I am having occasional issues compiling to a Seeeduino XIAO. Some programs compile just fine but many (that I have assembled) are not. I am attaching a portion of the sketch that fails to compile and verbose error codes in the hopes that some Pro from Dover will point out my errors.
This is not the same issue as having to reset the tabs in order to allow communication. It is, apparently, something I have injected or dueling support files.
Respectfully - Baran
float pressLength_milliSeconds = 0;
int hi = 0;
int xPos = 0;
int counter = 0; .
int level;
int resetButton = 6;
int BenDangle = 0;
int BenDongle = 0;
int val = 0;
int newAngle;
int x;
int y;
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include "Wire.h"
#include "Seeed_BME280.h"
BME280 bme280;
MPU6050 mpu;
#include <Adafruit_GFX.h> // Calls up the OLED graphics folder.
#include <Adafruit_SSD1306.h> // Calls up the OLED display folder.
#define OUTPUT_READABLE_YAWPITCHROLL // Holds the angular information.
#define INTERRUPT_PIN 7
#define SEALEVELPRESSURE_HPA (1013.25)
#define DEBUG
#ifdef DEBUG
//#define DPRINT(args...) Serial.print(args) //OR use the following syntax:
#define DPRINTSTIMER(t) for (static unsigned long SpamTimer; (unsigned long)(millis() - SpamTimer) >= (t); SpamTimer = millis())
#define DPRINTSFN(StrSize,Name,...) {char S[StrSize];Serial.print("\t");Serial.print(Name);Serial.print(" "); Serial.print(dtostrf((float)__VA_ARGS__ ,S));}//StringSize,Name,Variable,Spaces,Percision
#define DPRINTLN(...) Serial.println(__VA_ARGS__)
#else
#define DPRINTSTIMER(t) if(false)
#define DPRINTSFN(...) //blank line
#define DPRINTLN(...) //blank line
#endif
#define interruptPin 6
#define LED_PIN 13 //
// gyro offsets here, scaled for min sensitivity: used MPU6050_calibration.ino
// XA YA ZA XG YG ZG
int MPUOffsets[6] = {-4563, 1649, 1339, -13, 34, 58};// Test Board 9255
// === i2c SETUP Items
void i2cSetup() {
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
Wire.begin();
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
// === INTERRUPT DETECTION ROUTINE
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
mpuInterrupt = true;
// === MPU DMP SETUP
int FifoAlive = 0;
int IsAlive = -20;
// MPU control/status vars
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
float euler[3]; // [psi, theta, phi] Euler angle container
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
byte StartUP = 100;
void MPU6050Connect() {
static int MPUInitCntr = 0;
// initialize device
mpu.initialize(); // same
// load and configure the DMP
devStatus = mpu.dmpInitialize();// same
if (devStatus != 0) {
// ERROR!
// 1 = initial memory load failed
// 2 = DMP configuration updates failed
// (if it's going to break, usually the code will be 1)
char * StatStr[5] { "No Error", "initial memory load failed", "DMP configuration updates failed", "3", "4"};
MPUInitCntr++;
Serial.print(F("MPU connection Try #"));
Serial.println(MPUInitCntr);
Serial.print(F("DMP Initialization failed (code "));
Serial.print(StatStr[devStatus]);
Serial.println(F(")"));
if (MPUInitCntr >= 10) return;
MPU6050Connect(); // Lets try again
return;
mpu.setXAccelOffset(MPUOffsets[0]);
mpu.setYAccelOffset(MPUOffsets[1]);
mpu.setZAccelOffset(MPUOffsets[2]);
mpu.setXGyroOffset(MPUOffsets[3]);
mpu.setYGyroOffset(MPUOffsets[4]);
mpu.setZGyroOffset(MPUOffsets[5]);
Serial.println(F("Enabling DMP..."));
mpu.setDMPEnabled(true);
Serial.println(F("Enabling interrupt detection (Arduino external interrupt pin 2 on the Uno)..."));
Serial.print("mpu.getInterruptDrive= "); Serial.println(mpu.getInterruptDrive());
attachInterrupt(digitalPinToInterrupt(interruptPin), dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
