OLED & SD Card Lib problem
So I try to use a OLED in my project and display on my OLED some data but while working
on the code I found a problem and couldn't understand why it's happening what's happening.
So I got the OLED simple example code as well DHT lib and SD card library which looks
it's cause the problem.
Code:
// -----------------------------------------------SD_Card
#include <SD.h>
const int chipSelect = 10;
File dataFile;
// -----------------------------------------------OLED
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000 };
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
// -----------------------------------------------DHT11
#include <dht.h>
#define dht_pin A0
dht DHT;
unsigned long DHTCount = 0;
void setup()   {
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  delay(2000);
  display.clearDisplay();
  display.drawPixel(10, 10, WHITE);
  display.display();
  delay(2000);
int x1;
    display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  display.println(x1);
  display.println("Hello, world!");
  display.setTextColor(BLACK, WHITE); // 'inverted' text
  display.println(3.141592);
  display.setTextSize(2);
  display.print("0x"); display.println(0xDEADBEEF, HEX);
  display.display();
  x1++;
The fun part is if I run the code as it's above the OLED will complitly freeze and will not display anything.
but if I get out the sd card part, delete it:
#include <SD.h>
File dataFile;
the OLED will work normally.
One note that the display will not work even if you put that part in comment /* */
you need to complitly cut it out or delete the SD_Card part so the OLED could work.
I tried even change position maybe the libs work in a order but that didn't helped.
Why this is happening?
I really don't understand, do I miss something?
Is it the sdcard lib processing something that lags all the chip(Ram)?
Thanks for your time,
D.60
Every instance of the File class needs 512 bytes of SRAM. I'm guessing, with all the other libraries that you are using, that you do not have 512 bytes of SRAM available.
2KB SRAM
So you tell me all that libs eats all my ram?
Is there a possible way (code) to see how much ram (display it on serial monitor or OLED) is available
or in use ?
D.60
What IDE version are you running?
Apparently, there was a SD card problem in 1.8.0, which should have been fixed in 1.8.1.
BR Niels
I use 1.0.5 cause reasons :smiley:
