear();
delay(850);
//Stop motor for half second
analogWrite(enable1Pin,0);
analogWrite(enable2Pin,0);
digitalWrite(motor1Pin1,LOW);
digitalWrite(motor2Pin3,LOW);
//turn car right
void TurnRight(){
//turn right
digitalWrite(motor2Pin4, HIGH);
//lcd.clear();
delay(850);
// stop car
void StopCar(){
delay(700);
type or paste code here
thats my attempt for obstacle avoidance car.
the thing is , the engine wont move.
when i try this-
// Motor A
//Motor B
//modding motor A
//modding Motor B
//forward
delay(700);
//Stop motor
delay(700);
i get a normal movement forward.
what am i missing?