packetSize = mpu.dmpGetFIFOPacketSize();
delay(1000); // Let it Stabalize
mpu.resetFIFO(); // Clear fifo buffer
mpu.getIntStatus();
// === MPU DMP Get Data
void GetDMP() {
// Serial.println(F("FIFO interrupt at:"));
// Serial.println(micros());
static unsigned long LastGoodPacketTime;
FifoAlive = 1;
fifoCount = mpu.getFIFOCount();
if ((!fifoCount) || (fifoCount % packetSize)) {
digitalWrite(LED_PIN, LOW);
mpu.resetFIFO();
while (fifoCount >= packetSize) {
mpu.getFIFOBytes(fifoBuffer, packetSize);
fifoCount -= packetSize;
LastGoodPacketTime = millis();
MPUMath();
digitalWrite(LED_PIN, !digitalRead(LED_PIN));
// === MPU Math
float Yaw, Pitch, Roll;
void MPUMath() {
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
Yaw = (ypr[0] * 180.0 / M_PI);
Pitch = (ypr[1] * 180.0 / M_PI);
Roll = (ypr[2] * 180.0 / M_PI);
Roll = -Roll;
// === MPU DMP Get Data 1
void GetDMP1() {
FifoAlive = 1;
mpu.resetFIFO(); } else {
MPUMath1();
// === MPU Math 1
void MPUMath1() {
Roll = -Roll;
y = round(Roll);
if (y>90)
val = y-360;}
else{val=y;}
void GetDMP2() {
FifoAlive = 1;
mpu.resetFIFO();
MPUMath2();
// === MPU Math ===
void MPUMath2() {
counter = round(Pitch);
Serial.begin(115200); //115200
i2cSetup();
MPU6050Connect();
pinMode(LED_PIN, OUTPUT);
if (!bme280.init()) {Serial.println("Device error!");}
pinMode(resetButton, INPUT_PULLUP);
FOLLOWING IS THE VERBOSE COMPILATION DATA RECORD
Arduino: 1.8.15 (Windows 10), Board: "Seeeduino XIAO, Arduino, On"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Baran\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Baran\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Baran\sketchbook\libraries -fqbn=Seeeduino:samd:seeed_XIAO_m0:usbstack=arduino,debug=on -ide-version=10815 -build-path C:\Users\Baran\AppData\Local\Temp\arduino_build_34347 -warnings=none -build-cache C:\Users\Baran\AppData\Local\Temp\arduino_cache_29700 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=C:\Users\Baran\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\Baran\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.bossac.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1 -prefs=runtime.tools.CMSIS-Atmel-1.2.1.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.CMSIS.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0 -prefs=runtime.tools.CMSIS-5.7.0.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0 -verbose C:\Users\Baran\sketchbook\SuperFinalBB\SuperFinalBB.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Baran\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Baran\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Baran\sketchbook\libraries -fqbn=Seeeduino:samd:seeed_XIAO_m0:usbstack=arduino,debug=on -ide-version=10815 -build-path C:\Users\Baran\AppData\Local\Temp\arduino_build_34347 -warnings=none -build-cache C:\Users\Baran\AppData\Local\Temp\arduino_cache_29700 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=C:\Users\Baran\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\Baran\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.bossac.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1 -prefs=runtime.tools.CMSIS-Atmel-1.2.1.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.CMSIS.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0 -prefs=runtime.tools.CMSIS-5.7.0.path=C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0 -verbose C:\Users\Baran\sketchbook\SuperFinalBB\SuperFinalBB.ino
Using board 'seeed_XIAO_m0' from platform in folder: C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2
Using core 'arduino' from platform in folder: C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2
Detecting libraries used...
