I am posting here to get some help. I am using arduino Uno for displaying load cell value with 1306 OLED display. I am using HX711 as ADC. My code does not display anything in OLED, but shows data in serial monitor and saves data in SD card. For test purpose, I am trying to print " Hi" in display. Even this command has not been printed in display. Where am I doing wrong?
I have checked Display with some example code. It displays the commands, which proves display in is working condition. I am suspecting that there has some problem in my code. Can anyone please help to find out the problem?
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "HX711.h" //You must have this library in your arduino library folder
/*************************************************VARIABLES******************************************************/
#define DURATION 2 //Number of hours you want this program to run once the button is pressed
#define LOG_INTERVAL 100 //Milliseconds between entries (reduce to take more/faster data)
#define SYNC_INTERVAL 1000 // millis between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL 1 //Echo data to serial port
//Easy method to turn serial printing on and off. Set to 0 if you don't want to print to the Serial Monitor
RTC_DS1307 RTC; //define the Real Time Clock object
const int chipSelect = 10; //for the data logging shield, we use digital pin 10 for the SD cs line
char timestamp[30];
const int pushbutton = 8;
const int done_light = 9;
/***All the variables for voltage reading function***/
const int voltage_in = A0; //pin connected to the voltage divider output
float voltage_raw; //raw 0 to 1023 integer reading from the ADCs
float voltage_reading; //voltage value between 0 and 5V
float voltage_true; //voltage value between 0 and 10V
uint32_t start_time;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
//the logging file
File bhoomiFile;
#define DOUT 3
#define CLK 2
HX711 scale;
int average = 0;
//Change this calibration factor as pe
float calibration_factor = 122541;
/****************************************************SETUP*******************************************************/
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
delay(2000);
display.clearDisplay();
display.setTextSize(3);
display.setTextColor(WHITE);
display.setCursor(0, 5);
// Display static text
display.println("Hi!");
display.display();
pinMode(pushbutton, INPUT); //Set pushbutton as Input
pinMode(voltage_in, INPUT); //Set voltage input
pinMode(done_light, OUTPUT); //Set the LED as an output
digitalWrite(done_light, LOW); //Make sure the LED is off when we start the program
//chip select pin mode set within SD_INIT()
Serial.begin(115200); //Initialize the serial communication
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
display.println(F("SSD1306 allocation failed"));
for(;;);
//display.display();
// delay(2000);
// Clear the buffer
display.setCursor(0, 0);
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
scale.begin(DOUT, CLK);
Serial.println("Press T to tare");
scale.set_scale(calibration_factor); //Calibration Factor obtained from first sketch
scale.tare(); //Reset the scale to 0
#if ECHO_TO_SERIAL
Serial.println("Press button to start"); //Prompt user to press button
#endif
while(digitalRead(pushbutton)){}; //Wait for pushbutton input
#if ECHO_TO_SERIAL
Serial.println("(BUTTON PRESSED!)"); //Once pressed, display a message saying so
#endif
SD_INIT();
createFile();
//connect to RTC
Wire.begin(); //Wire.begin: Initiate the Wire library and join the I2C bus as a master or slave.
if (!RTC.begin()) //RTC.begin initializes the internal RTC. It needs to be called before any other RTC library methods
{ //Assume that it returns 1 on success and 0 on failure
bhoomiFile.println("RTC failed");
display.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
bhoomiFile.println("millis,Time (MM/DD/YYYY HH:MM:SS), weight (mg)"); //If RTC initializes successfully...set this as a header in the file
#if ECHO_TO_SERIAL
Serial.println("millis,Time (MM/DD/YYYY HH:MM:SS), weight (mg)");
start_time = millis(); //The very next step after this will be the data recording
//Therefore, note down the time at this moment as the start time
/*************************************************LOOP***********************************************************/
//Below: As long as current time - start time < required duration, keep recording the data
for(start_time; (millis() - start_time) < (DURATION * 60 * 60 * 1000L); )
//To have record time in HOURS: (DURATION * 60 * 60 * 1000L)
doTheThing();
while(1)
#if ECHO_TO_SERIAL
Serial.println("ALL DONE"); //Once the set amount of time has passed, display message saying so
digitalWrite(done_light, HIGH);
//lcd.home();
display.println("ALL DONE");
//lcd.home();
/************************************************FUNCTIONS*******************************************************/
void error(char *str)
Serial.print("error: ");
Serial.println(str);
while(1);
void SD_INIT()
Serial.print("Initializing SD card...");
pinMode(chipSelect, OUTPUT);
//Check if the card is present and can be initialized:
if (!SD.begin(chipSelect)) //SD.begin initializes the SD library and card; Returns 1 on success, 0 on failure
display.println("SD Card failed");
delay(30);
error("Card failed, or not present"); //Error function displays the error message if SD.begin fails and returns 0
return;
Serial.println("card initialized."); //If SD.begin is successful
void createFile()
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) //Make a new file every time the Arduino starts up
{ //Goes from 00 to 99
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (!SD.exists(filename)) //SD.exists() tests whether a file or directory exists on the SD card
{ //It returns true if the file or directory exists, false if not
//only open a new file if it doesn't exist
bhoomiFile = SD.open(filename, FILE_WRITE); /*SD.open() opens a file on the SD card. If the file is opened for writing,
it will be created if it doesn't already exist (but the directory containing it must already exist).
It returns a File object referring to the opened file; if the file couldn't be opened,
this object will evaluate to false in a boolean context*/
//FILE_WRITE enables read and write access to the file
break; // leave the loop!
if (!bhoomiFile) //If file couldn't be opened/created
error("couldn't create file");
Serial.print("Logging to: "); //Otherwise, display the name of the file generated
display.println("Hello, world!");
Serial.println(filename);
void doTheThing()
DateTime now;
//delay for the amount of time we want between readings
delay((LOG_INTERVAL - 1) - (millis() % LOG_INTERVAL));
//fetch the time
now = RTC.now();
sprintf(timestamp, "%02d:%02d:%02d %2d/%2d/%2d \n", now.hour(),now.minute(),now.second(),now.month(),now.day(),now.year()-2000);
Serial.println(timestamp);
bhoomiFile.print("");
bhoomiFile.print(millis(),DEC);
bhoomiFile.print(" , ");
display.println("filename");
//now = RTC.now();
bhoomiFile.print(" "); //This space is important. If you remove this, the seconds will not be recorded in the log file
bhoomiFile.print(now.month(), DEC);
bhoomiFile.print("/");
bhoomiFile.print(now.day(), DEC);
bhoomiFile.print(now.year(), DEC);
bhoomiFile.print(now.hour(), DEC);
bhoomiFile.print(":");
bhoomiFile.print(now.minute(), DEC);
bhoomiFile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
// Serial.print(now.month(), DEC);
// Serial.print("/");
// Serial.print(now.day(), DEC);
// Serial.print(now.year(), DEC);
// Serial.print(" ");
// Serial.print(now.hour(), DEC);
// Serial.print(":");
// Serial.print(now.minute(), DEC);
// Serial.print(now.second(), DEC);
// Serial.print("");
// Serial.print(millis(),DEC);
//Serial.print(scale.get_units()*1000, 4); //Up to 4 decimal points
//Log the voltage reading
bhoomiFile.print(", ");
bhoomiFile.print(scale.get_units()*1000, 4); //for variables of datatype 'float', the number in the print() funtion specifies
//the number of digits to be printed out
#if ECHO_TO_SERIAL
Serial.print(", ");
bhoomiFile.println();
#if ECHO_TO_SERIAL
#endif // ECHO_TO_SERIAL
//When you use file.write(), it doesn't write to the card until you flush() or close().
//Whenever you open a file, be sure to close it to save your data.
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
bhoomiFile.flush(); //flush() ensures that any bytes written to the file are physically saved to the SD card
The test code I used is given below. After running this code, display shows " Hello world"
#include <Wire.h>
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
Serial.println(F("SSD1306 allocation failed"));
for(;;);
delay(2000);
display.display();
