Hm, the plot thickens. Well here's my full code, maybe you can provide some insight into something that I'm doing wrong with my logic, rather than the core being at fault. All I have connected to the ATTiny85 is an LED whose anode is connected to pin 5 (pin 0 in Arduino mapping), and cathode connected to pin 7 (pin 2 in Arduino mapping).
When I don't use random and explicitly return the same pattern every single time in my pickPattern method (choose r = 4, for example), the LED lights up just fine. But when I try to use random(1,10), nothing happens. Sometimes the LED will blink once very, very faintly, but thats about it.
// Define the driver (+) pins
#define CHAN_1_DRIVER_PIN 0
const byte NUM_LOW_PINS = 3;
const byte NUM_PATTERNS = 10;
const byte LOW_PINS[] = {2, 3, 4};
// Separate variables for two concurrent channels
byte CHAN_1_PIN;
byte * CHAN_1_PATTERN;
byte CHAN_1_PATTERN_SIZE;
byte CHAN_1_COUNTER;
byte CHAN_1_PATTERN_COUNTER;
// Define all the firefly patterns (based on real data)
byte pattern1[] = {2, 14, 44, 95, 141, 175, 192, 186, 149, 94, 60, 35, 38, 50, 76, 83, 73, 58, 43, 30, 20, 14, 16, 25, 30, 27, 20, 11, 4, 10, 17, 19, 14, 8, 4, 4, 6, 9, 9, 4, 2, 4, 14, 37, 79, 133, 173, 185, 172, 143, 106, 70, 45, 36, 44, 60, 75, 75, 59, 37, 20, 12, 16, 22, 26, 25, 22, 18, 14, 10, 7, 5, 7, 10, 10, 9, 7, 6, 5, 4, 5, 6, 6, 6, 5, 4, 3, 2, 2, 1};
byte pattern2[] = {5, 17, 45, 89, 131, 163, 185, 192, 180, 143, 95, 64, 41, 31, 44, 55, 79, 82, 73, 61, 48, 36, 26, 18, 14, 15, 23, 30, 29, 24, 17, 9, 4, 9, 15, 19, 17, 12, 6, 3, 3, 6, 8, 9, 7, 3, 2, 4, 12, 30, 61, 105, 149, 178, 184, 172, 148, 116, 84, 57, 41, 36, 44, 58, 72, 76, 68, 51, 32, 18, 12, 14, 20, 24, 26, 24, 21, 18, 15, 11, 8, 5, 5, 8, 10, 10, 9, 8, 6, 5, 4, 4, 5, 6, 6, 6, 5, 5, 4, 3, 2, 2, 1};
byte pattern3[] = {5, 15, 32, 64, 99, 132, 160, 179, 183, 167, 131, 89, 62, 44, 32, 36, 44, 54, 74, 74, 67, 57, 47, 38, 29, 21, 16, 14, 17, 24, 29, 29, 26, 20, 14, 6, 6, 13, 18, 20, 19, 16, 11, 6, 4, 4, 6, 9, 10, 8, 5, 3, 4, 7, 18, 37, 68, 112, 156, 186, 192, 176, 148, 115, 85, 61, 45, 36, 36, 45, 58, 69, 70, 59, 43, 29, 20, 15, 13, 15, 20, 23, 24, 24, 22, 20, 17, 14, 11, 8, 6, 5, 7, 11, 11, 9, 7, 5, 3};
byte pattern4[] = {2, 29, 81, 123, 130, 104, 63, 24, 2, 1, 1, 1, 1, 1, 1, 4, 15, 26, 36, 46, 55, 66, 79, 91, 102, 109, 115, 121, 131, 142, 152, 155, 151, 141, 133, 131, 135, 144, 153, 158, 158, 154, 151, 150, 149, 148, 144, 139, 136, 138, 145, 155, 161, 160, 153, 144, 138, 139, 145, 152, 156, 154, 148, 141, 138, 140, 145, 150, 153, 153, 152, 152, 154, 154, 150, 142, 134, 129, 132, 142, 156, 168, 170, 161, 146, 131, 121, 117, 116, 116, 115, 113, 110, 109, 106, 101, 92, 80, 67, 58, 52, 49, 46, 43, 39, 33, 27, 22, 18, 14, 11, 7, 5, 3, 1, 1, 0, 1, 0};
byte pattern5[] = {1, 31, 89, 126, 119, 85, 42, 6, 1, 1, 1, 1, 1, 1, 8, 22, 37, 51, 64, 72, 80, 92, 108, 122, 127, 122, 117, 124, 143, 163, 167, 155, 139, 135, 142, 150, 150, 141, 131, 129, 133, 139, 143, 146, 149, 152, 150, 144, 138, 138, 145, 150, 147, 137, 132, 137, 153, 166, 167, 156, 148, 149, 156, 161, 156, 147, 141, 145, 152, 157, 156, 154, 156, 161, 161, 152, 140, 133, 131, 130, 124, 114, 105, 102, 103, 101, 93, 82, 74, 68, 63, 55, 46, 38, 32, 29, 25, 20, 15, 11, 8, 6, 4, 2, 1, 1, 0, 0};
byte pattern6[] = {2, 25, 70, 117, 146, 144, 111, 61, 18, 1, 1, 1, 1, 1, 1, 1, 1, 8, 18, 28, 39, 50, 60, 69, 78, 85, 92, 99, 105, 111, 118, 126, 134, 142, 149, 155, 159, 161, 160, 156, 152, 146, 139, 134, 129, 126, 125, 126, 129, 134, 140, 148, 155, 162, 168, 171, 172, 171, 168, 163, 158, 153, 149, 146, 144, 144, 146, 148, 151, 154, 157, 158, 158, 157, 154, 150, 145, 141, 137, 134, 133, 132, 134, 136, 139, 143, 147, 149, 150, 150, 147, 143, 138, 133, 128, 123, 118, 115, 113, 111, 109, 108, 105, 102, 98, 92, 86, 78, 70, 63, 55, 48, 42, 37, 33, 29, 25, 22, 19, 16, 13, 10, 7, 5, 3, 2, 1, 1, 0, 0};
byte pattern7[] = {1, 27, 72, 109, 121, 104, 61, 17, 1, 1, 1, 1, 1, 1, 1, 11, 21, 34, 48, 60, 70, 77, 86, 99, 115, 128, 135, 135, 134, 136, 141, 144, 143, 139, 138, 141, 147, 148, 142, 131, 123, 126, 138, 153, 164, 166, 161, 156, 154, 154, 153, 151, 150, 155, 163, 169, 166, 152,136, 126, 128, 139, 151, 156, 153, 146, 140, 136, 131, 123, 115, 110, 110, 112, 110, 100, 86, 73, 65, 62, 60, 58, 52, 46, 40, 35, 31, 25, 20, 15, 11, 8, 6, 4, 2, 1, 1, 0, 0};
byte pattern8[] = {1, 26, 73, 116, 131, 115, 80, 39, 8, 1, 1, 1, 1, 1, 1, 1, 6, 15, 26, 36, 47, 58, 70, 82, 91, 98, 102, 106, 111, 119, 131, 144, 154, 157, 153, 144, 137, 134, 137, 146, 154, 158, 156, 149, 141, 137, 138, 143, 151, 157, 158, 155, 151, 148, 150, 154, 158, 160, 158, 153, 148, 144, 145, 147, 150, 150, 146, 140, 133, 130, 131, 135, 140, 143, 144, 142, 141, 141, 144, 149, 153, 156, 157, 157, 157, 160, 164, 167, 167, 161, 153, 145, 142, 143, 149, 154, 155, 149, 137, 124, 115, 112, 116, 123, 128, 128, 121, 110, 99, 91, 88, 88, 89, 87, 83, 75, 66, 57, 50, 44, 38, 34, 29, 25, 20, 17, 13, 9, 7, 4, 3, 1, 1, 0, 1, 0};
byte pattern9[] = {2, 36, 94, 130, 121, 79, 27, 1, 1, 1, 1, 1, 1, 5, 16, 30, 45, 59, 71, 82, 94, 107, 119, 130, 137, 142, 147, 151, 154, 153, 149, 144, 141, 141, 143, 143, 140, 134, 131, 135, 145, 160, 171, 172, 163, 150, 141, 140, 145, 151, 152, 147, 138, 134, 136, 147, 159, 165, 162, 152, 140, 132, 129, 131, 132, 131, 127, 123, 119, 116, 112, 105, 96, 86, 77, 69, 62, 54, 45, 38, 31, 27, 23, 19, 14, 10, 6, 4, 2, 1, 1, 0, 0};
byte pattern10[] = {2, 42, 99, 121, 96, 42, 3, 1, 1, 1, 1, 1, 12, 25, 41, 60, 77, 86, 91, 100, 118, 136, 144, 143, 141, 146, 153, 155, 153, 152, 155, 154, 148, 141, 142, 152, 159, 154, 142, 136, 141, 152, 153, 143, 132, 126, 124, 120, 111, 101, 92, 83, 72, 59, 49, 43, 38, 30, 21, 15, 11, 8, 5, 3, 1, 1, 0, 0};
// Set up an array for all the patterns
byte patternSizes[] = { 90, 103, 99, 119, 108, 130, 98, 136, 93, 68 };
byte patternOrder[] = {1, 4, 2, 6, 10, 4, 8, 1, 3, 7, 5, 10, 3, 4, 4, 8, 1, 4, 7, 3, 8, 2, 9, 8, 10, 2, 4, 6, 7, 3, 3, 9};
byte patternOrderSize = 32;
// Set up all the pin directions
pinMode(CHAN_1_DRIVER_PIN, OUTPUT);
for(int i=0; i<3; i++)
pinMode(LOW_PINS[i], OUTPUT);
// Initialize both driver pins to LOW, so no power reaches LEDs
digitalWrite(CHAN_1_DRIVER_PIN, LOW);
// Initialize all grounding pins to HIGH, so that when the
// driver pins do go HIGH, not all LEDs turn on.
digitalWrite(LOW_PINS[i], HIGH);
CHAN_1_PIN = LOW_PINS[0];
CHAN_1_PATTERN_COUNTER = 0;
CHAN_1_PATTERN = pickPattern();
// Drive LED cathode LOW (provide path to ground)
digitalWrite(CHAN_1_PIN, LOW);
// Output frame of pattern
analogWrite(CHAN_1_DRIVER_PIN, CHAN_1_PATTERN[CHAN_1_PATTERN_COUNTER]);
// Increment pattern counter, or reset counter and pick a new pattern
if(CHAN_1_PATTERN_COUNTER < CHAN_1_PATTERN_SIZE) {
CHAN_1_PATTERN_COUNTER++;
delay(10);
Pick a random pattern
- Method to pick a random firefly
pattern by generating a random number
between 1 and 10.
byte * pickPattern() {
int r = random(1,10); // does not work
// int r = 10; // works!
CHAN_1_PATTERN_SIZE = patternSizes[r-1];
switch(r) {
case 1:
return pattern1;
case 2:
return pattern2;
case 3:
return pattern3;
case 4:
return pattern4;
case 5:
return pattern5;
case 6:
return pattern6;
case 7:
return pattern7;
case 8:
return pattern8;
case 9:
return pattern9;
case 10:
return pattern10;
default:
return pattern2;