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o nul
Alternatives for I2Cdev.h: [Seeed_Arduino_IMU10DOF-master MPU6050@0.3.0 I2Cdev]
ResolveLibrary(I2Cdev.h)
-> candidates: [Seeed_Arduino_IMU10DOF-master MPU6050@0.3.0 I2Cdev]
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "-IC:\Users\Baran\sketchbook\libraries\I2Cdev" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "-IC:\Users\Baran\sketchbook\libraries\I2Cdev" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o nul
Alternatives for MPU6050_6Axis_MotionApps20.h: [MPU6050@0.3.0]
ResolveLibrary(MPU6050_6Axis_MotionApps20.h)
-> candidates: [MPU6050@0.3.0]
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "-IC:\Users\Baran\sketchbook\libraries\I2Cdev" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire" "-IC:\Users\Baran\sketchbook\libraries\MPU6050\src" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o nul
Alternatives for Seeed_BME280.h: [Grove_BME280-master@1.0.2]
ResolveLibrary(Seeed_BME280.h)
-> candidates: [Grove_BME280-master@1.0.2]
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "-IC:\Users\Baran\sketchbook\libraries\I2Cdev" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire" "-IC:\Users\Baran\sketchbook\libraries\MPU6050\src" "-IC:\Users\Baran\sketchbook\libraries\Grove_BME280-master" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.10.10]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [Adafruit_GFX_Library@1.10.10]
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "-IC:\Users\Baran\sketchbook\libraries\I2Cdev" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire" "-IC:\Users\Baran\sketchbook\libraries\MPU6050\src" "-IC:\Users\Baran\sketchbook\libraries\Grove_BME280-master" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o nul
Alternatives for Adafruit_SSD1306.h: [Adafruit_SSD1306@2.4.6]
ResolveLibrary(Adafruit_SSD1306.h)
-> candidates: [Adafruit_SSD1306@2.4.6]
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "-IC:\Users\Baran\sketchbook\libraries\I2Cdev" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire" "-IC:\Users\Baran\sketchbook\libraries\MPU6050\src" "-IC:\Users\Baran\sketchbook\libraries\Grove_BME280-master" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_SSD1306" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "-IC:\Users\Baran\sketchbook\libraries\I2Cdev" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire" "-IC:\Users\Baran\sketchbook\libraries\MPU6050\src" "-IC:\Users\Baran\sketchbook\libraries\Grove_BME280-master" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_SSD1306" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\SPI" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o nul
Alternatives for Adafruit_ZeroDMA.h: [Adafruit_ZeroDMA@1.0.4]
ResolveLibrary(Adafruit_ZeroDMA.h)
-> candidates: [Adafruit_ZeroDMA@1.0.4]
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "-IC:\Users\Baran\sketchbook\libraries\I2Cdev" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire" "-IC:\Users\Baran\sketchbook\libraries\MPU6050\src" "-IC:\Users\Baran\sketchbook\libraries\Grove_BME280-master" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_SSD1306" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\SPI" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Adafruit_ZeroDMA" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\I2Cdev\I2Cdev.cpp
Using cached library dependencies for file: C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire\Wire.cpp
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\MPU6050\src\I2Cdev.cpp
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\MPU6050\src\MPU6050.cpp
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\Grove_BME280-master\Seeed_BME280.cpp
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.8.3]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit_BusIO@1.8.3]
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library\glcdfont.c
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp
Using cached library dependencies for file: C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Adafruit_ZeroDMA\Adafruit_ZeroDMA.cpp
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp
Using cached library dependencies for file: C:\Users\Baran\sketchbook\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp
Generating function prototypes...
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "-IC:\Users\Baran\sketchbook\libraries\I2Cdev" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire" "-IC:\Users\Baran\sketchbook\libraries\MPU6050\src" "-IC:\Users\Baran\sketchbook\libraries\Grove_BME280-master" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_SSD1306" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\SPI" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Adafruit_ZeroDMA" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_BusIO" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD "-D__SKETCH_NAME__="""SuperFinalBB.ino"""" -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" -g -DDEBUG=1 -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER="Seeed"" "-DUSB_PRODUCT="Seeed XIAO M0"" -g -DDEBUG=1 "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" "-IC:\Users\Baran\sketchbook\libraries\I2Cdev" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire" "-IC:\Users\Baran\sketchbook\libraries\MPU6050\src" "-IC:\Users\Baran\sketchbook\libraries\Grove_BME280-master" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_SSD1306" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\SPI" "-IC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Adafruit_ZeroDMA" "-IC:\Users\Baran\sketchbook\libraries\Adafruit_BusIO" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp" -o "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp.o"
Compiling libraries...
