When i upload the keyestudio 4wd BT Car V2.0 lesson 8 motor driver shield, Tt's uploaded successfully but just M1 and M2 motors are ruining M3 and M4 motors are not working i tried to change the jumblers but same result, if you can help
Thanks A lot.
lesson 8
motor driver shield
http://www.keyestudio.com
#define ML_Ctrl 4 // define the direction control pin of B motor
#define ML_PWM 5 //define the PWM control pin of B motor
#define MR_Ctrl 2 //define direction control pin of A motor
#define MR_PWM 9 //define the PWM control pin of A motor
pinMode(ML_Ctrl, OUTPUT);//define direction control pin of B motor as output
pinMode(ML_PWM, OUTPUT);//define PWM control pin of B motor as output
pinMode(MR_Ctrl, OUTPUT);//define direction control pin of A motor as output.
pinMode(MR_PWM, OUTPUT);//define the PWM control pin of A motor as output
digitalWrite(ML_Ctrl,HIGH);//set the direction control pin of B motor to HIGH
analogWrite(ML_PWM,200);//set the PWM control speed of B motor to 200
digitalWrite(MR_Ctrl,HIGH);//set the direction control pin of A motor to HIGH
analogWrite(MR_PWM,200);//set the PWM control speed of A motor to 200
//front
delay(2000);//delay in 2s
digitalWrite(ML_Ctrl,LOW);//set the direction control pin of B motor to LOW
digitalWrite(MR_Ctrl,LOW);//set the direction control pin of A motor to LOW
//back
analogWrite(MR_PWM,200);// set the PWM control speed of A motor to 200
//left
digitalWrite(MR_Ctrl,LOW);// set the direction control pin of A motor to LOW
//right
analogWrite(ML_PWM,0);//set the PWM control speed of B motor to 0
analogWrite(MR_PWM,0);//set the PWM control speed of A motor to 0
//stop
