OLED Display problem
Hello, I stopped my project at the point, when I need to display current position at my OLED. Im not able to make any working code. When "acivate" void updateDisplay, program stops. Last I tried to update it each 500 millis, this doesnot help me too. I cant slow down whole program because of rotary encoder too, it is skipping steps if I put any display function into the main loop too frequently. Thank you for any help.
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
#include <AccelStepper.h>
#include <EZButton.h>
// PIN definitions motor driver
#define STEP_PIN  2  //step
#define DIR_PIN   5  //direction
#define EN_PIN 6    //stepper driver enable pin
// Define a stepper and the pins it will use  6400 steps per round with TCM2208 and NEMA 17 Creality 42-34
AccelStepper stepper(AccelStepper::DRIVER, STEP_PIN, DIR_PIN); // (Type of driver: with 2 pins, STEP, DIR - for TMC2208 Aliexpres driver)
int motorMaxSpeed = 150;    //50  maximum steps per second (about 3rps / at 16 microsteps)
int motorAccel = 10;  //steps/second/second to accelerate
// rotary encoder
#define ENCODER_CLK 8
#define ENCODER_DT 3
#define BTN_1_PIN 9
#define BTN_1 0
int lastClk = HIGH;
int counterEnc = 0;
int pulse_cnt = 0;
unsigned long previousMillis = 0;
unsigned long previousPulseMillis = 0;
float filtered_rpm = 0.0;
int counter2 = 0;
void ReadButtons(bool *states, int num) {
  //Read all button states however you want
  states[BTN_1] = !digitalRead(BTN_1_PIN);
EZButton _ezb(1, ReadButtons, 10000, 15000, 50);
int dock = 1;
// 1.3 OLED I2C displej Aliexpress
#define i2c_Address 0x3C   //initialize with the I2C addr 0x3C Typically eBay OLED's
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1   //   QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Banner
#define PROJEKT "Turnout v1.1"
//relay 2 module
int relay_2 = 4;
int relay_1 = 7;
//DCC orientation timer
unsigned long previousPolarityMillis;
// 'OK', 64x64px
const unsigned char epd_bitmap_OK [] PROGMEM = {
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0xe0, 0x38, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x10, 0x1e, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x78, 0x00, 0x3c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x00, 0x38, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x18, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0x80, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0xe3, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc3, 0x80, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x01, 0xc1, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc1, 0xc0, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x01, 0xc1, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0xe0, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x01, 0xc0, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x70, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x01, 0xc0, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x3c, 0x03, 0xff, 0x80,
	0x00, 0x00, 0x00, 0xe0, 0x1e, 0x0f, 0xff, 0xc0, 0x00, 0x00, 0x00, 0xe0, 0x0f, 0x1f, 0xff, 0xc0,
	0x00, 0x00, 0x00, 0xfe, 0x07, 0xfc, 0x01, 0xc0, 0x00, 0x0f, 0xff, 0xff, 0x03, 0xf8, 0x01, 0xc0,
	0x00, 0x1f, 0xff, 0xff, 0x01, 0xf8, 0x01, 0xc0, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x38, 0x01, 0xc0,
	0x00, 0x3c, 0x00, 0x00, 0x00, 0x38, 0x01, 0xc0, 0x00, 0x38, 0x00, 0x00, 0x00, 0x38, 0x01, 0xc0,
	0x00, 0x3c, 0x00, 0x00, 0x00, 0x38, 0x01, 0xc0, 0x00, 0x1f, 0xe0, 0x00, 0x00, 0x38, 0x01, 0xc0,
	0x00, 0x1f, 0xe0, 0x00, 0x00, 0x38, 0x01, 0xc0, 0x00, 0x1f, 0xe0, 0x00, 0x00, 0x38, 0x01, 0xc0,
	0x00, 0x38, 0x00, 0x00, 0x00, 0x38, 0x01, 0xc0, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x38, 0x01, 0xc0,
	0x00, 0x38, 0x00, 0x00, 0x00, 0x38, 0x01, 0xc0, 0x00, 0x3c, 0x00, 0x00, 0x00, 0x38, 0x01, 0xc0,
	0x00, 0x1f, 0xe0, 0x00, 0x00, 0x38, 0xe1, 0xc0, 0x00, 0x0f, 0xe0, 0x00, 0x00, 0x38, 0xe1, 0xc0,
