Hello guys,
I have built a one wire rpm pick up that uses a wire wrapped around the spark plug. The circuit consists of a zener diode, a rectifier, a couple resistors, and a cap. I hooked it up to an O scope, and it works as expected. The frequency veries with RPM very consistantly.
I hook it up to the Arduino, but the output is not consistant. the RPM goes up after the a few minutes. Its not just the engine warming up either. I believe it has to be the code. I hooked up a tiny tach to it, and it does the same thing.
My tach puts out an AC wave, and the tiny tach is digital I believe. If anyone could point me into the right direction I would really appreciate it. Here is the code.
int iTestPin=13; //Pin which generates test pulses, this is not needed when actual pulse is available for measurement
int iPulsePin = 2; //Pin serving as external interrupt (pin 2) to count the pulses
static float siPulseCounter=0; //Variable keeping track of pulse counts
static float siSecondCount=0; //Variable keeping track no. of seconds in the timer1 block
float rpm;
void SetupTimer1() //Setting up timer1 with appropriate register values
TCCR1A = 0; // No PWM is used.So set this to zero.
TCCR1B = 1<<CS12 | 0<<CS11 | 0<<CS10; // Input clock is set to F(cpu)/256
TIMSK1 = 1<<TOIE1; // Enable timer interrupt to detect overflow
Set the timer count to overflow to in 1 second.
My board has a 16MHz oscillator.
Reload Timer Value = ((2 ^ Bits) - 1) - ((Input Frequency / Prescale) / Target Frequency)
= 65535 - ((16 x 10 ^6 Hz)/256)/1 Hz
= 65535 - 62500
= 3035
TCNT1=0x0bdb; //3035 in hex
ISR(TIMER1_OVF_vect) // Timer1 ISR when it overflows
TCNT1=0x0bdb; //Reset Timer1 to count another second
siSecondCount++; //Increase second count
if(siSecondCount>=1) //If 1 Seconds are attained Print the Pulse count to serial port.
rpm = siPulseCounter*16.54; //Multiplier has to do with Reference Voltage this is at 5v ref.
Serial.print("RPM is ");
Serial.println(rpm); //Print as decimal value
siPulseCounter=0; //Reset counter values for next minute cycle
siSecondCount=0;
void setup(void)
pinMode(iPulsePin, INPUT); // Set Pulsepin to accept inputs
digitalWrite(iPulsePin, LOW);
pinMode(iTestPin, OUTPUT); // Test signal generator pin as output. Can be ignored if the actual digital signal is available
attachInterrupt(0, count, RISING); // Caputres external interrupt 0 at iPulsepin at rising edge and calls funtion count defined below
Serial.begin(115200); // Begin Serial communication at baudrate 9600 bps
SetupTimer1(); // Call Setuptimer1 function
Serial.println(" Initialising, Please wait...");
void loop(void)
/*** Following 4 lines just generate pulses for testing purposes.
All the 4 lines Can be ignored if the actual digital signal is available ***/
digitalWrite(iTestPin, HIGH); // sets the iTestPin ON
delay(6.89); // waits for a second
digitalWrite(iTestPin, LOW); // sets the iTestPin off
delay(2); // waits for a second
void count() // Function called by AttachInterrupt at interrupt at int 0
siPulseCounter++; //increment the pulse count