Compiling library "I2Cdev"
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o
Compiling library "Wire"
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Wire\Wire.cpp.o
Compiling library "MPU6050"
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\MPU6050.cpp.o
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o
Compiling library "Grove_BME280-master"
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Grove_BME280-master\Seeed_BME280.cpp.o
Compiling library "Adafruit_GFX_Library"
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_GFX_Library\glcdfont.c.o
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp.o
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp.o
Compiling library "Adafruit_SSD1306"
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\SPI\SPI.cpp.o
Compiling library "Adafruit_ZeroDMA"
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_ZeroDMA\Adafruit_ZeroDMA.cpp.o
Compiling library "Adafruit_BusIO"
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o
Compiling core...
Using previously compiled file: C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\core\variant.cpp.o
Using precompiled core: C:\Users\Baran\AppData\Local\Temp\arduino_cache_29700\core\core_Seeeduino_samd_seeed_XIAO_m0_usbstack_arduino,debug_on_7134da0d1e821d41aa14f67af42ccb57.a
Linking everything together...
"C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" "-LC:\Users\Baran\AppData\Local\Temp\arduino_build_34347" -Os -Wl,--gc-sections -save-temps "-TC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\Users\Baran\AppData\Local\Temp\arduino_build_34347/SuperFinalBB.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -u _printf_float -u _scanf_float -Wl,--wrap,_write -u __wrap__write -o "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347/SuperFinalBB.ino.elf" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\sketch\SuperFinalBB.ino.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Wire\Wire.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\MPU6050.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Grove_BME280-master\Seeed_BME280.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_GFX_Library\glcdfont.c.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\SPI\SPI.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_ZeroDMA\Adafruit_ZeroDMA.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o" "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\core\variant.cpp.o" -Wl,--start-group "-LC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Lib/GCC/" -larm_cortexM0l_math -lm "-LC:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\variants\XIAO_m0" -lm "C:\Users\Baran\AppData\Local\Temp\arduino_build_34347/..\arduino_cache_29700\core\core_Seeeduino_samd_seeed_XIAO_m0_usbstack_arduino,debug_on_7134da0d1e821d41aa14f67af42ccb57.a" -Wl,--end-group
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::I2Cdev()':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:98: multiple definition of `I2Cdev::I2Cdev()'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:98: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::writeBytes(unsigned char, unsigned char, unsigned char, unsigned char*)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:588: multiple definition of `I2Cdev::writeBytes(unsigned char, unsigned char, unsigned char, unsigned char*)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:588: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::writeByte(unsigned char, unsigned char, unsigned char)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:567: multiple definition of `I2Cdev::writeByte(unsigned char, unsigned char, unsigned char)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:567: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::writeWords(unsigned char, unsigned char, unsigned char, unsigned short*)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:649: multiple definition of `I2Cdev::writeWords(unsigned char, unsigned char, unsigned char, unsigned short*)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:649: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::writeWord(unsigned char, unsigned char, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:577: multiple definition of `I2Cdev::writeWord(unsigned char, unsigned char, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:577: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::readBytes(unsigned char, unsigned char, unsigned char, unsigned char*, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:211: multiple definition of `I2Cdev::readBytes(unsigned char, unsigned char, unsigned char, unsigned char*, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:211: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::readByte(unsigned char, unsigned char, unsigned char*, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:188: multiple definition of `I2Cdev::readByte(unsigned char, unsigned char, unsigned char*, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:188: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::readBit(unsigned char, unsigned char, unsigned char, unsigned char*, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:108: multiple definition