	0x00, 0x07, 0xc0, 0x00, 0x00, 0x38, 0xe1, 0xc0, 0x00, 0x07, 0x00, 0x00, 0x00, 0x38, 0x01, 0xc0,
	0x00, 0x07, 0x00, 0x00, 0x01, 0xf8, 0x01, 0xc0, 0x00, 0x03, 0x80, 0x00, 0x0f, 0xf8, 0x01, 0xc0,
	0x00, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x00, 0x01, 0xff, 0xff, 0xfe, 0x1f, 0xff, 0xc0,
	0x00, 0x00, 0xff, 0xff, 0xf0, 0x0f, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// 'gears-6281075_640', 128x64px
const unsigned char bitmap_gears [] PROGMEM = {
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x30, 0xc3, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x3e, 0x70, 0xe7, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x77, 0xf0, 0xfe, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0xe3, 0xc0, 0x3c, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0xc1, 0x00, 0x08, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x01, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x1f, 0x83, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x3f, 0xe3, 0x80, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0xf0, 0xf3, 0x80, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x03, 0xe1, 0xc0, 0x3b, 0x80, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x0f, 0xc1, 0x83, 0x1b, 0x80, 0xc0, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x0f, 0xc3, 0x87, 0xdb, 0x80, 0xc1, 0xb0, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x0c, 0x03, 0x0c, 0x7f, 0x00, 0xf3, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x0c, 0x03, 0x18, 0x3c, 0x00, 0x1e, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x0c, 0x03, 0x30, 0x10, 0x00, 0x04, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x0c, 0x01, 0xe0, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x0f, 0xc1, 0xc0, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x03, 0xe1, 0xe0, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0xf0, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x78, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x18, 0x00, 0x3e, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x38, 0x00, 0xff, 0x80, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0x38, 0x03, 0xf8, 0xe0, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0x30, 0x07, 0xff, 0x30, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x01, 0x83, 0xf0, 0x0f, 0xc1, 0x90, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0xff, 0xff, 0x80, 0x58, 0x07, 0xf0, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x28, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0xff, 0xff, 0x00, 0x4c, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0xff, 0xff, 0xc0, 0xd8, 0x03, 0xf0, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x01, 0x81, 0xf0, 0x0c, 0x73, 0x90, 0x07, 0xe0, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x10, 0x06, 0x1c, 0x30, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x10, 0x03, 0x00, 0x60, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x08, 0x01, 0xc1, 0xc0, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x08, 0x00, 0x7e, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x18, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x30, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x60, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0xc0, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x18, 0x3c, 0x00, 0x1e, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x0c, 0x67, 0x00, 0xf3, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x06, 0xc1, 0x00, 0xc1, 0xb0, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x83, 0x81, 0x00, 0xc0, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0xc0, 0x01, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x60, 0x01, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x20, 0x01, 0x80, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x20, 0x00, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x63, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
  //OLED power up
  display.begin(i2c_Address, true);
  display.display();
  delay(2000);
  //relay position set
  pinMode(relay_1, OUTPUT);
  pinMode(relay_2, OUTPUT);
  digitalWrite(relay_1, LOW);
  digitalWrite(relay_2, LOW);
 // Set encoder pins as inputs
  pinMode(ENCODER_CLK, INPUT);
  pinMode(ENCODER_DT, INPUT);
//initialize pins
  pinMode(BTN_1_PIN, INPUT_PULLUP);
  pinMode(LED_BUILTIN, OUTPUT);
 //subscribe to needed events
  _ezb.Subscribe(BTN_1, Btn1Pressed, PRESSED);
  _ezb.Subscribe(BTN_1, Btn1Released, RELEASED);
  _ezb.Subscribe(BTN_1, Btn1Hold, HOLD);
  _ezb.Subscribe(BTN_1, Btn1HoldReleased, HOLD_RELEASED);
 // pinMode(PWMPin, INPUT_PULLUP);
  pinMode (EN_PIN, OUTPUT);
  digitalWrite(EN_PIN, LOW);
  stepper.setMaxSpeed(motorMaxSpeed);
  stepper.setAcceleration(motorAccel);
  stepper.moveTo(0);
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(SH110X_WHITE);
  display.setCursor(30, 30);
  display.print(PROJEKT);
  display.display();
//init done information
  Serial.print("Init done");
  delay(10);
  delay(2000);
  display.drawBitmap(32, 0, epd_bitmap_OK, 64, 64, SH110X_WHITE);
  display.display();
  display.setTextSize(8);
 /* unsigned long currentMillis = millis();*/
  int newClk = digitalRead(ENCODER_CLK);
  if (newClk != lastClk) {
    // There was a change on the CLK pin
    lastClk = newClk;
    int dtValue = digitalRead(ENCODER_DT);
    // Rotating clockwise causes the CLK pin to go low first, and then the DT pin goes low too.
    if (newClk == LOW && dtValue == HIGH) {
      counterEnc--;
      if (counterEnc <= 1 ) {
        counterEnc = 1;
      Serial.print("Rotated clockwise ⏩ Pos:");
      Serial.println(counterEnc);
    // Rotating counterclockwise causes the DT pin to go low first, and then the CLK pin go low.
    if (newClk == LOW && dtValue == LOW) {
      counterEnc++;
      if (counterEnc >= 20 ) {
        counterEnc = 20;
      Serial.print("Rotated counterclockwise ⏪ Pos:");
    //pulse_cnt++;
     counter2 = counterEnc;
  // Calculate speed by counting the pulses during a second
  if (currentMillis-previousMillis >= 1000) {
    // After counting the pulses we have to calculate the speed(revolutions per minute),
    // by knowing that KY-040 Rotary Encoder module has 20 steps per revolution.
    // We derive the equation: RPM =(counts_second / 20)* 60s = counts_second * 3
    int RPM = pulse_cnt * 3;
    pulse_cnt = 0;
    Serial.print("RPM = ");
    Serial.println(RPM);
_ezb.Loop();
Serial.println(counter2);
    dock = counter;
    if(counter <= 9) {
    display.setCursor(40, 3);
    display.println(dock);
    display.display();
    else {
    display.setCursor(15, 3);
    display.display();
//correct DCC polarity to position
unsigned long currentPolarityMillis = millis();
if(currentPolarityMillis - previousPolarityMillis >= 500 ) { //mala hodnota seka program
previousPolarityMillis = currentPolarityMillis;
checkPolarity();
updateDisplay();
void updateDisplay() {
    /*dock = counterEnc;
    if(counterEnc <= 9) {
    display.display();
    else {
    display.display();
// button pressed
void Btn1Pressed() {
  digitalWrite(LED_BUILTIN, HIGH);
  Serial.println("pressed");
// button released
void Btn1Released() {
  digitalWrite(LED_BUILTIN, LOW);
  Serial.println("released");
//  button hold
bool state = true;
void Btn1Hold() {
  state = !state;
  digitalWrite(LED_BUILTIN, state);
  Serial.println("hold");
// button released after hold
void Btn1HoldReleased() {
  for (int i = 0; i < 6; i++) {
    state = !state;
    delay(50);
  Serial.println("hold released");
void checkPolarity() {
if (counter2 >= 5 && counter2 < 15)   {
//Serial.println("Normal Polarity");
    else {
digitalWrite(relay_1, HIGH);
digitalWrite(relay_2, HIGH);
The code works perfect until serial monitoring, immidiatelly I want to send the encoder position to the display, it is not stabil.
"works perfect" does not equal "does not work"
How is an encoder an OLED problem? Your code is a mashup and you lost control. Start here... does this compile and show on your OLED?
  display.print("Hello, World!");
  display.display();
Side note... your delays probably caused the problems you observe, from the rotary encoder sketch you used in your mashup...
Note: your code will need to read the state of the pins frequently in order to detect the rotations correctly. If your loop() takes too long (e.g. you use delay() in your code), we recommend using attachInterrupt() to listen for changes in the CLK pin. Assuming CLK is connected to pin 2, and DT to pin 3
Continuing with testing devices, add the rotary switch...
#define ENCODER_CLK 2
int lastClk = HIGH;
  display.display();
    lastClk = newClk;
      display.setTextColor(SH110X_BLACK);
      display.setCursor(20, 20);
      display.print(" < CCW");
      display.setCursor(80, 20);
      display.print(" CW >");
      display.display();
      display.display();
Add a counter...
int lastClk = HIGH, counterEnc, counterEncOld;
  display.display();
    lastClk = newClk;
      counterEnc--;
      counterEnc++;
    if (counterEncOld != counterEnc) {
      if (counterEncOld < 0)
        display.setCursor(60, 20);
        display.setCursor(65, 20);
      display.print(counterEncOld);
      counterEncOld = counterEnc; // store count
      if (counterEnc < 0)
      display.print(counterEnc);
    display.display();
diagram.json for wokwi.com
  "version": 1,
  "author": "Anonymous maker",
  "editor": "wokwi",
  "parts": [
    { "type": "wokwi-arduino-nano", "id": "nano", "top": -4.8, "left": -0.5, "attrs": {} },
      "type": "board-ssd1306",
      "id": "oled1",
      "top": 41.54,
      "left": 173.03,
      "attrs": { "i2cAddress": "0x3c" }
    { "type": "wokwi-ky-040", "id": "encoder1", "top": -84.7, "left": -48.8, "attrs": {} },
    { "type": "wokwi-relay-module", "id": "relay1", "top": -67, "left": 163.2, "attrs": {} },
    { "type": "wokwi-relay-module", "id": "relay2", "top": -143.8, "left": 163.2, "attrs": {} },
      "type": "wokwi-led",
      "id": "led1",
      "top": -166.8,
      "left": 291.8,
      "attrs": { "color": "red" }
    { "type": "wokwi-led", "id": "led2", "top": -90, "left": 291.8, "attrs": { "color": "red" } }
  "connections": [
    [ "oled1:GND", "nano:GND.1", "black", [ "v-9.6", "h38.4" ] ],
    [ "oled1:VCC", "nano:5V", "red", [ "v-38.4", "h-19.05" ] ],
    [ "oled1:SCL", "nano:A5", "green", [ "v-28.8", "h-66.9" ] ],
    [ "oled1:SDA", "nano:A4", "green", [ "v-19.2", "h-86.33" ] ],
    [ "encoder1:CLK", "nano:2", "green", [ "h0" ] ],
    [ "nano:3", "encoder1:DT", "green", [ "v0" ] ],
    [ "encoder1:VCC", "nano:5V", "red", [ "h0" ] ],
    [ "encoder1:GND", "nano:GND.1", "black", [ "h0" ] ],
    [ "nano:GND.1", "relay1:GND", "black", [ "v0" ] ],
    [ "nano:5V", "relay1:VCC", "red", [ "v0" ] ],
    [ "nano:4", "encoder1:SW", "green", [ "v0" ] ],
    [ "nano:5", "relay1:IN", "green", [ "v0" ] ],
    [ "nano:6", "relay2:IN", "green", [ "v0" ] ],
    [ "nano:5V", "relay2:VCC", "red", [ "v0" ] ],
    [ "nano:GND.1", "relay2:GND", "black", [ "v0" ] ],
    [ "relay1:COM", "led2:A", "red", [ "h0" ] ],
    [ "nano:5V", "relay1:NO", "red", [ "v-48", "h192", "v-28.8" ] ],
    [ "nano:GND.1", "led2:C", "black", [ "v-57.6", "h163.2" ] ],
    [ "nano:GND.1", "led1:C", "black", [ "v-134.4", "h153.6", "v-28.8" ] ],
    [ "nano:5V", "relay2:NO", "red", [ "v-48", "h201.6", "v-105.6" ] ],
    [ "relay2:COM", "led1:A", "red", [ "h0" ] ]
  "dependencies": {}
Thank you, I did not see what was wrong, I rebuilt this code again and all works.
