Official Arduino WiFi Shield - Losing Connection?
Hi all,
I have been trying to work out how to maintain a constant connection to the internet for my project when using the arduino WiFi shield (Or at least reconnect). It looses connection randomly (between 30 minutes and several hours).
I am connecting to Ubidots and updating stats every 30 seconds so I don't think it's an idle time issue.
I've also updated the firmware to the latest.
Does anyone have some example code on diagnosing why it's not maintaining a connection? Or a method to reconnect? The green LED is still illuminated and my router shows a connection but the arduino does not respond to any web requests or a ping.
This also occurs when using the example WiFi sketches included in the arduino IDE.
Hi madlan,
I've also experienced the same issues and a fast way I've found around this is to reboot the Arduino periodically to make sure it stays fresh. I know it's not very elegant, but I recommend it for any system that might be left unattended (such as a measuring device).
I use this function to reset, which I found here in the forums:
void software_Reset()
asm volatile (" jmp 0");
Another healthy practice is to avoid the use of string operators and use the function sprintf instead. This minimizes the risk of causing memory problems.
Hope this helps.
I have had similar issues with Adafruit's CC3000 WiFi modules. It appears there's some kind of network event that causes them to disconnect. I have several of them and they often disconnect in synch. In my sketches I check to see if the device is connected to the WLAN each time through loop(), and if not I initiate a reconnect, starting with a reboot of the device, a device initialization and a connection sequence. Since it's written for the Adafruit device the code would require some tweaking, but here are some snippets which might help. It has a lot of debug fluff that can be stripped out, but unless DEBUG is #defined the code doesn't get compiled. The LEDs monitor the state of the WiFi connection, and one does double duty as a proof-of-life indicator for the rest of the sketch.
 wdt_disable();
 pinMode(redLED, OUTPUT);
 pinMode(yellowLED, OUTPUT);
 pinMode(greenLED, OUTPUT);
 #ifdef DEBUG
 readString.reserve(80);
 //enable serial data print
 delay(5000); // time to start serial monitor
 Serial.println(F("v2.0"));
 #endif
 // the following "gaurd code" does the initial connect to the WLAN and then
 // checks the connect state each time throught loop().
 // If the CC3000 disconnects from the WLAN it will automatically attempt to
 // reconnect, waiting for the WLAN to recover or come back into range if necessary.
 if (!cc3000.checkConnected())      // make sure we are connected to wireless network
   if (!init_network())    // try a cold start connect to WLAN
     delay(15 * 1000);     // if we couldn't connect, try again later
     return;
   // put any code that needs to be run after a sucessful WLAN connect/reconnecrt here
   www.begin(); // start the web server
   wdt_enable(WDTO_8S);
   #ifdef DEBUG
   Serial.println("Listening for connections ...");
   #endif
//  The rest of the code goes here
 glow_led();  // Proof of life indicator
 wdt_reset();
bool init_network(void)
 cc3000.reboot();
 // Set up the CC3000, connect to the access point, and get an IP address.
 #ifdef DEBUG
 Serial.println(F("Initializing CC3000..."));
 #endif
 greenFlag = false;  // glowing green off
 digitalWrite(redLED, HIGH);   // red on
 digitalWrite(yellowLED, LOW); // yellow off
 if (!cc3000.begin())  // fatal
 {                     // the code below will never execute since the call hangs when it fails
   #ifdef DEBUG
   Serial.println(F("Couldn't begin()"));
   #endif
   while(1);
 digitalWrite(redLED, LOW);      // red off
 digitalWrite(yellowLED, HIGH);  // yellow on
 if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY, WLAN_ATTEMPTS))
   #ifdef DEBUG
   Serial.println(F("Failed to connect to AP!"));
   #endif
   return false; // fail. Leaves yellow LED on
 digitalWrite(yellowLED, LOW);  // successful connect so turn off yellow LED
 #ifdef DEBUG
 Serial.println(F("Connected to Wireless Network!"));
 Serial.println(F("Request DHCP..."));
 #endif
 while (!cc3000.checkDHCP())
   delay(100);
 #ifdef DEBUG
 Serial.println(F("Got IP"));
 #endif
 greenFlag = true;  // enable glowing greenLED
 return true;  // success
// Glowing status LED
void glow_led(void)
   if (greenFlag)
   unsigned long i = millis();
   int j = i % 1000;
   if (j > 500)
      j = 500 - j;
   analogWrite(greenLED, j/2);