of `I2Cdev::readBit(unsigned char, unsigned char, unsigned char, unsigned char*, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:108: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::readBits(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char*, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:139: multiple definition of `I2Cdev::readBits(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char*, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:139: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::writeBit(unsigned char, unsigned char, unsigned char, unsigned char)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:482: multiple definition of `I2Cdev::writeBit(unsigned char, unsigned char, unsigned char, unsigned char)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:482: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::writeBits(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:511: multiple definition of `I2Cdev::writeBits(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)'
Multiple libraries were found for "I2Cdev.h"
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:511: first defined here
Used: C:\Users\Baran\sketchbook\libraries\I2Cdev
Not used: C:\Users\Baran\sketchbook\libraries\Seeed_Arduino_IMU10DOF-master
Not used: C:\Users\Baran\sketchbook\libraries\MPU6050
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::readWords(unsigned char, unsigned char, unsigned char, unsigned short*, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:331: multiple definition of `I2Cdev::readWords(unsigned char, unsigned char, unsigned char, unsigned short*, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:331: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::readWord(unsigned char, unsigned char, unsigned short*, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:199: multiple definition of `I2Cdev::readWord(unsigned char, unsigned char, unsigned short*, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:199: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::readBitW(unsigned char, unsigned char, unsigned char, unsigned short*, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:123: multiple definition of `I2Cdev::readBitW(unsigned char, unsigned char, unsigned char, unsigned short*, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:123: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::readBitsW(unsigned char, unsigned char, unsigned char, unsigned char, unsigned short*, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:164: multiple definition of `I2Cdev::readBitsW(unsigned char, unsigned char, unsigned char, unsigned char, unsigned short*, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:164: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::writeBitW(unsigned char, unsigned char, unsigned char, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:496: multiple definition of `I2Cdev::writeBitW(unsigned char, unsigned char, unsigned char, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:496: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o: In function `I2Cdev::writeBitsW(unsigned char, unsigned char, unsigned char, unsigned char, unsigned short)':
C:\Users\Baran\sketchbook\libraries\MPU6050\src/I2Cdev.cpp:540: multiple definition of `I2Cdev::writeBitsW(unsigned char, unsigned char, unsigned char, unsigned char, unsigned short)'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:C:\Users\Baran\sketchbook\libraries\I2Cdev/I2Cdev.cpp:540: first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\MPU6050\I2Cdev.cpp.o:(.data._ZN6I2Cdev11readTimeoutE+0x0): multiple definition of `I2Cdev::readTimeout'
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347\libraries\I2Cdev\I2Cdev.cpp.o:(.data._ZN6I2Cdev11readTimeoutE+0x0): first defined here
C:\Users\Baran\AppData\Local\Temp\arduino_build_34347/..\arduino_cache_29700\core\core_Seeeduino_samd_seeed_XIAO_m0_usbstack_arduino,debug_on_7134da0d1e821d41aa14f67af42ccb57.a(main.cpp.o): In function `_real_body()':
C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\cores\arduino/main.cpp:43: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
Using library I2Cdev in folder: C:\Users\Baran\sketchbook\libraries\I2Cdev (legacy)
Using library Wire at version 1.0 in folder: C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Wire
Using library MPU6050 at version 0.3.0 in folder: C:\Users\Baran\sketchbook\libraries\MPU6050
Using library Grove_BME280-master at version 1.0.2 in folder: C:\Users\Baran\sketchbook\libraries\Grove_BME280-master
Using library Adafruit_GFX_Library at version 1.10.10 in folder: C:\Users\Baran\sketchbook\libraries\Adafruit_GFX_Library
Using library Adafruit_SSD1306 at version 2.4.6 in folder: C:\Users\Baran\sketchbook\libraries\Adafruit_SSD1306
Using library SPI at version 1.0 in folder: C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\SPI
Using library Adafruit_ZeroDMA at version 1.0.4 in folder: C:\Users\Baran\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Adafruit_ZeroDMA
Using library Adafruit_BusIO at version 1.8.3 in folder: C:\Users\Baran\sketchbook\libraries\Adafruit_BusIO
exit status 1
Error compiling for board Seeeduino XIAO.