#include <Wire.h>
#include <U8g2lib.h>
// Stepper motor driver
//Display
U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
bool needDisplayUpdate = false;
//Encoder with switch
#define ENCODER_CLK 3   // CLK pin
#define ENCODER_DT 8    // DT pin
//encoder
volatile int encoderPos = 0;
int lastEncoderPos = 0;
unsigned long lastInterruptTime = 0;
unsigned long debounceDelay = 40; // debounce time 20 default
//button
#define BTN_1_PIN 9
#define BTN_1 0
  //Read  button states
  states[BTN_1] = !digitalRead(BTN_1_PIN); }
EZButton _ezb(1, ReadButtons, 1000, 500, 5);
//relay 2 module
int relay_2 = 4;
int relay_1 = 7;
unsigned long previousButtonMillis;
int encoderPolarity;
  // encoder
  pinMode(ENCODER_CLK, INPUT_PULLUP);
  pinMode(ENCODER_DT, INPUT_PULLUP);
  // button
   //subscribe to needed events for button
  // motor driver;
  stepper.moveTo(0);
  //relay set
  //display
  u8g2.begin();
  u8g2.clearBuffer();
  u8g2.setFont(u8g2_font_fub49_tn);
  u8g2.setCursor(22 , 57);
  u8g2.println("00");
  u8g2.sendBuffer();
  attachInterrupt(digitalPinToInterrupt(ENCODER_CLK), handleEncoder, CHANGE);
_ezb.Loop();
  if (encoderPos != lastEncoderPos) {
    lastEncoderPos = encoderPos;
    needDisplayUpdate = true;
 if(needDisplayUpdate) {
    if(encoderPos <= 9) {
    u8g2.clearBuffer();
    u8g2.setCursor(37, 57);
    u8g2.println(encoderPos);
    u8g2.sendBuffer();
    else {
    u8g2.clearBuffer();
    u8g2.setCursor(22, 57);
    u8g2.sendBuffer();
if(currentPolarityMillis - previousPolarityMillis >= 1000 ) {
checkPolarity();
/////////////////////////////////functions////////////////////////////////
void handleEncoder() {
  if (currentMillis - lastInterruptTime > debounceDelay) {
    int CLKstate = digitalRead(ENCODER_CLK);
    int DTstate = digitalRead(ENCODER_DT);
    if (CLKstate == DTstate) {
      encoderPos--;
      if (encoderPos <= 1 ) {
        encoderPos = 1;
      encoderPos++;
      if (encoderPos >= 20 ) {
        encoderPos = 20;
    lastInterruptTime = currentMillis;
///////////////////////////////////////button/////////////////////////////////////
    int motor_1_Position = ( 320 * encoderPos );
    stepper.runToNewPosition(motor_1_Position);
    encoderPolarity = encoderPos;
bool state = true;
void Btn1Hold() {
  state = !state;
    digitalWrite(EN_PIN, HIGH);
    state = !state;
    delay(5);
////////////////////////////////////////polarity////////////////////////////////
//change polarity if necessary
if (encoderPolarity >= 5 && encoderPolarity < 15)   {
    else {
