Help with servo control on ESP32
I'm using arduino IDE to program make a simple obstacle avoidance robot with only Ultrasonic Sensor mounted on a servo. I'm using the ESP32Servo.h library. If I load this function to esp32, it works fine and shows and scans the distance.
void scanDistance() {
  int servoAngle;
  const int angleLeft = 180;
  const int angleRight = 0;
  const int angleCenter = 90;
  // Set servo to center position and measure distance
  servo.write(angleCenter);
  delay(500); // Allow time for servo to stabilize
  servoAngle = angleCenter;
  if (servoAngle == angleCenter) {
    distanceCenter = getDistance();
    Serial.print("Center distance: ");
    Serial.println(distanceCenter);
  // If center distance is less than 20 cm, check left and right
  if (distanceCenter < 20) {
    // Look left
    servo.write(angleLeft);
    servoAngle = angleLeft;
    distanceLeft = getDistance();
    Serial.print("Left distance: ");
    Serial.println(distanceLeft);
    // Look right
    servo.write(angleRight);
    servoAngle = angleRight;
    distanceRight = getDistance();
    Serial.print("Right distance: ");
    Serial.println(distanceRight);
    // Return to center
but the moment I edit this and insert any functions related to moving the other motors the servo goes haywire and turns to the right. I'm using a simpe Micro servo sg90. and i know this is not a problem of current or voltage since i did not connect the motor drivers yet and is just checking the serial for values. Please Help asap. Will prefer a simple solution since I'm a beginner. Not a complete noob but not so profficient either. Need ASAP. Thanks in advance.
Are you using an Arduino® Nano ESP32 — Arduino Official Store or another ESP32 (which one)?
Full code might help others to help you.
there's really nothing else in the full code since I only have that function in the loop(); that one works fine but if I use this:
void navigationProtocol() {
  int servoAngle;
    // Look left
    // Look right
if (distanceLeft < distanceRight) {
      goRight();
      delay(500); // Allow time for turning
    } else if (distanceLeft > distanceRight) {
      goLeft();
    // Return to center
    // Return to center
  }else {
    moveForward();
which, as you can see, only added the movement functions. and there's really nothing wrong in those. just the typical motor control codes like enable pin and motor pin controls. the moment I run this code the servo goes to the right and it starts there. it's not even subtituting 0 degrees as 90 and 90 into 180 since it only moves about 20-30 degrees from 0.
I'm using ESP32 Dev Module
Topic moved. The category where you posted is specifically for the Arduino Nano ESP32.
I can't help you with your problem, sorry.
goRight goLeft and move Forward are all undefined!
So are many other variables, pin numbers etc.
Nothing I can do without seeing the complete code
hmmm according to my opinion :
  • Check the brake system
If your servo motor has a brake system, make sure it's turned on.
  • Check the motor speed circuit gain
See if the motor speed circuit gain setting is too high, and adjust it if needed.
  • Check the serial monitor
If you can't get the motor to move, check the serial monitor to see if you're getting a value back.
  • Install the ESP32Servo Library
You can install this library from the Arduino IDE's Library Manager. Once installed, you can open the File/Examples menu and scroll down to the ESP32Servo section.
Allow all digital pins to be used as PWM pins from frequencies and timers on esp 32
i hope this help and if i am wrong plz correct if you can :slight_smile:
