Thank you in advance for reading this. As I am nearly at my wits end trying to make this work.
----> Basic Scenario:
Need to Interface Arduino with a device, that has 4 positions and OFF. Then cycles back to Position # 1.
So 5 button clicks Cycle the device... A Long Press Saves the ON position in case power is lost.
----> What I have Accomplished:
Power Arduino from the Device we wish to interface with - Done
Take the Devices own button, and Wire it up to the Arduino with a Pulldown Resistor - Done
Create a Homemade optocoupler using a photo-resistor and an LED + shrink Tubing - Done
Test the coupler to see if it manipulates the device, it does! 50ms blink, changes our position up +1
----> Complete Scenario
Now that I have an Interface with the original button that I can control from my Nano, I need to make it "Behave" in the following manner....
AutoButtonPress = Button Automatically records a press every 24 hours, and blinks the LED for 50ms
ManualSinglePress = After a short Pause, Blinks once for 50ms
ManualDoublePress = Resets the counter to 24 Hours
ManualLongPress = After a short Pause, LED lights for 5 Seconds to SAVE home position on the original device.
OutputToSerial = Show all actions on serial console for troubleshooting purposes
OutputCounterToDisplay = Output the 24 hour countdown to a display of some kind. To see when it is reset. As well as Status.
----> What I cannot Figure out
I am having a hard time understanding the Structure of the Code and how to mix all of these functions together on my Nano.
What Display I should Get, and How to Apply it to my Nano, and get it to display my counter.
How to get the counter to control the Button, and output its state to the display.
How to accomplish this on my Nano with as few pins as possible. (Limited Space inside the target Device.)
----> Honesty in all things... I'm a Sh_t coder, and I typically can only work from example.
But in this instance, I just cannot figure out how to put this all together.
I've been at this for 5 days now and I am starting to wonder if I can even do this.
Please, any help that any of you can provide would be most appreciated.
I've asked a few questions in Project Guidance in the past few days, but the responses are just too vague, and seem to assume that I am far more skilled in this than I am.
Nothing could be farther from the truth. Even After Days of Watching Tutorials, I just cannot seem to grasp how to put this all together.
As it sits, it appears that a combination of StateChange, BlinkWithoutDelay, Debounce, and Something Else is needed.
I just don't know how to implement them to get to the end result.
Thank you all again for taking the time to read through this.
-Z-
